Modeling Software for Compressor Engineers
النتائج 1 إلى 3 من 3
    mehmetsa
    mehmetsa غير متواجد حالياً
    ACI's eRCM Modeling Software provides the perfect solution to model compressor performance curves.
    You simply specify the compressor's geometry (frame, cylinder, stage, throw, valving, etc.) via direct inputs or from our extensive database of OEM and legacy records and eRCM displays that unit's performance curves: Pressures vs. Load, Pressure vs. Flow, Pressure vs. Pressure and more, including graphs of net rod load forces and PV/PT cards.
    link
    http://www.aciservicesinc.com/ercm/A...or%20Model.msi
    http://www.aciservicesinc.com/software/ercm.htm
    mehmetsa
    م/وفاء
    م/وفاء غير متواجد حالياً
    Received: 13
    thank u very much for this soft ware
    mehmetsa
