رسالة هامة جدا
النتائج 1 إلى 3 من 3
    AlgerinRefiner
    AlgerinRefiner غير متواجد حالياً
    رسالة هامة جدا
    HELLO Engineers
    please please please help me I need some search or graduation projects about " pinch technology, analysis, design "
    how can desing this problem with " pinch analysis "
    http://actamont.tuke.sk/pdf/2004/n3/26pozivil1.pdf
    The Problem Table -*-
    Composite Curves -*-
    The Grand Composite Curve-*-
    يا جماعة انا في حيرة من امري اقترب الوقت ولم اعمل شئ الرجاء المساعدة باي رسالة تتكلم على الموضوع نحن لم ندرس هذه التقنية في جامعتنا واستاذي المؤطر ليس عنده اي معلومة ونحن ندرس بالفرنسية ومذكرتي بالانجليزية
    راح اكون ممتن وشاكر لكل من يساعدني
    لا تخيبو ظني يا مهندسي العرب
    من مواضيع AlgerinRefiner :
    alshangiti
    alshangiti غير متواجد حالياً
    مشرف وإستشاري هندسة المناجم
    الصورة الرمزية alshangiti
    Received: 89
    Given: 8
    Pinch analysis is a methodology for minimising energy consumption of chemical processes by calculating thermodynamically feasible energy targets (or minimum energy consumption) and achieving them by optimising heat recovery systems, energy supply methods and process operating conditions. It is also known as process integration, heat integration, energy integration or pinch technology.
    The process data is represented as a set of energy flows, or streams, as a function of heat load (kW) against temperature (deg C). These data is combined for all the streams in the plant to give composite curves, one for all ‘hot streams’ (releasing heat) and one for all ‘cold streams’ (requiring heat). The point of closest approach between the hot and cold composite curves is the pinch temperature (pinch point or just pinch), and is where design is most constrained. Hence, by finding this point and starting design there, the energy targets can be achieved using heat exchangers to recover heat between hot and cold streams. In practice, during the pinch analysis, often cross-pinch exchanges of heat are found between a stream with its temperature above the pinch and one below the pinch. Removal of those exchanges by alternative matching make the process reach its energy target.
    The techniques were first developed in the late 1970’s by teams led by Bodo Linnhoff while he did his PhD under the supervision of Dr Flower at the university of Leeds. He moved to University of Manchester to continue the work. Many refinements have been developed since and used in a wide range of industries, including non-process situations. Both detailed and simplified (spreadsheet) programs are now available to calculate the energy targets. A commonly used, free Pinch analysis program is PinchLeni.
    In recent years, Pinch Analysis has been extended beyond energy applications. It now includes:
    Mass Exchange Networks (El-Halwagi and Manousiouthakis, 1989)
    Water Pinch (Wang and Smith, 1994; Hallale, 2002)
    Hydrogen Pinch (Hallale et al., 2003)
    [ References
    • El-Halwagi, M. M. and V. Manousiouthakis, 1989, "Synthesis of Mass Exchange Networks", AIChE J., 35(8), 1233-1244
    • Kemp, I.C. (2006). Pinch Analysis and Process Integration: A User Guide on Process Integration for the Efficient Use of Energy, 2nd edition. Includes spreadsheet software. Butterworth-Heinemann. ISBN 0750682604. (1st edition: Linnhoff et al, 1982).
    • Hallale, N. (2002). A New Graphical Targeting Method for Water Minimisation. Advances in Environmental Research. 6(3): 377-390
    • N.Hallale, I.Moore, D. Vauk, "Hydrogen optimization at minimal investment", Petroleum Technology Quarterly (PTQ), Spring (2003)
    • Wang, Y. P. and Smith, R. (1994). Wastewater Minimisation. Chemical
    • Engineering Science. 49: 981-1006
    http://www.cheresources.com/pinchtech3.shtml
    http://canmetenergy-canmetenergie.nr.../2003-140e.pdf
    المهندس / يحيى بن محمد الشنقيطى
    AlgerinRefiner
    شكرا اخي على المساعدة وعذرا لتاخري في الرد
    لن انسى مساعدتك
