رجاء من الاخوة الافاضل جدول لاجهادات مواسير الجلفنايز
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 13 من 13
    engausma
    engausma غير متواجد حالياً
    and if the there any steel member of trusses failed in stress capacity
    check you can whatever you like depth of trusses or diameter of pipe or thickness of pipe
    م/الحملى
    engausma
    also you should have vertical member of truss over column (the bottom cohrd )should not be transfer it is load directaily to the column
    م/الحملى
    engausma
    and make calculatin for lateral torisonal buikling for purlin and it is better to provide lateral support and the middle of the span 7 m and it is alwyaes be rod with diamiter 25
    م/الحملى
