plz help me in) sap2000 v11
النتائج 1 إلى 10 من 12
    الصورة الرمزية hassan awaden
    hassan awaden
    hassan awaden غير متواجد حالياً
    sap programme not give me acttual results
    ithink for reactins its ok
    but for beams it gives small moment
    and also for slab
    plz helb me
    anass81
    anass81 غير متواجد حالياً
    الصورة الرمزية anass81
    Received: 679
    Given: 724
    اقتباس المشاركة الأصلية كتبت بواسطة hassan awaden مشاهدة المشاركة
    and also for slab
    plz helb me
    افضل طريقة هي انك ترفق الملف, وبعدها نرى ما المشكلة
    hassan awaden
    its simble flat slab with marginal beam
    anass81
    Received: 679
    Given: 724
    Still, we need the file in order to know what went wrong
    hassan awaden
    ok till me plz how to attatch file
    anass81
    Received: 679
    Given: 724
    try this link
    http://www.arab-eng.org/vb/t132662.html
    إبراهيم أسامة
    الصورة الرمزية إبراهيم أسامة
    Received: 16
    Given: 3
    لو بتعمل set modifier متعملهاش وجرب كده وقلنا
    hassan awaden
    thats the file mr anass check for me plz
    hassan awaden
    slab 20 cm
    beam (20*60)
    d.l=1.50 t/m2
    l.l=0.25 t/m2
    wall load =0.345 t/m
    eng_batool
    eng_batool غير متواجد حالياً
    use a modifier factor
    You should use a modifier factor for slab and beams to get a suitable result
    The modifier factor changes in slab, beam and columns according to tha design procedure which you follow
    1- Using ACI
    If you need ultimate result (factored result) you should use the modifier for slabs =0.25 and for beams = 0.35 and for columns =0.7
    If you need working result you should use the modifier for slabs =0.5and for beams = 0.75 and for columns =1
    From ACI318M chapter 10 ( 10.10.4.1 )
    1- Using ECP
    If you need ultimate result (factored result) you should use the modifier for slabs =0.5 and for beams = 0.7 and for columns =1
