Modern Wind-power Technology
النتائج 1 إلى 2 من 2
    mahmoodbtb
    mahmoodbtb غير متواجد حالياً
    When you talk about modern wind turbines, you're looking at two primary designs: horizontal-axis and vertical-axis. Vertical-axis wind turbines (VAWTs) are pretty rare. The only one currently in commercial production is the Darrieus turbine, which looks kind of like an egg beater.
    Vertical-axis wind turbines (left: Darrieus turbine)
    In a VAWT, the shaft is mounted on a vertical axis, perpendicular to the ground. VAWTs are always aligned with the wind, unlike their horizontal-axis counterparts, so there's no adjustment necessary when the wind direction changes; but a VAWT can't start moving all by itself -- it needs a boost from its electrical system to get started. Instead of a tower, it typically uses guy wires for support, so the rotor elevation is lower. Lower elevation means slower wind due to ground interference, so VAWTs are generally less efficient than HAWTs. On the upside, all equipment is at ground level for easy installation and servicing; but that means a larger footprint for the turbine, which is a big negative in farming areas.
    Darrieus-design VAWT
    VAWTs may be used for small-scale turbines and for pumping water in rural areas, but all commercially produced, utility-scale wind turbines are horizontal-axis wind turbines (HAWTs).
    Wind farm in California
    As implied by the name, the HAWT shaft is mounted horizontally, parallel to the ground. HAWTs need to constantly align themselves with the wind using a yaw-adjustment mechanism. The yaw system typically consists of electric motors and gearboxes that move the entire rotor left or right in small increments. The turbine's electronic controller reads the position of a wind vane device (either mechanical or electronic) and adjusts the position of the rotor to capture the most wind energy available. HAWTs use a tower to lift the turbine components to an optimum elevation for wind speed (and so the blades can clear the ground) and take up very little ground space since almost all of the components are up to 260 feet (80 meters) in the air.
    Large HAWT components:
    · rotor blades - capture wind's energy and convert it to rotational energy of shaft
    · shaft - transfers rotational energy into generator
    · nacelle - casing that holds:
    · gearbox - increases speed of shaft between rotor hub and generator
    · generator - uses rotational energy of shaft to generate electricity using electromagnetism
    · electronic control unit (not shown) - monitors system, shuts down turbine in case of malfunction and controls yaw mechanism
    · yaw controller (not shown) - moves rotor to align with direction of wind
    · brakes - stop rotation of shaft in case of power overload or system failure
    · tower - supports rotor and nacelle and lifts entire setup to higher elevation where blades can safely clear the ground
    · electrical equipment - carries electricity from generator down through tower and controls many safety elements of turbine
    From start to finish, the process of generating electricity from wind -- and delivering that electricity to people who need it -- looks something like this:
    Unlike the old-fashioned Dutch windmill design, which relied mostly on the wind's force to push the blades into motion, modern turbines use more sophisticated aerodynamic principles to capture the wind's energy most effectively. The two primary aerodynamic forces at work in wind-turbine rotors are lift, which acts perpendicular to the direction of wind flow; and drag, which acts parallel to the direction of wind flow.
    Turbine blades are shaped a lot like airplane wings -- they use an airfoil design. In an airfoil, one surface of the blade is somewhat rounded, while the other is relatively flat. Lift is a pretty complex phenomenon and may in fact require a Ph.D. in math or physics to fully grasp. But in one simplified explanation of lift, when wind travels over the rounded, downwind face of the blade, it has to move faster to reach the end of the blade in time to meet the wind travelling over the flat, upwind face of the blade (facing the direction from which the wind is blowing). Since faster moving air tends to rise in the atmosphere, the downwind, curved surface ends up with a low-pressure pocket just above it. The low-pressure area sucks the blade in the downwind direction, an effect known as "lift." On the upwind side of the blade, the wind is moving slower and creating an area of higher pressure that pushes on the blade, trying to slow it down. Like in the design of an airplane wing, a high lift-to-drag ratio is essential in designing an efficient turbine blade. Turbine blades are twisted so they can always present an angle that takes advantage of the ideal lift-to-drag force ratio. See How Airplanes Work to learn more about lift, drag and the aerodynamics of an airfoil.
