كلتش المروحة للردياتير
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 19 من 19
    م.محمود جمال
    الصورة الرمزية م.محمود جمال
    م.محمود جمال
    م.محمود جمال
    fan clutch is a thermostatically-controlled device that exists as an integral component of the automotive cooling system. When the engine is cool or even at normal operating temperature, the fan clutch partially disengages the engine's mechanically-driven radiator cooling fan, generally located at the front of the water pump and driven by a belt and pulley connected to the engine's crankshaft. This saves power since the engine does not have to fully drive the fan.
    However, if engine temperature rises above the clutch's engagement temperature setting, the fan becomes fully engaged, thus drawing a higher volume of ambient air through the vehicle's radiator which in turn serves to maintain or lower the engine coolant temperature to an acceptable level.
    Most fan clutches are viscous or "fluid" couplings combined with a bi-metallic sensory system similar to that in a thermostat.
    Normally fan clutches are fairly reliable, but sometimes they fail. A common symptom of fan clutch failure is overheating at idle or in heavy traffic. Bad fan clutches can also cause poor performance of the car's air conditioning system because the fan also cools the air conditioner's condenser, which is directly in front of the radiator.
    Another potential symptom of fan clutch failure (always drawing air at a high rate) in a cold weather climate is that the heating system blows lukewarm air never delivering sufficient hot air.
    نور الزمان1
    نور الزمان1 غير متواجد حالياً
    الله يعطيك العافيه شرح جميل وبناء
    ahmedzhelmy
    ahmedzhelmy غير متواجد حالياً
    الصورة الرمزية ahmedzhelmy
    Received: 20
    شكرا يا باشمهندس محمود ، ولكن لي رجاء .. وهو كتابة المصلحات باللغة العربية .. فمثلا ريدياتير .. المعنى باللغة العربية مبرد ، وكلمة كلتش .. قابض ، وكلمة spring معناها باللغة العربية نابض .. فيكتب مثلا نابض لولبي ـ نابض ورقي ـ نابض مخروطي ........ وهكذا .. وهذا لا يخفض من قيمة الموضوع .. فالموضوع ممتاز وبارك الله فيك.
    مع تحياتي
    د.أحمد زكي حلمي
    م.محمود جمال
    thankssssssssssssssssssssssssssssssssss
    lameey
    lameey غير متواجد حالياً
    thhaaaaaaaaaaaaaaaaaaaaaanks
    م / وائل احمد
    م / وائل احمد غير متواجد حالياً
    اللهم أغفر لة و لوالدية
    اللهم عافهم وأعف عنهم
    اللهم امين
    black88star
    black88star غير متواجد حالياً
    الصورة الرمزية black88star
    مشــــــــــــــــكور يديك الف عافية
    عــــــــــــوآفي
    اللـــــــــــــــــــــــــــهمَ زدني علـــــــــــــــــــــــــــــماَ
