برنامج رهيب في كتابة الصيغ الكيميائية والمركبات الكيميائية والكثير الكثير ....
النتائج 1 إلى 10 من 15
    مهندس المحبة
    مهندس المحبة غير متواجد حالياً
    Received: 157
    أرجو أن أفيدكم أخواني الأعزاء بهذا البرنامج الأكثر من رائع لكل من يريد كتابة المركبات الكيميائية وصيغها ......
    Chemwindows 6.0
    ChemWindow 6 is the most complete chemistry publishing software for Windows 98, NT or XP users. It helps you to produce great presentations for all aspects of chemical research: chemical reactions, 2-D and 3-D chemical structures, laboratory experiment setups, chemical engineering diagrams. Most structures can be drawn, checked for accuracy, and embedded in a report in just a few moments. Common groups can be labeled by typing a single key, using programmable Hot keys.
    The chemical Engineering Collection presents more than 250 Process Flow Symbols: furnaces, filters, compressors and coolers, exchangers and evaporators, silos and separators, tanks and towers, and vessels and valves. You 'll find everything you need to draw top-quality process flow diagrams.
    Chemical Database Module
    The Chemical Database is used to set up a chemical database in Microsoft Access. Two Access example files are provided, and you can adapt one to set up your own database. You will store fully integrated chemical structure fields into Access and use predesigned tables and forms to enter your product chemical data and perform substructure searches.
    To edit a structure, double click the structure field in Access. This field has been programmed to automatically call ChemWindow. Using ChemWindow, you can edit the structure without leaving the database. Fields for mass, formula, etc. are updated or entered automatically. You also can import SD files into an Access database, using the SDfile import Wizard.
    SymApps 6
    Top Quality 3-D Presentations, 3-D Modeling and Publishing:
    3-D presentationSymApps is a professional 3-D molecular rendering program designed for desktop visualization and publishing. A modified MM2 force field minimization module converts 2-D structures to 3-D.
    SymApps produces high-quality graphics that supports perspective views, colors, dithering (smoothing), and light source adjustments. Designed as OLE server application, it allows you to embed structures inside word processors (e.g. Microsoft Word) and manipulate molecules within the container documents.
    Symmetry Operations:
    SymApps has the ability to calculate symmetry point groups and to display the symmetry elements on the screen. Point groups may be calculated over a range of tolerances, allowing you to quickly identify distortions in your molecular coordinates. SymApps will also calculate character tables for any symmetry point group and make animated movies of symmetry operations ans basic three-dimensional rotations. Can also export them as .avi files that will run in any Windows application that supports this format.
    http://rapidshare.com/files/17059769..._ingDZ.com.zip
    http://www.megaupload.com/?d=ERIKO7PB
    أرجوالرد والتقييم ولاتنسونا من خالص دعائكم .........
    weswes
    weswes غير متواجد حالياً
    الصورة الرمزية weswes
    جزاك الله خيرا وجعله في ميزان حسناتك
    مهندس المحبة
    Received: 157
    أجمعين إن شاء الله .........
    correng
    correng غير متواجد حالياً
    الصورة الرمزية correng
    مجهوداتك والله اكثر من رائعه
    و جزاك الله عنا خيرا
    مهندس المحبة
    Received: 157
    أهلا وسهلا أخي العزيز وبارك الله فيك ......
    athersaeed1970
    athersaeed1970 غير متواجد حالياً
    الصورة الرمزية athersaeed1970
    عاشت يمينك لاكلت ولاوهنت
    محمد صلاحات
    محمد صلاحات غير متواجد حالياً
    اخي الكريم مهندس المحبة شكر خاص لك من اعماق قلبي
    شيراز سندبال
    شيراز سندبال غير متواجد حالياً
    شكرا على الموقع و السلام عليكم
    مهندس المحبة
    Received: 157
    أهلا وسهلا فيكم أخواني ومنورين
    محمد 977
    محمد 977 غير متواجد حالياً
    مشكووووووووووووووووور من صميم القلب
    تسلم الأيادي
    الف الف الف شكر من صميم القلب
