SolidWorks Premium 2009 SP0.0 x86/x64 FuLL Multilanguage
النتائج 1 إلى 2 من 2
    لعله يرحمني
    لعله يرحمني غير متواجد حالياً
    First download this link
    Second download this link
    After their download, continue to solidworks..
    Please read .pdf in the rar file
    %100 working..
    Download Crack
    if you have it on DVD, copy files to HDD and then run setup.exe manually
    also, Vista "Home" is not supported
    I dunno? A bit too strong, ya think?
    At SolidWorks World the most anticipated moments are sleeping and the presentation of features on the next release. SolidWorks 2009 is set to launch the third quarter of 2008 and the development crew has some very pretty functionality they%u2019re cooking up.
    Do you want SolidWorks to perform better?
    Well, %u2018scalability%u2019 just happened to be the flaming corporate whip lashed repeatedly every time 2009 was brought up. (Seriously, it was like a whipping, but one you don%u2019t mind so much. %u2018Thankyou sir, may I have another%u2019 type of stuff.)
    You can%u2019t have too much talk about performance as long as it%u2019s true. And as Mike Puckett mentioned, the SolidWorks team declared the same mantra of performance increases and concern for the user whether they were loopy or not.
    So, performance increases are a sure bet. Really? Sure looks like it. Take a read.
    Assemblies
    SpeedPak Technology
    I love the terminology they come up with sometimes. Speedpak does indeed sound better than amphetamine sulphate pak, but the results are the same. Adjusting a slider is like popping tabs as your model eliminates what components are loaded. Plus, you can make selections for what stays. I%u2019m interested to know what/how it chooses to eliminate. I%u2019m also kinda wondering if this is a modified, yet sexier, lightweight components.
    BOM in Assembly
    You can create a BOM in an assembly. When you edit a field in that BOM it updates the corresponding custom property. This looked great, but I%u2019m concerned with large assembly BOMs. Will they be too small? Scalable? Multiple tabs?
    Toolbox Enhancements
    You can change configurations right on the screen and update bolt size using Instant3D. I cringe at toolbox stuff. Mostly because it%u2019s never worked all that well for me and it lacks aircraft standard hardware. I%u2019ll admit though, it%u2019s been a couple years since I%u2019ve used it last. It%u2019s great they%u2019re tying the Instant3D in with assembly
    Ribbon Cable Support
    There%u2019s some added ribbon cable functionality added to routing. Looks like fun, but I don%u2019t do wiring, so%u2026 ya, cool.
    Sketch Enhancements
    Dimensioning
    Dimensions suddenly appear as you%u2019re sketching. As soon as you sketch a line, you can immediately type the dimension in. This is how it always should have been. I%u2019m thinking (hoping) this will be an option because it could get annoying if you want to sketch or trace a quick profile.
    Slot Tool
    I don%u2019t think I need to say anymore, except it works like the sketch offset tool, but fast as greased death.
    Negative Dimension
    Finally, some negativity. Enter a negative dimension, and it goes the other direction.
    Stretch
    With the tool you can stretch geometry that%u2019s dimensioned. It supports negative dimension.
    Sheet Metal
    Solid to Sheet Metal
    This is more than just Insert Bends. Make a solid, select a main face and the edges to rip. It then wraps it in sheet metal and allows you to unbend it. There%u2019s got to be limitation with complex parts which could be really annoying. Hopefully it will deal with these well. I can see this command eliminating a lot of typical problems with sheet metal and the process of step-by-step sheet metal feature creation.
    Plastic Tools
    Lip and Groove, Shell and Draft
    Automatically adds a lip and groove to the split part as well as Shell and Draft. They were going to quick to tell if this was in a single part file or if it could be done in an assembly. Seems simple in a part context.
    User Interface
    Command Manager
    I hear the angels singing with a lot of SolidWorks Users that like this thing. You can now put it on the sides.
    Double-Click Middle Mouse button Zoom-to-Fit
    Ya know, like in AutoCrad. They showed it in a drawing, so I%u2019m not sure it%u2019s the same in the model. If it%u2019s not, it should be and for pete%u2019s sake, zoom to the model geometry, not the boundary.
