معرفة سرعة الرياح دون أجهزة
النتائج 1 إلى 10 من 12
    mahmoodbtb
    mahmoodbtb غير متواجد حالياً
    Know Your Wind
    A precise understanding of your wind resource is the cornerstone of any wind project. While some of the best resources are found on agricultural lands, the power in the wind varies greatly from one location to another. There are two initial steps to determine the amount of wind available at your site.
    First, you need to decide how you want to use wind power. There are many kinds of wind turbines, many kinds of projects, and many uses for wind energy. Some homeowners produce a small amount of electricity just for use on their farms. Others produce excess electricity and sell it back to a utility company. Still others lease their land to developers who build large wind facilities and market the power. The size of your project will help determine the scope of your wind analysis.
    Second, you need to determine how much wind blows across your site, and when. Analyzing your wind resource is similar to evaluating a traditional crop to be harvested. Talking to experts and other landowners who have invested in wind energy can help you use "wind prospecting" techniques for estimating your resource. If your site looks promising after a first-pass assessment, you may want to install monitoring devices and take measurements over a period of time.
    The extent of your wind resource may help determine what type of a turbine you want to install, and your lifestyle and profit goals may tell you whether a wind project is worth your time. Many landowners install wind turbines simply because they believe strongly in using non-polluting, inexhaustible forms of energy.
    Wind Speed
    Speed is the most important factor to consider. Wind speed varies from year to year, season to season, with the ti me of day,
    Wind Speed Distribution
    Wind doesn't blow at the same speed all the time. The ideal wind resource has relatively stable high speeds. If your trees and vegetation are permanently deformed due to constant wind exposure, also known as “flagging,” you may have a good wind resource to generate electricity.
    Flagging graphic from the Department of Energy
    Daily and Seasonal Wind Cycles
    We tend to need electricity most during the daytime and either during the coldest or hottest months. If your wind blows strongly when you need electricity most or year-round, then you have a good match between the wind energy and your load.
    Wind Direction
    To ensure the most effective use of a wind turbine, it should be exposed to the most energetic wind. Though the wind may blow more frequently from the west, more wind energy may come from a different direction if those winds are stronger. It is very important to find out which directions have the best winds for electricity production. A wind rose chart, which is generated from your wind resource assessment, is a helpful tool to determine wind direction and distribution.
    Wind Rose graphic from U.S. Department of Agriculture
    Wind Shear
    Wind shear is the increase in wind speed at greater heights above ground. You may be able to increase your energy production by installing a turbine on a taller tower.
    Air Pressure and Temperature
    Air pressure and temperature affect the amount of energy in the wind to a minor degree. Regional data is adequately accurate to estimate pressure and temperature influences.
    Obstacles
    When wind flows around buildings and other structures in the landscape, it slows down or becomes turbulent. A wind turbine should be placed in a location where the influence of obstacles is minimized.
    Roughness
    "Roughness" refers to the terrain and density of vegetation on the landscape. Your turbine will be affected by roughness - the smoother the better - within a 19-mile (30-kilometer) radius, so you want to determine how rough your land really is.
    In Summary
    All of the above are factors that impact your wind power. Wind power determines the amount of electricity available to be produced on an annual basis. The more information you gather about your wind resource, the better your decision about investing in wind energy will be.
    عصام نورالدين
    عصام نورالدين غير متواجد حالياً
    الصورة الرمزية عصام نورالدين
    Received: 10
    بارك الله فيك .......
    لا تفكر في ما تريد أن تأخذ ، بل فكر في ما تستطيع أن تقدم
    فيصل التميمي
    فيصل التميمي غير متواجد حالياً
    الصورة الرمزية فيصل التميمي
    الموضوع ممتاز جدا ويستحق المتابعه
    القدس عروس عروبتكم
    لا اله الا الله محمد رسول الله
    mac2
    mac2 غير متواجد حالياً
    موضوع رائع جدا
    شكرا لك
    كهربائي متوسط
    كهربائي متوسط غير متواجد حالياً
    معلومات قيمة تستحق المتابعة
    monsif2003
    monsif2003 غير متواجد حالياً
    مشكور يا غالي على
    المعلومات القيمة
    حيدر الغزالي
    حيدر الغزالي غير متواجد حالياً
    شكرا لك
    شكلاته بالفلفل
    شكلاته بالفلفل غير متواجد حالياً
    مشكور اخوي
    ع المعلومات الرائعه
    zamalkawi
    zamalkawi غير متواجد حالياً
    عضو فائق التميز
    Received: 9
    معلومات مفيدة، ولكن ما علاقة العنوان بالمحتوى؟
    خيال البروق
    خيال البروق غير متواجد حالياً
    موضوع مميز اخي
    لو كان مترجم يكون افضل والفائدة تكون اكبر
    معظم المواضيع الجيدة بالانجليزي وقليلة هي المترجمة
    من علمني حرفآ كنت له عبدآ
