من يعرف( خلية تحليل) يجاوب
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 16 من 16
    جاسم العجيلي
    جاسم العجيلي غير متواجد حالياً
    الصورة الرمزية جاسم العجيلي
    dear
    in another expression we use 2.69kw to produce 1 m^3 of hydrogen
    but using of 1 m^3 of hydrogen will produce only 3.54 kw for one one hour duration
    with the best
    alsane
    alsane غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة جاسم العجيلي مشاهدة المشاركة
    with a great appreciation
    so if you don't mind to add :
    1joul =1 watt *1 sec
    12753.96kj =12753.96 kw *1sec
    this means that
    we may produce this value of energy
    by using such gas within one second
    3.54 kw per one hour
    for demotic voltage (220 v) this power provide 16 amp.
    as i think
    am I right
    left
    1m^3 of H2 with O2 gas produce 3.54 kw as heat not electrical energy
    The Gibbs free energy of 237.1 kJ/mol of H2
    the enthalpy ΔH = -285.83 kJ
    237.1/285.8 x100% = 83%
    the fuel energy is converted to electrical energy at an efficiency 83% not more than that .
    thats mean 1m^3 of hydrogen will produce less energy than we used to produce it
    ΔG = ΔH - TΔS
    -285.83 kJ + 48.7 kJ = -237.1 kJ
    the lost will be TΔS = 48.7kj
    actually we need 3.65 kw to produce 1m^3 H2 -this value change with temperature and pressure -(the value 2.69 mistake in the calculation) and 1m^3 H2 will produce 3.02kw at 83% in the full cell .
    usually the full cells efficiency between 60%to 70%
    سأثأر ولكن لرب ودين***وأمضي على سنتي في يقين
    فإما إلى النصر فوق الأنام*** وإما إلى الله في الخالدين
    جاسم العجيلي
    so grateful
    i do appreciate your accuracy
    what is the most convenient and economic method to produce this gas for this mass consumption
    alsane
    dear brother
    the cheapest way to produce this gas by using stainless steel 316
    and you will get good results,the minimum voltage to produce the gas 1.23V so the voltage must higher than this value (and apply this value to each cell)
    the high voltage and amps cause heating the wires , water and reduce the efficiency of the cells
    you can use KOH to increase the water conductivity not more than 30% depending on the space between cells .
    dear brother before producing H2 gas you have to know about hazards
    ,this gas dangerous can explosion with O2 or air at such percent ,never produce H2 with O2 together as we seen in many video's in internet ,use separator between the plates so will have pure H 2
    اسلام البدوي
    اسلام البدوي غير متواجد حالياً
    الصورة الرمزية اسلام البدوي
    ياأخى الكريم لتسهيل تحويل الوحدات لديك إليك هذا البرنامج
    http://www.megaupload.com/?d=C7J9S47V
    jehad_15568
    jehad_15568 غير متواجد حالياً
    thank you for this informations
