محطات الطاقة الحرارية الشمسية (solar thermal power plant)
صفحة 3 من 12 الأولىالأولى 1 2 34 5 6 7 ... الأخيرةالأخيرة
النتائج 21 إلى 30 من 119
  1. [21]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة eng_sa3ed مشاهدة المشاركة
    لكم كل الشكر والتقدير اخى وعلى فكره ان امشروع تخرجى عن تحلية المياة باستخدام الطاقة الشمسية فلو بالامكان ان تدنى بأبحاث فى هذا الموضوع اكن شاكرا جدا لافضالكم
    موضوع تحلية المياه بالطاقة الشمسية
    ارفق الموضوع الآتي:
    1. مرفق ملف pdf
    2. موضوع من موسوعة ويكيبيديا.
    ارجو ان يكون مفيدا.
    http://en.wikipedia.org/wiki/Solar_desalination
    Solar desalination
    From Wikipedia, the free encyclopedia
    Jump to: navigation, search
    Solar desalination is a technique to desalinate water using solar energy. Solar desalination in the modern era extends back to the early 1950s when simple solar stills were studied for remote desert and coastal communities[1]. However, because of inexpensive water pumps and pipelines and declining energy costs in the 20th century, solar stills have become less of a viable solution for these community-scale projects.
    *******s
    [hide]
    <LI class=toclevel-1>2 Problems <LI class=toclevel-1>3 Solutions <LI class=toclevel-1>4 See also <LI class=toclevel-1>5 References
    [edit] Types of solar desalination
    In general, there are two different designs for solar stills: electrically and mechanically driven systems which utilize reverse osmosis and thermally driven systems.
    [edit] Reverse Osmosis
    Main article: Reverse osmosis
    Reverse osmosis is a pressure-driven process that forces the separation of fresh water from other constituents through a semipermeable membrane. This is the preferred method in large-scale desalination implementations where electricity is cheaply available. Here, solar energy is collected and converted into electrical or mechanical energy to initiate the process.
    [edit] Solar Humidification-Dehumidification
    Main article: Solar humidification
    The solar humidification-dehumidification (HDH) process (also called the multiple-effect humidification-dehumidification process, solar multistage condensation evaporation cycle (SMCEC) or multiple-effect humidification (MEH) [2], is a technique that mimics the natural water cycle on a shorter time frame by evaporating and condensing water to separate it from other substances. The driving force in this process is thermal solar energy to produce water vapor which is later condensed in a separate chamber. In sophisticated systems, waste heat is minimized by collecting the heat from the condensing water vapor and pre-heating the incoming water source. This system is effective for small- to mid- scale desalination systems in remote locations because of the relative inexpensiveness of solar collectors.
    [edit] Problems
    There are two inherent design problems facing any solar desalination project. Firstly, the system's efficiency is governed by preferably high heat and mass transfer during evaporation and condensation. The surfaces have to be properly designed within the contradictory objectives of heat transfer efficiency, economy and reliability.
    Secondly, the heat of condensation is valuable because it takes large amounts of solar energy to evaporate water and generate saturated, vapor-laden hot air. This energy is, by definition, transferred to the condenser's surface during condensation. With most forms of solar stills, this heat of condensation is ejected from the system as waste heat. The challenge still existing in the field today, is to achieve the optimum temperature difference between the solar-generated vapor and the seawater-cooled condenser, maximal reuse of the energy of condensation, and minimizing the asset investment.
    [edit] Solutions
    One solution to the barrier presented by the high level of solar energy required in solar desalination efforts is to reduce the pressure within the reservoir. This can be accomplished using a vacuum pump, and significantly decreases the amount of energy required for desalination. For example, water at a pressure of 0.1 atmospheres boils at 50°C rather than 100°C.[3]
    [edit] See also
    [edit] References
    1. <LI id=cite_note-0>^ E Delyannis, 2003, Historic background of desalination and renewable energies, Solar Energy. http://dx.doi.org/10.1016/j.solener.2003.08.002 <LI id=cite_note-1>^ The MEH-Method (in German with english abstract): Solar Desalination using the MEH method, Diss. Technical University of Munich
    2. ^ http://www.globalwarmingsolutions.co.uk/large_scale_solar_desalination_using_multi_effect_ humidification.htm Large scale Solar Desalination using Multi Effect Humidification
    [edit] External links
    Retrieved from "http://en.wikipedia.org/wiki/Solar_desalination"
  2. [22]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    الطاقة الشمسية- الخلايا الشمسية أو محطات الطاقة الحرارية الشمسية؟
    الطاقة الشمسية - الخلايا الشمسية أو محطات الطاقة الحرارية الشمسية؟
    Solar Power-Photovoltaic or Solar Thermal Power Plant
    ملخص:
    يربط كثير من الناس الطاقة الشمسية مباشرة بالخلايا الفوتوفولطية وليس بمحطات الطاقة الحرارية الشمسية بالرغم من إنشاء أول محطة توليد حرارية شمسية كان منذ15 عشر سنة وبأسعار معقولة تجاريا مقارنة بالخلايا الشمسية.