    Magnifier
    Quickly magnify an area of the screen without having to zoom in and out. Hmmm%u2026 Hmmmm. Sounds nice. You will have to see this because it made me kinda snicker. An actual magnifying glass pops up. I pictured an old coot with bad eyes. It%u2019s neat I suppose, and watch, I%u2019ll end up finding it the most useful thing.
    Triad Orientation
    Click on the X, Y or Z axis and the model is oriented to that view. A little bit closer to eliminating the view orientation toolbar and pop-up.
    Drawings
    Drag Drop Leaders
    You can drag and drop hole callouts to another instance of feature.
    Title Block Wizard
    Now you won%u2019t have to edit the sheet format, use that crappy macro or hire someone to make a crappy macro for you. There are so many different types of title blocks out there; I%u2019m really interested to see how this works.
    Comparison
    All, this sounds nice huh. How does it compare though?
    The development crew did a side-by-side of 2008 and 2009 opening a 10,000 part assembly inserting a 3-view into a drawing, adding a shaded assembly, making a change to the assembly and then going back to the drawing for the update. 2009 took a little bit to add the views, but not near as long as 2008. After that 2009 was hella fast. It was done before 08 had made changes to the assembly.
    Ya know, 2008 looked great, very fancy new interface but not too much in the performance area. Some felt there was too much attention in this area. Just in the few things above you can see the difference in the direction for the new release. Even the UI changes work more toward how the users are use to working. While I don%u2019t necessarily agree with keeping old practice to avoid learning something new, it does show SolidWorks is listening to the user and what%u2019s important to them.
    What do you think? Good changes?
    Download 32 Bit - x86
    Code:
    http://rapidshare.com/files/16930946...net.part01.rar
    http://rapidshare.com/files/16931422...net.part02.rar
    http://rapidshare.com/files/16941638...net.part03.rar
    http://rapidshare.com/files/16942089...net.part04.rar
    http://rapidshare.com/files/16942562...net.part05.rar
    http://rapidshare.com/files/16942861...net.part06.rar
    http://rapidshare.com/files/16943789...net.part07.rar
    http://rapidshare.com/files/16943162...net.part07.rar
    http://rapidshare.com/files/16944161...net.part08.rar
    http://rapidshare.com/files/16944529...net.part09.rar
    http://rapidshare.com/files/16945711...net.part10.rar
    http://rapidshare.com/files/16944870...net.part10.rar
    http://rapidshare.com/files/16946099...net.part11.rar
    http://rapidshare.com/files/16946486...net.part11.rar
    http://rapidshare.com/files/16945222...net.part11.rar
    http://rapidshare.com/files/16946863...net.part12.rar
    http://rapidshare.com/files/16947270...net.part13.rar
    http://rapidshare.com/files/16947663...net.part14.rar
    http://rapidshare.com/files/16948086...net.part15.rar
    http://rapidshare.com/files/16948596...net.part16.rar
    http://rapidshare.com/files/16949045...net.part17.rar
    http://rapidshare.com/files/16949512...net.part18.rar
    http://rapidshare.com/files/16949950...net.part19.rar
    http://rapidshare.com/files/16950444...net.part20.rar
    http://rapidshare.com/files/16950925...net.part21.rar
    http://rapidshare.com/files/16951575...net.part22.rar
    http://rapidshare.com/files/16952895...net.part23.rar
    http://rapidshare.com/files/16956981...net.part24.rar
    http://rapidshare.com/files/16957482...net.part25.rar
    http://rapidshare.com/files/16957955...net.part26.rar
    http://rapidshare.com/files/16958421...net.part27.rar
    http://rapidshare.com/files/16958926...net.part28.rar
    http://rapidshare.com/files/16959443...net.part29.rar
    http://rapidshare.com/files/16959948...net.part30.rar
    http://rapidshare.com/files/16960488...net.part31.rar
    http://rapidshare.com/files/16961018...net.part32.rar
    http://rapidshare.com/files/16961538...net.part33.rar
