Troubleshooting Basic Electrical Circuits Desciption: برنامج لمحاكاة الدوائر الكهربا
النتائج 1 إلى 10 من 17
    الصورة الرمزية القبطان علي
    القبطان علي
    القبطان علي غير متواجد حالياً
    Received: 34
    Given: 18
    هذا البرنامج لمحاكاة الدوائر الكهربائية وكشف الاخطاء وحلها
    صورة البرنامج
    This award-winning, electrical training program builds on the Basic Techniques program. Here, you will troubleshoot a a basic lighting circuit, switches and lights. You will need to use elementary wiring and connection wiring diagrams to troubleshoot 28 faults of varying difficulty. The program contains sections to describe how the circuit works as well as how to use the troubleshooting tools. The program evaluates the time and money spent to solve the fault and records all the steps performed to solve the fault. This can be used for later analysis of your troubleshooting approach. Safely Learn to Troubleshoot Basic Electrical Circuit, Highly Realistic Simulation of lighting Circuit, Practical Hands-On Approach with 28 Fault to solve, Use an Expert's experience to improve your troubleshooting approach, Assesses the User's Troubleshooting Skill, Tracks and Records Every Step Taken While Troubleshooting, Highly realistic simulation - The simulation behaves as the real circuit would. You can remove wires, operate any controls, and the circuit will behave appropriately. This is a true simulation. Realistic Tools. While using Troubleshooting - Basic Electrical Circuits you are able to perform virtually every operation used on real equipment including: operating the circuit, locking out the circuit, taking voltage and resistance readings, opening connections, replacing components and wiring, using the observe feature you can even check for visual or other clues to the cause of the fault, A fully simulated lighting circuit is available to practice your troubleshooting skills. Schematics and wiring diagrams can be viewed on screen or printed out to help you understand the circuit and eventually track down problem areas to solve faults. A section is included to guide you through the troubleshooting process using three sample faults. Twenty-eight faults are available to solve License: Freeware | Price: $0.00 | Size: 19.8 MB | Downloads (1731)
    Platform: Windows XP, Windows 2000, Windows 2003 , Windows Vista
    Term: Able - Electrical Circuits - Lighting - Electrical - Approach - Circuit - Lighting Circuit - Basic Electrical Circuits - Basic - Solve Fault - Basic Electrical Wiring - Electrical Wiring How To - Electrical Wiring - Home Electrical Wiring - Electrical Symbols - Electrical Enclosures - Electrical Safety - Electrical Supply - Electrical Supplies - Electrical Wire
    Troubleshooting Basic Electrical Circuits Copyright notice:
    Pirated Software Hurts Software Developers. Using Troubleshooting Basic Electrical Circuits Free Download crack, warez, password, serial numbers, torrent, keygen, registration codes, key generators is illegal and your business could subject you to lawsuits and leave your operating systems without patches. We do not host any torrent files or links of Troubleshooting Basic Electrical Circuits from depositfiles.com, rapidshare.com, megaupload.com etc. All download links are direct full download from publisher sites or their selected mirrors. Avoid: oem software, old version, warez, serial, torrent, keygen, crack of Troubleshooting Basic Electrical Circuits. Consider: Troubleshooting Basic Electrical Circuits full version, full download, premium download, licensed copy.
    ولمزيد من المعلومات او التحميل اليكم هذا الرابط
    http://www.filebuzz.com/fileinfo/474..._Circuits.html
    محمد حسيين
    محمد حسيين غير متواجد حالياً
    الصورة الرمزية محمد حسيين
    Received: 24
    شكـــــرا لك أخــــــــــــــــــي القبـطـــــــــــــــــــــــــــــــــــــــان
    محمد حسيين
    Received: 24
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    ممتاز كعادتك
    http://carsnology.blogspot.com
    fares61
    fares61 غير متواجد حالياً
    شـــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــــــكـــــرا لك
    كتوموتو
    كتوموتو غير متواجد حالياً
    شكر.........................
    eleman
    eleman غير متواجد حالياً
    شكرا ولكن الينك يعطى شرح فقط
    moh297
    moh297 غير متواجد حالياً
    الصورة الرمزية moh297
    جزاك اللة خيرا كثير وبارك لك
    عبد المعزمحمد
    عبد المعزمحمد غير متواجد حالياً
    الصورة الرمزية عبد المعزمحمد
    ولا عيب فى معروفهم غير انه يظهر عجز شكر الشاكرين
    emadahmed40
    emadahmed40 غير متواجد حالياً
    الدنيا كلما كست اوكست وكلما اينعت نعت
    وكلما جلت اوجلت وكلماحلت اوحلت
    وكم من صحيح ماتمن غير علة وكم من مريض عاش حين من الدهر
    وكم من ملك خضعت له علامات فلماعلا مات
    قبورنا تبنى وما تبنا ليتنا تبنا قبل ان تبنى
    أحسن إلى الناس تستعبد قلوبهم فطالما استعبد الإنسانَ إحسانُ
    أحسن إذا ما كان إمكان ومقدرة فلن يدوم على الإنسان إمكان
    تواضع تكن كالنجم لاح لناظر على صفحات الماء وهو رفيع
    ولا تك كالدخان يعلو بنفسه على طبقـــات الجو وهو وضيــع
    لا يفوح العطر حتى يسحق، ولا يضوَّع العود حتىيُحرق
    وكذلك الشدائد لك هي خير ونعمة
    . إصبر على كيد الحسود فإن صبرك قاتله
    النار تأكل بعضها إن لم تجد ماتأكله
    تموتُ الأَسْدُ في الغابات جوعا ولحم الضأن تأكله الكلاب
    احذر عدوك مرة واحذر صديقك الف مرة
    ف لربما انقلب عليك وهو اعلم بالمضرة
    لن أسقط من أعين الناس لأبرهن للبعض جاذبيتي فلست تفاحة نيوتن التي تهاوت من الأعلى لتمنح غيرها شرف الإكتشاف
