Autodesk AutoCAD Map 3D 2010 - NoPE x32 الاختصاصي بنظم المعلومات الجغرافية GIS
النتائج 1 إلى 10 من 14
    الصورة الرمزية abdolkadr
    abdolkadr
    abdolkadr غير متواجد حالياً
    Received: 22
    Given: 26
    Autodesk AutoCAD Map 3D 2010 - NoPE [x32]
    للتحميل
    http://www.megaupload.com/?d=CR28K5K0
    http://www.megaupload.com/?d=KZED3NB2
    http://www.megaupload.com/?d=Q0Q4R1E8
    http://www.megaupload.com/?d=JF47P0YL
    http://www.megaupload.com/?d=C7NXTACI
    http://www.megaupload.com/?d=Q51O9JIS
    http://www.megaupload.com/?d=LMJXJ32J
    http://www.megaupload.com/?d=2HXCQ8KP
    http://www.megaupload.com/?d=AK9FESI0
    http://www.megaupload.com/?d=LSHNGOXO
    http://www.megaupload.com/?d=MNCY91ZB
    http://www.megaupload.com/?d=EOMZGJDR
    http://www.megaupload.com/?d=VHBLMEG9
    http://www.megaupload.com/?d=R8ELGNSX
    http://www.megaupload.com/?d=KNKJCTEF
    http://www.megaupload.com/?d=O4641VNY
    http://www.megaupload.com/?d=RG5PYLRO
    او
    http://rapidshare.com/files/219113506/nm32k10_www.dl4all.com.part01.rar
    http://rapidshare.com/files/219109869/nm32k10_www.dl4all.com.part02.rar
    http://rapidshare.com/files/219109246/nm32k10_www.dl4all.com.part03.rar
    http://rapidshare.com/files/219109301/nm32k10_www.dl4all.com.part04.rar
    http://rapidshare.com/files/219109340/nm32k10_www.dl4all.com.part05.rar
    http://rapidshare.com/files/219109491/nm32k10_www.dl4all.com.part06.rar
    http://rapidshare.com/files/219109436/nm32k10_www.dl4all.com.part07.rar
    http://rapidshare.com/files/219113738/nm32k10_www.dl4all.com.part08.rar
    http://rapidshare.com/files/219109679/nm32k10_www.dl4all.com.part09.rar
    http://rapidshare.com/files/219111271/nm32k10_www.dl4all.com.part10.rar
    http://rapidshare.com/files/219109722/nm32k10_www.dl4all.com.part11.rar
    http://rapidshare.com/files/219109629/nm32k10_www.dl4all.com.part12.rar
    http://rapidshare.com/files/219109610/nm32k10_www.dl4all.com.part13.rar
    http://rapidshare.com/files/219111932/nm32k10_www.dl4all.com.part14.rar
    http://rapidshare.com/files/219109905/nm32k10_www.dl4all.com.part15.rar
    http://rapidshare.com/files/219110049/nm32k10_www.dl4all.com.part16.rar
    http://rapidshare.com/files/219109455/nm32k10_www.dl4all.com.part17.rar
    أبوالمعتز
    أبوالمعتز غير متواجد حالياً
    Received: 9
    أشكرك أخي العزيز ولكن قد قمت بتحميل هذا البرنامج وبعد التعب في التحميل لم أجد الكراك الخاص به
    أكون شاكر لك إذا معك الكراك ترفعه لي
    جزيت خيرا
    لا إله إلا الله
    عدد ما كان وعدد ما يكون
    وعدد الحركات والسكون
    abdolkadr
    Received: 22
    Given: 26
    اخي العزيز الكراك موجود مع الملفات اكيد
    وهذه طريقة التفعيل
    iNSTALLATION:
    1. extract — burn — mount
    2. install (use the serial-000-00000000)
    3. replace original .dll with the cracked one from NoPE dir
    4. Enjoy!
    اذا كنت حملت كل الملفات بشكل كامل فالكراك موجود ظمنها
    abdolkadr
    Received: 22
    Given: 26
    وهذه طريقة التفعيل
    iNSTALLATION:
    4. Enjoy!
    abdolkadr
    Received: 22
    Given: 26
    الكراك
    الكراك موجود مع الملفات ومع ذلك جرب هذا الكراك
    بعد فك الضغط ونسخ البرنامج على سيدي او دي في دي
    عندما يطلب السريال نمبر ادخل 000-00000000 اصفار
    بعد التنزيل انسخ هذا الكراك والصقك في ملفات البرنامج على السي بعد التنزيل
    الكراك في المرفقات طبعا الكراك مضغوط يجب فك الضغط
    انشاء الله جهد ما بضيع
    أبوالمعتز
    Received: 9
    أشكرك أخي العزيز وجاري التجربه
    بارك الله فيك
    لا إله إلا الله
    shereo
    shereo غير متواجد حالياً
    أشكرك أخي العزيز تم تحميل البرنامج
    جزاك الله خيرا
    لو ممكن شرح بسيط عن امكانيات عمل البرنامج
    hosamranjous
    hosamranjous غير متواجد حالياً
    أرجو مساعدتي في تقديم شرح مفصل عن ال civil design وخصوصا عن القائمة sheet maneger
    ولكم فائق الشكر والاحترام
    abdulhakimalsamil
    abdulhakimalsamil غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووووووووووووووووووو ووووووووووووووووووووووووووووووور
    abdulhakimalsamil
    Build date: 19/04/2008
    Program name: Keygen for ALL Autodesk products v2010 x86+x64
    Protection type: serial, activation
    Cracker's names: x-force
    Instructions: Unrar. Install Autodesk product v2010.Use one
    of this serials:
    666-69696969
    667-98989898
    400-45454545
    Use as Product Key: 495B1
    Finish the installation & restart the app.
    Choose to Activate. Once at the activation
    screen appeared start XFORCE Keygen 32bits or
    64bits version. Click on Mem Patch (you should
    see succeeded). Copy the request code into the
    keygen and press generate. Now copy the
    activation code back to the activation screen
    and click Next. You have a fully registered
    Autodesk product!!!
    Note: if you want to install 32bits version of
    the Autodesk 2010 product in a 64bits OS, you
    need to use the 32bits XFORCE keygen to activate
    it.
    البرنامج شغال 100 %
    حيث بعد تحميل جميع الملفات المضغوطة نقوم بالضغط على الأول فيفك ضغط جميع الملفات ليغطينا ملف واحد بشكل سيدي عند الضغط عليه يقوم بتشغيل برنامج النسخ مثل النيرو مثلاً لنسخ البرنامج على سيدي dvd وبعد نسخ السيدي نقوم نسخ البرنامج من السيدي إلى الجهاز ومن ثم نقوم بتنزيل البرنامج من على الجهاز لأنه من السيدي لا يكمل التنزيل بل يطلب السيدي
    وعند التنزيل يجب الانتباه إلى
    تنزيل الكيجين من الرابط http://www.damasgate.com/vb/t140309/
    وعند بداية التنزيل نختار:
    السيريال:
    666-69696969
    667-98989898
    400-45454545
    و Product Key: 495B1
    وبعد انتهاء التنزيل نختار الكيجين للتفعيل
