كلمة لا يكتبها الكومبيوتر!!!
النتائج 11 إلى 20 من 23
    طارق سليمان
    طارق سليمان غير متواجد حالياً
    According to this rather breathless little message, which circulates via email and online, it is not possible to create a folder named "CON" on a Microsoft Windows based computer. The message claims that not even Bill Gates or the whole Microsoft "Team" can explain why this might be so.
    It is in fact perfectly true that you cannot create a folder named "CON", nor can you rename an existing folder to "CON". However, there is no mystery surrounding this restriction whatsoever. The "team" at Microsoft, and a great many others besides, know perfectly well why you cannot name a folder "CON". "CON" and a number of other character strings are in fact reserved names that go back to the days of DOS and cannot be used to name folders or files. Other reserved names are:
    • PRN
    • AUX
    • NUL
    • LPT1
    • COM1
    • Potential drive letter - A: to Z:
    • A number of others
    If you try to name a folder using one of these reserved names, the name will automatically revert to the default, generally "New Folder". Moreover, if you try to use a reserved name to name a file such as a Notepad or Microsoft Word document you will generally receive an error message similar to the following:
    Depending on exactly how you save the file, you may instead receive a warning message advising that a file with that name already exists. However, even if you choose "Yes" to overwrite the existing file, you will still not be allowed* to save the file.
    While there is no mystery about this issue, it might have saved user confusion if Windows displayed an explanatory error message when attempting to create a folder with a reserved name as well.
    For more detailed information see:
    MS-DOS Device Driver Names Cannot be Used as File Names
    عثمان الشجاع
    عثمان الشجاع غير متواجد حالياً
    الصورة الرمزية عثمان الشجاع
    Lightbulb
    بسم الله الرحمن الرحيم:
    وفقكم الله لما يرضاه .
    http://www.shbab1.com/2minutes.htm
    أنا مسلم .................................................. أنا عربي.
    ادعُ لنا بالهداية وللمسلمين بالنصر .........والحمد لله رب العالمبن.
    م عامر
    م عامر غير متواجد حالياً
    مشرف الملتقى العام
    الصورة الرمزية م عامر
    Received: 184
    Given: 186
    الحقيقة أن ليس في الأمر معجزة ولاشيء من هذا القبيل بل هي كلمات محجوزة للنظام ولايمكن تسمية الملف بهذا الاسم
    وأعتقد أن الأخ طارق سليمان في مشاركته قد بين السبب ولكن بالانجليزية
    حيث أن هذا الاسم محجوز أو مخصص للنظام أو device name وهكذا لا يمكن تسمية أي ملف بنفس هذا الاسم
    وهنالك العديد من هذه الأسماء المحجوزة
    مثل:
    PRN
    AUX
    NUL
    LPT1
    COM1
    A number of others
    والأولى أختي الكريمة لو كان هذا الأمر له علاقة بالاسلام أو الاعجاز لما تمكن من تسمية الملف بإسم كن بالعربية وليس الانكليزية
    فما معنى con ...؟؟؟ وهل نفهم المعنى العربي للكلمة الانكليزية !!!!
    الحمد لله الذي أكرمنا بنعمة الإسلام
    {إِنَّ اللَّهَ وَمَلائِكَتَهُ يُصَلُّونَ عَلَى النَّبِيِّ يَا أَيُّهَا الَّذِينَ آمَنُوا صَلُّوا عَلَيْهِ وَسَلِّمُوا تَسْلِيمًا} (56) سورة الأحزاب
    أللهم ارزقنا نعمة الرضى واجمعنا مع الحبيب المصطفى في جنات العلى
    موقع الرسول الكريم صلى الله عليه وسلم
    بسمه العراقيه
    بسمه العراقيه غير متواجد حالياً
    الصورة الرمزية بسمه العراقيه
    اخوتي الاعزاء لكم جزيل الشكر على المرور والاهتمام
    بسمه العراقيه
    المهندس طارق سليمان :
    مشاركة اكثر من رائعه شكرا جزيلا على الرد المقنع معلومه جديدة علي انا شخصيا لانه الكومبيوتر مو تخصصي لكم جزييل الشكر والامتنان
    بسمه العراقيه
    م عامر لكم خالص شكري وامتناني على المرور والاهتمام
    مثل ما قلت معلومات قيمه قد تغيب عن كثير منا
    نورت الصفحة
    محمد شبانه
    محمد شبانه غير متواجد حالياً
    الصورة الرمزية محمد شبانه
    والله ما بعرف .. بس تسلم ايدك
    هو ضياء عيوني ...هو نبض قلبي ...هو مجرى الدم بعروقي ...هو حبيبي هو كل دنياي ....هو آخرتي ...هو حياتي ....هو حبيبي هو الكريم الذي أرجوه ...هو الغفور الذي أدعوه ....هو حبيبي هو من أطيعه ...هو من أعبده ...هو من أسجده له ...هو حبيبي هو الأول ...هو الآخر ...هو الظاهر ....هو الباطن ...هو حبيبي
    (هو ربي ورب العالمين)
    engr.amin
    engr.amin غير متواجد حالياً
    ابو اسامة63
    ابو اسامة63 غير متواجد حالياً
    Received: 49
    شكرا جزيلا للأخ طارق سليمان على التوضيح
    م وائل حسنى
    م وائل حسنى غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية م وائل حسنى
    فعلا شكرا جزيلا للاخ طارق سليمان للتوضيح
    إننا طلاب شهادة ... لسنا نحرص على هذه الحياة ... هذه الحياة تافهة رخيصة ... نحن نسعى إلى الحياة الأبدية .
    يا راحلين عن الحياة وساكنين بأضلعي .... هل تذكرون توجعي وتوجع الدنيا معي .
