ARAMCO-Welding Requirements for API Tanks
النتائج 1 إلى 4 من 4
    الصورة الرمزية سيد صلاح الصاوى
    سيد صلاح الصاوى
    سيد صلاح الصاوى غير متواجد حالياً
    Received: 62
    Given: 43
    This standard specifies the welding requirements for shop and field fabrication, repair, or modification of tanks designed and built to API STD 650 and API STD 620 and repaired to API STD 653. These requirements are in addition to the requirements of the API Codes and ASME SEC IX. For materials other than P-No. 1 or P-No. 8 and for API STD 620 App. Q tanks, the application shall be reviewed by Consulting Services Department to determine if additional requirements need to be specified.
    1.2 Additional requirements may be contained in Scopes of Work, Drawings, or other Instructions or Specifications pertaining to specific items of work.
    1.3 Any reference to Consulting Services Department (CSD) shall be interpreted as the CSD Welding Specialist or a representative designated by CSD.
    1.4 This entire standard may be attached to and made a part of purchase orders
    م.مجدي عليان
    م.مجدي عليان غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية م.مجدي عليان
    Received: 24
    Plz
    if you can to put all ARAMCO standards under one file or section
    thanx again for all efforts
    Best Regards
    Majdi N. Elyyan
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    شكرا اخى الفاضل
    http://carsnology.blogspot.com
    سامح 2010
    سامح 2010 غير متواجد حالياً
    الصورة الرمزية سامح 2010
    جزاكم الله خيرا وجعله فى ميزان حسناتك