    يناقش المرفق الطريقتين:
    • تقنية توليد الكهرباء بواسطة الخلايا الشمسية Photovoltaic
    • تقنية توليد الكهرباء بواسطة المجمعات الشمسية Solar Collectors and Concentrators
    1-المبادئ Principles
    يكفي حوالي 1% من مساحة الصحراء الكبرى بشمال إفريقيا من تأمين متطلبات العالم من الكهرباء بواسطة محطات الطاقة الحرارية الشمسية ، ويأمل العديد أن تقوم بلدان الحزام الشمسي (دول ذات كثافة شمسية عالية) باستخدام هذه الطاقة على عكس الخلايا الشمسية حيث لا يعتمد إنتاج الكهرباء على الخاصية الفوتونية بل على حرارة الشمس..
    1.1 الخلايا الشمسية (Photovoltaic):
    وهي الطريقة المباشرة بتحويل الطاقة الشمسية إلى طاقة كهربائية ، وتستخدم المواد شبه الموصلة Semiconductors مثل السليكون والتي تصنع بتقنية خاصة وأحيانا مادة السليكون كاربايد Silicon Carbide والكادميوم لتحسين الكفاءة. وتعتمد على الخواص الفيزيائية لتوليد الكهرباء أو ما يعرف بالفوتونات.
    1.2 محطات الطاقة الحرارية الشمسية:
    يمكن الرجوع إلى المشاركات السابقة والمرفقات لمعرفة المزيد عنها،، كما يوجد بالمرفق شرح للمجمعات الشمسية Parabolic Trough.
    2 -أنظمة مرجعية
    يوضح الجدول في المرفق بعض الدول والقدرات المركبة بأنظمة الخلايا الشمسية ،،
    أما محطات الطاقة الحرارية
    1. محطة موجاف Mojave بصحراء كاليفورنيا عام 1984 ، وهي محطة تستخدم ألParabolic Trough
    2. تم تركيب 9 وحدات توليد بنفس النظام في 1 بقدرة إنتاجية 354 ميجاوات كهرباء في عام 1991 م والتي قامت بتغذية 800 مليون كيلووات ساعة في السنة في شبكة الكهرباء وأنشئت على مساحة تصل إلى أكثر من 7كم مربع ، مع ملاحظة أن ثمانية وحدات لديها الاستطاعة باستخدام الوقود الأحفوري Fossil Fuel كبديل في حالة الغيوم وحجب الشمس وغيابها.
    تصل نسبة الاستخدام للطاقة الشمسية إلى 25% فقط.
    معظم مكونات المحطة تم تصنيعها في أوروبا وبلغت التكلفة أكثر من 1.2 بليون دولار أمريكي.بلغت تكلفة الكيلوات ساعة 12-14 سنتا أمريكيا بدلا من 27 سنتا أمريكيا أي بنسبة انخفاض تصل إلى 100%.
    المرفق يشمل شرحا أكثر تفصيلا ولكنه مبسط لذا أحببت إرفاقه للفائدة.
    والله الموفق وهو من وراء القصد.
  3. [23]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    Lightbulb جدول مواضيع محطات الطاقة الحرارية الشمسية
    نظرا لتعدد الملفات والمشاركات والمواضيع الخاصة بمحطات الطاقة الشمسية ،،
    احببت ان الخص ذلك في الجدول المرفق الذي يشمل
    • الموضوع
    • الرابط
    • المؤلف /الكاتب/ المشارك
    • رقم المشاركة
    لتسهيل ذلك على الأخوة الأعضاء وزوار الملتقى .
