موسوعه البرامج الهندسيه -- اكثر من 270 برنامج في كافه المجالات الميكانيكيه►►►υ
النتائج 1 إلى 10 من 23
    الصورة الرمزية م/زيكو تك
    م/زيكو تك
    م/زيكو تك غير متواجد حالياً
    Received: 101
    Given: 13
    موسوعه البرامج الهندسيه -- اكثر من 270 برنامج في كافه المجالات الميكانيكيه►►►►►►►►►
    البرامج A-D
    2wayxovr.zip
    2-Way passive crossover design pgm 3wayxovr.zip
    3-Way passive crossover design pgm
    762x39.zip
    Reload/test data on the 7.62x39 NATO acana401.zip
    Determines AC response of a circuit actfil.zip
    Active filter design air_cond.zip
    Trouble shooting for Air Conditioning alloy2.zip
    A Great Program For Bullet Casters (VG)
    amaze1.zip
    Signetics Amaze v1.7 disk 1 PLD Tutor amaze2.zip
    Signetics Amaze v1.7 disk 2 PLD Tutor amaze3.zip
    Signetics Amaze v1.7 disk 3 PLD Tutor amaze4.zip
    Signetics Amaze v1.7 disk 4 PLD Tutor amaze5.zip
    Signetics Amaze v1.7 disk 5 PLD Tutor amaze6.zip
    Signetics Amaze v1.7 disk 6 PLD Tutor amaze7.zip
    Signetics Amaze v1.7 disk 7 PLD Tutor
    angle102.zip
    ANGLE v1.02 Triangle calculator a_filter.zip
    Calculate resistor/capacitor OP AMP badstuff.zip
    dBASE listing of hazardous materials best_ups.zip
    Best Power Technology UPS seminar (VG) bidbiz.zip
    Make bids for contracting & other fields blakbdy.zip
    Black Body IR calculator for physics boundry2.zip
    Speaker & boundary response plotter btu.zip
    Calculate BTU's needed to heat & cool areas btu12sw.zip
    Calculates heating & cooling loads bullet1.zip
    bullet sighting program bullet_1.zip
    Bullet velocity calculator - Reloaders bwrksht.zip
    Powerful ballistics program cablev1.zip
    Media General CATV conversion chart carpet1.zip
    Calc cost & yards based on width & length ccharts.zip
    Control Charts made easy ccicap.zip
    CCICAP v4.09 Linear circuit analysis pgm cement.zip
    calculates amount of concrete needed cement1.zip
    Calculates cost & yards based on l/w/d ce_amp2.zip
    Transistor AMP design program with DOCS chill.zip
    wind chill calculation setup circdbas.zip
    Circuit Search database circit12.zip
    Microcomputer circuit analysis v1.2 control.zip
    Calculations for Locus of a control hub cpthermo.zip
    ThermoDynamics calculations for enginering ctowr321.zip
    Cooling Tower perform./calcs. v3.71
    ctrlsys1.zip
    Electronic Engineering utilities. 1 of 2 ctrlsys2.zip
    Electronic Engineering utilities. 2 of 2
    dan.zip
    AM Directional antenna analysis dataplot.zip
    A useful 2d science and engineering prog drills.zip
    Drill sizes/decimal equivalent/tap sizes
    م/زيكو تك
    Received: 101
    Given: 13
    البرامج E-H
    edraw32.zip
    EasyDraw logic/electronics schematic CAD eepub02.zip
    EE Public Domain library disk 2 eepub06.zip
    EE Public Domain library disk 6 eepub13.zip
    EE Public Domain library disk 13 eepub14.zip
    EE Public Domain library disk 14 eepub16.zip
    EE Public Domain library disk 16 eepub17.zip
    EE Public Domain library disk 17 eepub18.zip
    EE Public Domain library disk 18 eepub19.zip
    EE Public Domain library disk 19 eepub20.zip
    EE Public Domain library disk 20 eepub21.zip
    EE Public Domain library disk 21 eepub22.zip
    EE Public Domain library disk 22 eepub23.zip
    EE Public Domain library disk 23 eepub24.zip
    EE Public Domain library disk 24 eepub25.zip
    EE Public Domain library disk 25 eepub26.zip
    EE Public Domain library disk 26 eepub27.zip
    EE Public Domain library disk 27 eepub28.zip
    EE Public Domain library disk 28 eepub29.zip
    EE Public Domain library disk 29 eepub30.zip
    EE Public Domain library disk 30 eepub31.zip
    EE Public Domain library disk 31 eepub32.zip
    EE Public Domain library disk 32
    ee_calc.zip
    good EE formulas in BASIC electrc3.zip
    Electrician calc. v3.0, wire&cond size electric.zip
    figures various electrical formulas eltron13.zip
    HP Electronics package v1.3 eng51.zip
    Engineering relationships/equations v5.1 engstuff.zip
    engineering formulas for siliconheads eplot.zip
    Plot an equation on the screen epromprg.zip
    Eprom Programing Hex. & Bin Save Request eq_tutor.zip
    Proper use of an AUDIO equalizer exball.zip
    Demo balistic program for shooters facmaint.zip
    Factory Machine Maintenance system filtcad.zip
    Capacitive FILTER design utilities filtr170.zip