    Aerodynamics is not the only design consideration at play in creating an effective wind turbine. Size matters -- the longer the turbine blades (and therefore the greater the diameter of the rotor), the more energy a turbine can capture from the wind and the greater the electricity-generating capacity. Generally speaking, doubling the rotor diameter produces a four-fold increase in energy output. In some cases, however, in a lower-wind-speed area, a smaller-diameter rotor can end up producing more energy than a larger rotor because with a smaller setup, it takes less wind power to spin the smaller generator, so the turbine can be running at full capacity almost all the time. Tower height is a major factor in production capacity, as well. The higher the turbine, the more energy it can capture because wind speeds increase with elevation increase -- ground friction and ground-level objects interrupt the flow of the wind. Scientists estimate a 12 percent increase in wind speed with each doubling of elevation.
    To calculate the amount of power a turbine can actually generate from the wind, you need to know the wind speed at the turbine site and the turbine power rating. Most large turbines produce their maximum power at wind speeds around 15 meters per second (33 mph). Considering steady wind speeds, it's the diameter of the rotor that determines how much energy a turbine can generate. Keep in mind that as a rotor diameter increases, the height of the tower increases as well, which means more access to faster winds.
    Rotor Size and Maximum Power Output
    Rotor Diameter (meters)
    Power Output (kW)
    10
    25
    17
    100
    27
    225
    33
    300
    40
    500
    44
    600
    48
    750
    54
    1000
    64
    1500
    72
    2000
    80
    2500
    Sources: Danish Wind Industry Association, American Wind Energy Association
    At 33 mph, most large turbines generate their rated power capacity, and at 45 mph (20 meters per second), most large turbines shut down. There are a number of safety systems that can turn off a turbine if wind speeds threaten the structure, including a remarkably simple vibration sensor used in some turbines that basically consists of a metal ball attached to a chain, poised on a tiny pedestal. If the turbine starts vibrating above a certain threshold, the ball falls off the pedestal, pulling on the chain and triggering a shut down.
    Probably the most commonly activated safety system in a turbine is the "braking" system, which is triggered by above-threshold wind speeds. These setups use a power-control system that essentially hits the brakes when wind speeds get too high and then "release the brakes" when the wind is back below 45 mph. Modern large-turbine designs use several different types of braking systems:
    · Pitch control - The turbine's electronic controller monitors the turbine's power output. At wind speeds over 45 mph, the power output will be too high, at which point the controller tells the blades to alter their pitch so that they become unaligned with the wind. This slows the blades' rotation. Pitch-controlled systems require the blades' mounting angle (on the rotor) to be adjustable.
    · Passive stall control - The blades are mounted to the rotor at a fixed angle but are designed so that the twists in the blades themselves will apply the brakes once the wind becomes too fast. The blades are angled so that winds above a certain speed will cause turbulence on the upwind side of the blade, inducing stall. Simply stated, aerodynamic stall occurs when the blade's angle facing the oncoming wind becomes so steep that it starts to eliminate the force of lift, decreasing the speed of the blades.
    · Active stall control - The blades in this type of power-control system are pitchable, like the blades in a pitch-controlled system. An active stall system reads the power output the way a pitch-controlled system does, but instead of pitching the blades out of alignment with the wind, it pitches them to produce stall.
    (See Petester's Basic Aerodynamics for a nice explanation of both lift and still.)
    Globally, at least 50,000 wind turbines are producing a total of 50 billion kilowatt-hours (kWh) annually. In the next section, we'll examine the availability of wind resources and how much electricity wind turbines can actually produce.
    عصام نورالدين
    عصام نورالدين غير متواجد حالياً
    الصورة الرمزية عصام نورالدين
    Received: 10
    مشكور على هذه المعلومات ......
    ولكني لم أفهم هذه الأرقام غير المتسلسلة ، على عمود واحد ...
    لا تفكر في ما تريد أن تأخذ ، بل فكر في ما تستطيع أن تقدم
