Definitions of landmark
النتائج 1 إلى 5 من 5
    الصورة الرمزية عمر موقدي
    عمر موقدي
    عمر موقدي غير متواجد حالياً
    · the position of a prominent or well-known object in a particular landscape;
    · an event marking a unique or important historical change of course or one on which important developments depend; "the agreement was a watershed in the history of both nations"
    • a mark showing the boundary of a piece of land
    • an anatomical structure used as a point of origin in locating other anatomical structures (as in surgery) or as point from which measurements can be taken
    • Originally, a landmark literally meant a geographic feature, used by explorers and others to find their way back through an area on a return trip. In modern usage, it is anything that easily recognizable, such as a monument, building, or other structure.
    • A survey mark made on a 'permanent' feature of the land such as a tree, pile of stones, etc.
    • Monument of material mark or fixed object used to designate a land boundary on the ground: any prominent object on land that may be used to determine a location or a direction in navigation or surveying.
    • Any conspicuous object that helps establishes land boundaries.
    • A monument or structure of historic importance.
    • A specific location or identifiable natural or man-made geographic feature. Also referred to as a waypoint in GPS navigation.
    • An individually significant or individually designated historic site, building, structure or object (as opposed to a district).
    • A fixed object serving as a boundary mark for a tract of land, same as a monument.
    • A monument or object used to establish the boundary line of a property.
    المهندسة مي
    المهندسة مي غير متواجد حالياً
    مشكور والله على فتح هذا موضوع .. وأرجو تكملة تعريف باقي العناصر التي اتخذها kevin lynch في عمل الصورة الذهنية للمدينة ...........
    Eng.MTM
    rorowewe3
    rorowewe3 غير متواجد حالياً
    i am anew member in ur forum thanx 4 ur article.
    engmohamedhamdy
    engmohamedhamdy غير متواجد حالياً
    العلامات المميزه هي وسيله للوصول الى الرقي الحضاري والمعرفه والترسيخ للمعلومات والانشطه التاريخيه المختلفه والتي تساهم بدور كبير في توعيه الافراد بالمراحل التاريخيه والثقافيه للمدينه.
    احتاج الى معلومات عن اسس تصميم العلامات المميزه ( اللاند مارك) وامثله عليها....وشكرا
    engmohamedhamdy
    ابحث عن امثله واسس تصميم اللاند مارك ( العلامات المميزه ) في الميادين وامام المباني العامه والخاصه والمعبره عن طبيعه المكان وعن اسس تصميم هذه العلامات وجزاكم الله خيرا
