كورس تعليم الثري دي ماكس باحتراف برابط مباشر واحد
النتائج 1 إلى 3 من 3
    الصورة الرمزية مهندس وليد سمير
    مهندس وليد سمير
    مهندس وليد سمير غير متواجد حالياً
    Received: 19
    E-Learning | 3DS Max 2009 Essential Training | 649 MB
    As the most widely used 3D animation software in the world, 3ds Max is capable of creating stunning visual effects for a broad range of purposes. It can be used to create effects for everything from video games and feature films to architectural walkthroughs and mechanical designs. In 3ds Max 2009 Essential Training, instructor Steve Nelle provides a thorough introduction to the principles of 3D modeling, while also sharing practical techniques that experienced users can apply to their own workflows. Steve establishes the principles and best practices of the 3D production process, introduces the 3ds Max interface, and explores modeling in depth. He also demonstrates how to create and transform primitive objects, use specific modeling techniques, work at the sub-object level, and apply a variety of modifiers. Example files accompany the course.
    Table of *******s
    Introduction
    Welcome
    Using the example files
    1. Getting Started
    Understanding the production process
    The importance of traditional art concepts and principles
    Using reference materials
    Understanding 3D space
    Improving your workflow
    Getting help
    2. Interface Essentials
    Understanding the interface
    Working in the viewports
    Changing the measurement system
    Using snaps
    Using grids
    Customizing the interface
    Right-click features
    3. Working with Files
    Starting a new project
    Importing and opening files
    Saving and exporting files
    Holding and Fetching
    Summary info and object properties
    4. Working with Objects
    Selection techniques
    Naming objects
    Reading the Transform Gizmo
    Moving objects
    Rotating objects
    Scaling objects
    Understanding coordinate systems
    Introducing pivot points
    Working in Pivot mode
    Hiding and freezing objects
    Cloning objects
    Grouping objects
    5. Creating Off-the-Shelf Geometry
    Creating standard primitive objects
    Creating extended primitive objects
    Creating shapes
    Creating compound objects
    Creating architectural objects pt. 1: Walls
    Creating architectural objects pt. 2: Doors and Windows
    Creating architectural objects pt. 3: Railings
    Creating architectural objects pt. 4: Stairs
    Creating architectural objects pt. 5: Foliage
    Project: Creating a video camera
    6. Specific Modeling Techniques
    Extruding objects
    Lathing objects
    Changing the lathe axis
    Lofting objects
    Common lofting errors
    Loft deformations
    The Boolean command
    The Pro Boolean command
    Box modeling
    Building a plane with box modeling
    Paint deformations
    Patch modeling
    NURBS modeling
    The NURBS Fillet command
    Surface normals
    7. Project: Constructing a Room Using Multiple Modeling Techniques
    Building a floor and walls
    Building a table with legs
    Building a lamp with a shade
    Building a door
    Building a doorknob
    Building curtains
    Adding plants
    8. Working at the Sub-Object Level
    Sub-object types
    Sub-object selection
    Converting vs. using a modifier
    Sub-object transformations
    2D sub-object modeling commands
    3D sub-object modeling commands
    Ignore Backfacing
    Soft Selection
    Project: Building a low polygon flying saucer
    9. Working with Modifiers
    What is the modifier stack?
    Important things to know
    Copying and pasting modifiers
    Understanding the importance of modifier order
    Applying modifiers in the middle of the stack
    Collapsing the stack...how and why
    Using the Displace Modifier
    The Flex modifier
    The Morpher modifier
    The Noise modifier
    The Slice modifier
    The Symmetry modifier
    Using the Symmetry modifier for character modeling
    The TurboSmooth modifier
    The Hair and Fur modifier
    رابط التحميل
    http://www.arab-school.com/downloads...school.com.zip
    طبــعآآ باسورد فكـَ الضغــط >>>www.arab-school.com
    bashar abojafar
    bashar abojafar غير متواجد حالياً
    مسا الخير
    لو سمحتو بديكتاب الماكس 9 كيف بدي حملو
    engyoyo
    engyoyo غير متواجد حالياً
    للأسف الرابط لا يعمل
