need heat capacity for liquid propane
النتائج 1 إلى 6 من 6
    بو يعقوب
    بو يعقوب غير متواجد حالياً
    I need the heat capacity for liquid propane as in this form
    Cp = A + BT + CT^2 + DT^3 + ET^4
    where T is the temperature in kelvin
    and Cp is in J/kmol.K
    any one can help??
    alsane
    alsane غير متواجد حالياً
    Heat Capacity for propane
    Cp/R=A+BT+CT^2+DT^-2+ET^3........with T in (K).....this data only for propane
    Tmin 298k and T max1500k
    A=1.213
    B=28.785*10^3
    C=-8.824*106
    D=0
    E=0
    source:introduction to chemical engineering thermodynamic ,5th edition,J.M .Smith
    بو يعقوب
    thanks brother
    but the data you gave me is for propane in gas phase
    i need heat capacity for propane in liquid phase
    alsane
    alsalam alikom
    you can find data ((( between 85.47 k to 360 k , this will cover liquid and gas phase))) to calculate CP in perry,s hand book at page 2-174
    but you use different equation .
    http://www.4shared.com/network/searc...h&searchmode=2
    بو يعقوب
    i know that equation my brother
    is there a way to convert it to this form
    because i need to calculate the temperature of a stream that contain propane and other components
    the heat capacities of all the other components are in this form
    so i need Cp of liquid propane to be in the same form
    alsane
    اقتباس المشاركة الأصلية كتبت بواسطة بو يعقوب مشاهدة المشاركة
    they are different equations and different parameters ,because you dont know the temperature its difficult to solve it .
    these books has the data you looking for , search them in your library
    1-
    Solid and liquid heat capacity data collection
    C₁-C₃₃ compounds
    volume 4
    ISBN 10: 3926959819
    2-Thermophysical Properties of Matter
    see this web may help you
    http://webbook.nist.gov/chemistry/fluid/
    سأثأر ولكن لرب ودين***وأمضي على سنتي في يقين
    فإما إلى النصر فوق الأنام*** وإما إلى الله في الخالدين
