كتاب مهم للمهندس الكيميائي Rules of Thumb for Chemical Engineers
النتائج 1 إلى 10 من 11
    مهندس المحبة
    مهندس المحبة غير متواجد حالياً
    Received: 157
    Rules of Thumb for Chemical Engineers, Third Edition (Rules of Thumb for Chemical Engineers)
    By Carl R. Branan
    Publisher: Gulf Professional Publishing
    Number Of Pages: 426
    Publication Date: 2002-10-11
    ISBN-10 / ASIN: 0750675675
    ISBN-13 / EAN: 9780750675673
    The most complete guide of its kind, this is the standard handbook for chemical and process engineers. All new material on fluid flow, long pipe, fractionators, separators and accumulators, cooling towers, gas treating, blending, troubleshooting field cases, gas solubility, and density of irregular solids. This substantial addition of material will also include conversion tables and a new appendix, "Shortcut Equipment Design Methods."
    This convenient volume helps solve field engineering problems with its hundreds of common sense techniques, shortcuts, and calculations. Here, in a compact, easy-to-use format, are practical tips, handy formulas, correlations, curves, charts, tables, and shortcut methods that will save engineers valuable time and effort. Hundreds of common sense techniques and calculations help users quickly and accurately solve day-to-day design, operations, and equipment problems.
    * The standard handbook for chemical and process engineers
    * All new material on fluid flow, long pipe, fractionators, separators and accumulators, cooling towers, gas treating, blending, troubleshooting field cases, gas solubility, and density of irregular solids
    * Hundreds of common sense techniques, shortcuts, and calculations
    Summary: Any practicing Chemical Engineer must have this book
    Rating: 5
    This book is a work horse. It is extremly practical and to the point. Important concepts and design equations are laid out in a concise and easy to read format. This book noteworthy for the depth of the material covered and the incredibly succint delivery of that information.
    Summary: Useful but read the fine print
    Rating: 5
    This reference is highly useful for consulting work. It has its limits. A true rule-of-thumb book for chemical engineers would require volumes so I would say the author did well, hence the 5 stars. A good example of the limits of this book are what he does with knock-out pots. He limits his presentation to reflux drums instead of expanding his study to KO pots in general. The section on reflux drums is difficult to use because the tables presented for liquid holding times is difficult to understand, let alone use. The reader would be tempted to use this method for KO pots unless he sees the fine print in the corner of the page. Look for these caveates.
    The index is good, which is critical for such a reference. If I had a choice between buying Hicks or Branan, it would be a hard choice. I would probably advise the cheaper book, Branan. Besides, Hicks, "Standard Handbook of Engineering Calculations," covers a broad range of engineering calculations. Branan is more focused on chemical engineering. It is unfortunate that it is not expanded to cover more of the field.
    If this review was helpful, please add your vote.
    Summary: Question about Units used (US and Metric?)
    Rating: 3
    Hi
    I do not have a copy of the current edition, but a year ago I investigated purchasing a previous edition. What deterred me at the time was that all tips, tricks and equations etc. were in US units and thus only of very limited appeal to the Metric world.
    A question to a reviewer of the 4th edition - has the book become "international", i.e. quoting metric and US units? If not, it shall remain of limited desirability in the free world.
    Roland
    Summary: From an Industrial Practitioner - This is an Excellent Quick Reference
    Rating: 5
    This book is an excellent and priceless reference on Process Equipment Fundamentals and Quick Calculations for any engineer or practitioner working in the process industries. I am an Electronic Engineer, but I have been working for the last 16 years as an Instrumentation, Automation and Process Control Engineer for the Oil & Gas Industry. As a result I have been involved with Chemical Engineering issues in a day to day basic.
    I have found this book to be an excellent tool aid to analyze operational problems that affect process performance.
    Chemical engineers working in operations and design for the process industries will find this book most useful.
    Summary: A MUST HAVE books for Chemical Engineers
    Rating: 5
    This is one of the few MUST HAVE books for Chemical Engineers doing process engineering. When I travel (for work) I always take "Transport Phenomena" (aka BSL), The GPA Databook and "Rules of Thumb for Chemical Engineers". Rules of Thumb... is a great reference for process design and trouble shooting field problems.
    A Practical Tip: The best thing to do with "Rules of Thumb for Chemical Engineers" is to carefuly remove the binding and put it into a 3-hole notebook (e.g., the GPA databook) and then file all the classic process design articles with the appropriate chapters
    أرجو الرد والتقييم ولاتنسونا من خالص الدعاء ............[/CENTER]
    ميس الحلوة
    ميس الحلوة غير متواجد حالياً
    الصورة الرمزية ميس الحلوة
    شكرا على الكتاب الرائع ..........
    مهندس المحبة
    Received: 157
    شكرا على المرور ........
    بلاد العرب اوطاني
    بلاد العرب اوطاني غير متواجد حالياً
    الصورة الرمزية بلاد العرب اوطاني
    Received: 8
    Given: 5
    شكرا على الكتاب وجزاكم الله خيرا
    مهندس المحبة
    Received: 157
    كل الهلا ومنور الموضوع ..........
    thebest2007
    thebest2007 غير متواجد حالياً
    Smile thanks
    thanks a lot
    husam475
    husam475 غير متواجد حالياً
    ألف شكر على المجهود
    مهندس المحبة
    Received: 157
    منورين ............
    khalid elnaji
    khalid elnaji غير متواجد حالياً
    الصورة الرمزية khalid elnaji
    شكرا" و اتمني لك التوفيق والسداد
    مهندس المحبة
    Received: 157
    منور أخي العزيز ..........