    http://rapidshare.com/files/16962037...net.part34.rar
    http://rapidshare.com/files/16962544...net.part35.rar
    http://rapidshare.com/files/16963152...net.part36.rar
    http://rapidshare.com/files/16963668...net.part37.rar
    http://rapidshare.com/files/16964172...net.part38.rar
    http://rapidshare.com/files/16964630...net.part39.rar
    http://rapidshare.com/files/16965074...net.part40.rar
    http://rapidshare.com/files/16965504...net.part41.rar
    http://rapidshare.com/files/16965907...net.part42.rar
    http://rapidshare.com/files/16966298...net.part43.rar
    http://rapidshare.com/files/16966696...net.part44.rar
    http://rapidshare.com/files/16967101...net.part45.rar
    http://rapidshare.com/files/16967508...net.part46.rar
    http://rapidshare.com/files/16967888...net.part47.rar
    http://rapidshare.com/files/16968253...net.part48.rar
    http://rapidshare.com/files/16968591...net.part49.rar
    http://rapidshare.com/files/16968793...net.part50.rar
    Download 64 Bit - x64
    Code:http://rapidshare.com/files/20270002...bit.part01.rar
    http://rapidshare.com/files/20270775...bit.part02.rar
    http://rapidshare.com/files/20271618...bit.part03.rar
    http://rapidshare.com/files/20272542...bit.part04.rar
    http://rapidshare.com/files/20273465...bit.part05.rar
    http://rapidshare.com/files/20274448...bit.part06.rar
    http://rapidshare.com/files/20275421...bit.part07.rar
    http://rapidshare.com/files/20276407...bit.part08.rar
    http://rapidshare.com/files/20277579...bit.part09.rar
    http://rapidshare.com/files/20278654...bit.part10.rar
    http://rapidshare.com/files/20279771...bit.part11.rar
    http://rapidshare.com/files/20280903...bit.part12.rar
    http://rapidshare.com/files/20282084...bit.part13.rar
    http://rapidshare.com/files/20283383...bit.part14.rar
    http://rapidshare.com/files/20286112...bit.part15.rar
    http://rapidshare.com/files/20287300...bit.part16.rar
    http://rapidshare.com/files/20288536...bit.part17.rar
    http://rapidshare.com/files/20289785...bit.part18.rar
    http://rapidshare.com/files/20290951...bit.part19.rar
    http://rapidshare.com/files/20292081...bit.part20.rar
    http://rapidshare.com/files/20293213...bit.part21.rar
    http://rapidshare.com/files/20294348...bit.part22.rar
    http://rapidshare.com/files/20295459...bit.part23.rar
    http://rapidshare.com/files/20296548...bit.part24.rar
    http://rapidshare.com/files/20297616...bit.part25.rar
    http://rapidshare.com/files/20298590...bit.part26.rar
    http://rapidshare.com/files/20299466...bit.part27.rar
    http://rapidshare.com/files/20300340...bit.part28.rar
    http://rapidshare.com/files/20301136...bit.part29.rar
    http://rapidshare.com/files/20301895...bit.part30.rar
    http://rapidshare.com/files/20302690...bit.part31.rar
    http://rapidshare.com/files/20303388...bit.part32.rar
    http://rapidshare.com/files/20304033...bit.part33.rar
    http://rapidshare.com/files/20304631...bit.part34.rar
    http://rapidshare.com/files/20305180...bit.part35.rar
    http://rapidshare.com/files/20305730...bit.part36.rar
    http://rapidshare.com/files/20306249...bit.part37.rar
    http://rapidshare.com/files/20306773...bit.part38.rar
    http://rapidshare.com/files/20307257...bit.part39.rar
    http://rapidshare.com/files/20307794...bit.part40.rar
    http://rapidshare.com/files/20308383...bit.part41.rar
    http://rapidshare.com/files/20309079...bit.part42.rar
    http://rapidshare.com/files/20309727...bit.part43.rar
    http://rapidshare.com/files/20310462...bit.part44.rar
    http://rapidshare.com/files/20311198...bit.part45.rar
    http://rapidshare.com/files/20312042...bit.part46.rar
    http://rapidshare.com/files/20312918...bit.part47.rar
    http://rapidshare.com/files/20313857...bit.part48.rar
    http://rapidshare.com/files/20314805...bit.part49.rar
    http://rapidshare.com/files/20315755...bit.part50.rar
    http://rapidshare.com/files/20315764...bit.part51.rar
    semsem83
    semsem83 غير متواجد حالياً
    thank you for your do
