برنامج رهيب في كتابة الصيغ الكيميائية والمركبات الكيميائية والكثير الكثير ....
النتائج 1 إلى 10 من 13
    مهندس المحبة
    مهندس المحبة غير متواجد حالياً
    Received: 157
    أرجو أن أفيدكم أخواني الأعزاء بهذا البرنامج الأكثر من رائع لكل من يريد كتابة المركبات الكيميائية وصيغها ......
    Chemwindows 6.0
    ChemWindow 6 is the most complete chemistry publishing software for Windows 98, NT or XP users. It helps you to produce great presentations for all aspects of chemical research: chemical reactions, 2-D and 3-D chemical structures, laboratory experiment setups, chemical engineering diagrams. Most structures can be drawn, checked for accuracy, and embedded in a report in just a few moments. Common groups can be labeled by typing a single key, using programmable Hot keys.
    The chemical Engineering Collection presents more than 250 Process Flow Symbols: furnaces, filters, compressors and coolers, exchangers and evaporators, silos and separators, tanks and towers, and vessels and valves. You 'll find everything you need to draw top-quality process flow diagrams.
    Chemical Database Module
    The Chemical Database is used to set up a chemical database in Microsoft Access. Two Access example files are provided, and you can adapt one to set up your own database. You will store fully integrated chemical structure fields into Access and use predesigned tables and forms to enter your product chemical data and perform substructure searches.
    To edit a structure, double click the structure field in Access. This field has been programmed to automatically call ChemWindow. Using ChemWindow, you can edit the structure without leaving the database. Fields for mass, formula, etc. are updated or entered automatically. You also can import SD files into an Access database, using the SDfile import Wizard.
    SymApps 6
    Top Quality 3-D Presentations, 3-D Modeling and Publishing:
    3-D presentationSymApps is a professional 3-D molecular rendering program designed for desktop visualization and publishing. A modified MM2 force field minimization module converts 2-D structures to 3-D.
    SymApps produces high-quality graphics that supports perspective views, colors, dithering (smoothing), and light source adjustments. Designed as OLE server application, it allows you to embed structures inside word processors (e.g. Microsoft Word) and manipulate molecules within the container documents.
    Symmetry Operations:
    SymApps has the ability to calculate symmetry point groups and to display the symmetry elements on the screen. Point groups may be calculated over a range of tolerances, allowing you to quickly identify distortions in your molecular coordinates. SymApps will also calculate character tables for any symmetry point group and make animated movies of symmetry operations ans basic three-dimensional rotations. Can also export them as .avi files that will run in any Windows application that supports this format.
    http://rapidshare.com/files/17059769..._ingDZ.com.zip
    http://www.megaupload.com/?d=ERIKO7PB
    أرجوالرد والتقييم ولاتنسونا من خالص دعائكم .........
    ميس الحلوة
    ميس الحلوة غير متواجد حالياً
    الصورة الرمزية ميس الحلوة
    شكرا على البرنامج الأكثر من رائع ........
    مهندس المحبة
    Received: 157
    ابولوزة
    ابولوزة غير متواجد حالياً
    شكر
    aboeslam
    aboeslam غير متواجد حالياً
    افيدونى رجاءا ماهى المواد التى تتفاعل مع الجبس او تضاف اليه لتحسين كفاءته
    aboeslam
    عزيزى مهندس المحبه افيدنى عن المواد
    التى تضاف الى الجبس .لتحسين وظائفه
    Mohammed El-Gaily
    Mohammed El-Gaily غير متواجد حالياً
    100 بالمية والله وماشاء الله وجزاك الله عنا كل خير
    تسلمي وشكراً لك أختي المهندسة العزيزة ونخدمك كدا ببرنامج خطير مره زي هذا إنشاء الله
    وشكررررررررررراً جزييييييييييييييييييلاً شديييييييييييييييييد شدييييييييييييييييييييد
    أخوك م.محمد الجيلي
    ملتقي الهندسة الإلكترونية
    osaid jarrar
    osaid jarrar غير متواجد حالياً
    اخواني افيدوني عن افضل نسب خلط المواد الاصق للسراميك ولماذا يطبل السراميك بعد التركيب وطرق العلاج مع الشكر الجزيل
    cyberian
    cyberian غير متواجد حالياً
    الصورة الرمزية cyberian
    برنامج رائع و فعال
    احلاموه
    احلاموه غير متواجد حالياً
    ما عرفت كيف انزله وحدي ):
    اذا حد هنا حبير كاشور يطرشلي الخطوات ؛؛؛
