المعدات المطلوبة لإنشاء شبكة انترنت محلية وايرلس مع مقهى انترنت
صفحة 8 من 13 الأولىالأولى ... 4 5 6 7 89 10 11 12 ... الأخيرةالأخيرة
النتائج 71 إلى 80 من 125
  1. [71]
    الاصيله
    الاصيله غير متواجد حالياً
    لوسمحتوا ابغي منكم طلب اذا ممكن تساعدوني في حل هذا الاسيمانت اذا ممكن هندسه الشبكات اللاسلكيه
    اذا احد يعرف الحل يرد ع بسرع وقت ممكن وذلك للاهميه ضروري
  2. [72]
    الاصيله
    Assignment Title:
    Design Wireless Network for the two buildings of the University of Hail.
    Introduction to University of Hail:
    University of Hail is based in the Muscat area and is a centre for undergraduate and postgraduate teaching. It is a relatively new University which does not rely particularly on technology to the extent that it should do in order to function efficiently. Mail is sent between departments in paper form and the use of computers is minimal and concentrated only in the Faculty of Computing.
    For educational and administrative purposes UOH is divided into 2 buildings within 1 mile of each other. The main building has the Dean office, Registration department, Technical services department, Faculty of Engineering, Law, Business, English and Computing. The second building has Chairman Office, HR department, Central Lab and learning Center.
    The main site comprises of 4 Floors (ground, first, second and third). Ground floor comprises Dean office and Registration department. First floor comprises Engineering departments and 2 laboratories, each laboratory contains 15 client computers and one server. Second floor comprises Technical services, English and Law departments. Third floor comprises Computing department and 4 high equipped and secure laboratories. Each laboratory contains 20 to 30 PCs and one server. In each floor every department comprises of up to 20 staff laptops. The staff machines are not networked. The laboratories at first and third floor have approximately 10 members of admin staff all with their own PCs and not networked. The registration department at ground floor and technical department at second floor have more than 15 staff members all with their own PCs and laptops but not networked. Only the laboratories in this building are wired network.
    The second building consists of 3 Floors (ground, first and second). Ground floor contains central laboratory having 300 PCs and 2 servers. There is a wired network in laboratory but no connectivity with internet. First floor contains learning center having more than 50 PCs but without network. Second floor contains Chairman office and HR department with 15 staff members having wireless network and internet facility. The second building has approximately 10 members of admin staff in ground and first floor- again all with their own PCs/laptops and again not networked
    COMP 0316 Page 2 of 9
    Requirements
    1. Five PCs of every laboratory in main building should share a printer and there should be a single laser printing facility in each Laboratory.
    2. Ten PCs in learning center should share a printer and there should be a laser printing facility for every 15 PCs.
    3. Every department should have a printer and laser printer facility share by staff members.
    4. All computers in department and laboratories should be wireless networked so that internal Email can be supported.
    5. The wireless networks should be separated such that students must NOT be able to access the Staff and Admin segment.
    6. Internet Access must be provided to ALL users.
    7. Central laboratory in second building should wirelessly connect to learning center in second building and all laboratories in main building.
    8. Both building of UOH should connect to each other through wireless technology.
    Assignment Tasks
    You need to explain which devices you will select for installation of wireless network at UOH. Give the reason for selecting a specific device.
    (5 marks)
    The purpose of a wireless network is to determine the number and placement of different network devices that provides adequate signal coverage throughout the entire UOH. You may consider the following:
    a. Provide a brief description on the UOH.
    b. Understand the wireless requirements of the UOH (e.g. the range between devices and the access point, technology implemented like 802.11g or 802.11n, attenuation factors, the coverage areas required, security, Access for different users).
    c. Review the existing network (can the existing network be used for implementing the wireless network).
    d. Determine the access point locations for every floor in a duilding.
    e. Prepare a diagram showing the wireless network proposed for the floors of two buildings in UOH.
  3. [73]
    الاصيله
    Assignment Title:
    Requirements
    Assignment Tasks
    (5 marks)
  4. [74]
    الاصيله
    Assignment Title:
    Requirements
    Assignment Tasks
    (5 marks)
  5. [75]
    اللامنتمي
    اللامنتمي غير متواجد حالياً
    موضوع قيم بارك الله فيك
  6. [76]
    kaboke
    kaboke غير متواجد حالياً
    الصورة الرمزية kaboke
    Given: 3
    مشكور جداً تسلم
    kabo- sudan
  7. [77]
    mosque010
    mosque010 غير متواجد حالياً
    بااااااااااارك الله فيييييييييييييييييييييك
    وفييييييييييييييك بااااااااااااااااااااااارك
  8. [78]
    م/على عبدالمقصود
    م/على عبدالمقصود غير متواجد حالياً
    شكرااااااااااااااااااااااااااااااااااااااااااااااا اااااااااااااااااااااااااااااااااااااااااااااااااا ا
  9. [79]
    سماهر 2
    سماهر 2 غير متواجد حالياً
    ميرسي
    أحتاجها ,,, يعطيكـ ربي ألف عافية
  10. [80]
    معين2020
    معين2020 غير متواجد حالياً
    الصورة الرمزية معين2020
    يعطيك العافيه
