ARAMCO-Welding Requirements for Pressure Vessels
النتائج 1 إلى 4 من 4
    الصورة الرمزية سيد صلاح الصاوى
    سيد صلاح الصاوى
    سيد صلاح الصاوى غير متواجد حالياً
    Received: 62
    Given: 43
    This standard specifies the welding, heat treatment, and hardness testing requirements for shop and field fabrication, repair, or modification of pressure vessels and heat exchangers to ASME SEC VIII. These requirements are in addition to the requirements of ASME SEC VIII and ASME SEC IX.
    1.2 Additional requirements may be contained in Scopes of Work, Drawings, or other Instructions or Specifications pertaining to specific items of work.
    1.3 Any reference to Consulting Services Department (CSD) shall be interpreted as the CSD Welding Specialist or a representative designated by CSD. Any reference to "approval" shall be interpreted as written approval.
    1.4 This entire standard may be attached to and made a part of purchase orders.
    سامح 2010
    سامح 2010 غير متواجد حالياً
    الصورة الرمزية سامح 2010
    جزاكم الله خيرا وجعله الله فى ميزان حسناتك
    ممكن ترفق WPS&PQR للملف
    وطريقة اختبار Hydrotest for vessels
    سامح 2010
    ممكن لو عند حضرتك Aramco welding requirements for tanks
    وجزاكم الله خيرا
    سيد صلاح الصاوى
    Received: 62
    Given: 43
    الاخ سامح يمكن مشاهدة الرابط التالى
    http://www.arab-eng.org/vb/t127883.html