    م
    الموضوع
    الكاتب/ المؤلف/ المشارك
    المشاركة
    محطات الطاقة الحرارية (ص1)
    محطات الطاقة الحرارية (ص2،3)
    محطات الطاقة الحرارية (ص4،5)
    3
    5
    Technical and Economical Analysis of Future Prospective of Solar Thermal Power Plant
    8
    الطاقة الحرارية الشمسية المركزة
    13
    7
    الطاقة الشمسية بواسطة المرايا المقعرة
    http://www.arab-eng.org/vb/t127777.html
    السيد عبد
    15
    8
    لمن يحب المساعدة (اللواقط الشمسية)
    15
    9
    Parabolic Concentrator
    19
    10
    Solar desalination
    Wikipedia
    21
    11
    Appl. of Solar &Wind E. to Sea Water Desalin. http://www.arab-eng.org/vb/attachments/38885d1241867354-desalination-solar-energy.pdf
    D. Zejli & others
    21
  4. [24]
    شكرى محمد نورى
    Received: 62
    كما عودتنا على المواضيع المثمرة والرائعة .
    تسلم على عطاءك المتميز حقا .
    تقبل كل الاعتزاز والتقدير .
    البغدادي .
  5. [25]
    شكرى محمد نورى
    Received: 62
    البغدادي .
  6. [26]
    dercncplaner
    dercncplaner غير متواجد حالياً
    الصورة الرمزية dercncplaner
    أنا لم أقرأ تفاصيل الموضوع هنا، ولكن عندي ملاحظة مهمّة
    إذا كان هنا المقصود هو عن محطّات توليد الكهرباء بالطاقة الشمسيّة الحرارية، فالأكيد أن السائل الذي يجري في الأنابيب التي تقع في محرق المرآة هو زيت صناعي ... وليس بالماء، لأن هذا الزيت يربح الحرارة بسرعة، والأهم أنه يحتفط بها لوقت أطول من الماء.
    وحتّى إن كانت للمنازل، فالنظام الأفضل هو استخدام الزيت، ثم في مُجمّع يتم تسخين الماء.
    والله أعلم
    حلقات شرح كتاب التوحيد للشيخ محمد حسان (كاملة) بروابط مباشرة (Archive) .. هنــا، أو إمكانية المشاهدة المباشرة .. هنــا
  7. [27]
    أبو محمد الشامي
    أبو محمد الشامي غير متواجد حالياً
    أحادي أو ثنائي الأقطاب
    أخي العزيز
    يرجى توضيح الفرق بين اللواقط الكهربائية التي تعتمد على الأشعة الشمسية بين نوعين mono Or Poly ومتى نستخدم كل واحدة منهم.
    ولكم الشكر الجزيل
  8. [28]
    شوق9999
    شوق9999 غير متواجد حالياً
    عضو داعم للملتقى
    الصورة الرمزية شوق9999
    جزاك الله خيييييييييييييييير
    كل عام والجميع بخير ،،
    وتقبل الله صيامكم وقيامكم.
  9. [29]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    البغدادي .
    الأخ المهندس شكري
    شكرا مرورك وتقريظك ،
    وشكرا مداخلتك القيمة المحفزة .
    بارك الله فيك وفي عطآءتك ومواضيعك وجهودك.
    لك مني كل الود والتقدير.
  10. [30]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة dercncplaner مشاهدة المشاركة
    والله أعلم
    المهندس dercncplaner
    وعليكم السلام
    نعم اخي أصبت وهو سائل وسيط تنتقل الحرارة من الماء له عند درجة حرارة دون الغليان مثل غاز الفريون (او مماثل له ذو درجة غليان منخفضة) ويستخدم لتحريك التربينة عند ضغط عالي -- وقد ذكرت ذلك في الموضوع(( لتسخين غاز الفريون والذي يتبخر عند درجة حرارة 45 درجة مئوية وفي هذه الحالة يتم استخدام الماء كوسيط ومن ثم يستخدم الفريون المبخر وبضغط عالي لوحدة التربين/المولد لتوليد الطاقة الكهربية.))
    --، هذا في محطات الطاقة الشمسية الحرارية ، اما في تسخين المياه المنزلية فيستخدم مباشرة حيث ان الحرارة الناتجة كافية لعمليات تسخين المياه المنزلية.
    بارك الله فيك.
