For soil experts
النتائج 1 إلى 3 من 3
    ابو نديم
    ابو نديم غير متواجد حالياً
    إسلام علي
    إسلام علي غير متواجد حالياً
    الصورة الرمزية إسلام علي
    Received: 1,093
    Given: 2,479
    False; the liquid limit will decrease
    والله أعلم
    Liquid Limit (LL) is defined as the moisture ******* at which soil begins to behave as a liquid material and begins to flow
    (Liquid limit of a fine-grained soil gives the moisture ******* at which the shear strength of the soil is approximately 2.5kN/m2)
    In the lab, the LL is defined as the moisture ******* (%) required to close a 2-mm wide groove in a soil pat a distance of 0.5 in along the bottom of the groove after 25 blows
    م عبد الحكيم مواس
    م عبد الحكيم مواس غير متواجد حالياً
    الصورة الرمزية م عبد الحكيم مواس
    Received: 269
    Given: 472
    dear Colleque what Mr.Bisher said correct that main the imprtant factor is
    the moisture , any the fine soil will be sensitive for the moisture if present ,
    i inferred that if the water table or the soil is wety the LL probably will be high
    but you have to cinsult the Geotechnical lab.
    regards
