Media Player Classic play most of all your favort media
مشاهدة نتائج الإستطلاع: do you like it ? if not please Specifiy
المصوتون
0. أنت لم تصوت في هذا الإستطلاع
  • did you have any problem with the player
    0 0%
  • if yes please tell me what it is
    0 0%
إستطلاع متعدد الإختيارات.
النتائج 1 إلى 2 من 2
    سجاد hger mood
    سجاد hger mood غير متواجد حالياً
    Media Player Classic looks just like Windows Media Player 6.4, but has many additional features. It has a built in DVD player with real-time zoom, support for AVI subtitles, QuickTime and RealVideo support (requires QuickTime and/or Real Player); built-in MPEG2/SVCD/DVD codec.
    It also supports SVCD/CVD selectable subtitles and lots more. The best part about Media Player Classic is the ability to modify the filters when playing your favorite video files.
    What is Media Player Classic - Home Cinema?
    It is a Media Player Classic mod designed for homecinema usage and released by Casimir666.
    Changes in Media Player Classic 6.4.9.1 [2008-11-15] :
    - MPC: some minor changes
    • Media Player Classic 6.4.9.1 [2008-10-05]
    - MPC: Save image/thumbnails now also supports PNG
    - MPC: Updated libpng to 1.2.32
    - MPC: Fixed playlist shuffle functionality
    Changes in Media Player Classic - Home Cinema 1.2.908 :
    - NEW: support Multi-Monitor configuration, select Monitor for full-screen playback
    - NEW: creation of minidump when mpc crash
    - NEW: Simplified Chinese & Traditional Chinese translations
    - NEW: Pixel shader to convert BT601 -> BT701 (request #1911511)
    - NEW: YV12 Chroma Upsampling pixel shader added (http://forum.doom9 .org/showthread.php?p=1184975#post1184975)
    - NEW: Recursively adding directories to the Playlist (feature request #2013805), add as New Menu item
    - NEW: Support for M2TS presentation graphics streams (only for EVR Custom and VMR9 Renderless)
    - NEW: Command lines "/startpos hh:mm:ss.ff", "/dvdpos title#chapter" and "/dvdpos title#hh:mm:ss.ff" to start playback to position
    - NEW: Differents icons for each format associated with mpc
    - NEW: support H264 and AAC in FLV splitter
    - CHANGED: Add VIRTKEY for "Save Thumbnails" (request #1964399)
    - CHANGED: Store the settings for the internal DXVA/FFmpeg decoders in a different value than the other internal decoders. This makes the settings better interchangeable with old MPC builds. Also gives more room in the bitvector for adding more (FFmpeg based) decoders in the future.
    - CHANGED: PAR correction option (for anamorphic video)in VSFilter and RealText support
    - CHANGED: liba52 & libdts library updated
    - CHANGED: x64 edition of MPCVideodec is now build using GCC/MingW64 (improve performances)
    - CHANGED: Gui option for Explorer Context menu->Files(see Formats Page)
    - CHANGED: Gui option for Explorer Context menu->Directory(see Formats Page)
    - CHANGED: Open directory(shell context menu or MPC-HC menu) - load only enqueue audio/video files, those with file extensions from the Formats page in MPC options
    - CHANGED: Replaced command line switches /unregvid and /unregaud with a new switch /unregall. That cleans up all file associations, including image/playlist formats.
    - CHANGED: Change in VideoDecoder Settings for rev.681(read AR from stream)
    - CHANGED: Open DVD detect and open Blu Ray main movie
    - CHANGED: Eac3 support in Mpeg splitter
    - CHANGED: Number of file and DVD position increase from 5 to 20 (req #1819709)
    - CHANGED: Bypass of UOPs for DVD (req #1811508). This feature didn't works for x64 build
    - CHANGED: LibPNG updated to release 1.2.32 (fix memory leaks)
    - FIXED: Chapter message improperly displayed in status bar (for file only)
    - FIXED: Crash with CoreAVC when changing "prefered decoder" setting during playback
    - FIXED: Missing checkmarks on "tearing test" and "display stats" options (bug #2010857)
    - FIXED: Save image/thumbnail not working with EVR (bug #2010681)
    - FIXED: Workaround to prevent GraphEdit crash when MpcVideoDec.ax was registered (when opening menu "Graph/Insert filter/Direct show filters")
    - FIXED: Fix rare seeking issue with VobSubs in VSFilter
    - FIXED: Subtitle style not save in settings.
    - FIXED: random freeze when using mpc-hc, vsfilter and Haali renderer at the same time
    - FIXED: shortcuts with MEDIA_PLAY, MEDIA_PAUSE not working with some remote control
    - FIXED: shortcuts label in "Option / Key" dialog box is now localized
    - FIXED: MPC-HC file association cleanup bug (rev.731), these commands are not working: mplayerc /unregvid, mplayerc /unregaud
    - FIXED: Freeze when play Mpeg2 or XVid file
    - FIXED: Remember position not working with some DVDs
    - FIXED: DXVA decoder now support H264 interlaced video
    - FIXED: Crash/black screen with DXVA decoder with some ATI cards
    - FIXED: Incorrect aspect ratio with some H264 files (extended SAR)
    to download
    http://www.free-codecs.com/Media_Pla...c_download.htm
    من مواضيع سجاد hger mood :
    السلطان2
    السلطان2 غير متواجد حالياً
    شكرررررررررررررررا