    "Filter CAD" v1.70 Electronic filter flange31.zip
    Flange Analysys v3.1 (Engineering) flowdem3.zip
    Steam & Gas line sizing/estimator fmsim12.zip
    FM Signal SImulation analysis v1.2 formulae.zip
    Electronic formula solver ftcalc.zip
    Foot & Inch calculator w/fractions gear.zip
    Program to determine bicycle gear ratios geosat10.zip
    GeoSAT v1.0 Satellite dish angle/aim handy121.zip
    HandyMan v1.20 Remodeling/Redecorating heatload.zip
    Figure HEAT/AC/REFRIG. loads v1.0 hpe.zip
    Engineering - stress analysis program hpe144a.zip
    HPE v1.44 FE Preprocessor from HPE hpe144b.zip
    HPE v1.44 *2d* FE analysis program hpe144c.zip
    HPE v1.44 *3d* FE analysis program hpread.zip
    Plans for an HP/PC Infrared interface hvac_r.zip
    HVAC & Refrigeration measurement calculator
    hwm_1.zip
    Hazardous Waste Material util. 1 of 12 hwm_10.zip
    Hazardous Waste Material util. 10 of 12 hwm_11.zip
    Hazardous Waste Material util. 11 of 12 hwm_12.zip
    Hazardous Waste Material util. 12 of 12 hwm_2.zip
    Hazardous Waste Material util. 2 of 12 hwm_3.zip
    Hazardous Waste Material util. 3 of 12 hwm_4.zip
    Hazardous Waste Material util. 4 of 12 hwm_5.zip
    Hazardous Waste Material util. 5 of 12 hwm_6.zip
    Hazardous Waste Material util. 6 of 12 hwm_7.zip
    Hazardous Waste Material util. 7 of 12 hwm_8.zip
    Hazardous Waste Material util. 8 of 12 hwm_9.zip
    Hazardous Waste Material util. 9 of 12
    hypercep.zip
    HYPERCEPTION Elec. Eng. signal analysis
    1 Not allowed!
    م/زيكو تك
    Received: 101
    Given: 13
    واتظروا المزيد برجاء ترك تعليقات لمعرفه مدى الاستفاده منها
    1 Not allowed!
    مصطفى الوكيل
    الصورة الرمزية مصطفى الوكيل
    Received: 61
    1 Not allowed!
    مهندس إستشارى / مصطفى الوكيل
    Zuhair Fayez
    م/زيكو تك
    Received: 101
    Given: 13
    1 Not allowed!
    م/زيكو تك
    Received: 101
    Given: 13
    ·ieee51.zip
    IEEE Filter design program v5.1
    ·imp_cvt.zip
    Convert RF impedance values to any format
    ·ind_cap.zip
    Inductive and capacitive reactance
    ·intermod.zip
    Intermodu. analysis for up to 10 freqs
    ·lblg2.zip
    LabLog II data acquisition manager
    ·lenscad.zip
    Design lens systems
    ·lin_test.zip
    Monitor Linearity Test
    ·listroom.zip
    Stereo speaker placement program
    ·lnap.zip
    Linear Network Analysis
    ·lormc.zip
    loran info for aircraft enthusiasts
    ·ltopamp.zip
    Spice OPAMP modules from Linear Tech
    ·l_match.zip
    Calculate match with L network
    ·machshop.zip
    Machine shop programs in Basic
    ·maint1.zip
    Factory machine maintenance system
    ·mapper43.zip
    Creates a graphical image of land plots
    ·measure.zip
    Measurement conversions-very handy
    ·miprops1.zip
    Gas property calculator - 1 of 2
    ·miprops2.zip
    Gas property calculator - 2 of 2
    ·mndothyd.zip
    Civil Engineering Hydraulics calculation
    ·module.zip
    Analog filter simulator. Good for audio
    ·motor.zip
    Calculate & plot DC motor specs
    ·motor890.zip
    Motorola's "Specs In Secs" Semiconductor
    ·mtvrt.zip
    Mark VandeWetting's ray-tracing package
    ·mwpath.zip
    1-2-3 microwave path calculation overlay
    ·nasa755.zip
    Nasa 2 Line Keplerian Elements For Sat's
    ·nceest.zip
    Est software for remodeling contractor
    ·notis.zip
    Tech anal methods for financial decisions
    ·nrginit1.zip
    Mass electric commercial energy spreadsheet
    1 Not allowed!
    م/زيكو تك
    Received: 101
    Given: 13
    ·oscii.zip
    Oscillator II v2.0 osc. circuit design
    ·paper.zip
    invaluable if you must weigh paper
    ·pcmech20.zip
    PC Mechanic v2.0 Maintenance management
    ·pc_calib.zip
    Instrument Calibration/Verification Aid
    ·pc_ecap.zip
    Electronic Circuit Analysis v1.10
    ·pc_ecap1.zip
    Electronic Circuit analysis program
    ·pc_track.zip
    PC-Track Satellite tracker. Does EGA/VGA
    ·perfv456.zip
    Perfect Box speaker enclosure design
    ·pinewood.zip
    Electronic timing circuit design pgm
    ·plfam.zip
    GA. Power new commercial/ind rate calc
    ·pll.zip
    PD Phase Locked Loop design program
    ·pll74.zip
    Phase Locked Loop designer (74HC46)
    ·plldsgn.zip
    Phase Locked Loop design program for 4046
    ·polemt1.zip
    How to install a Satellite Pole Mount
    ·psize.zip
    Particle-size analysis routines
    ·pspice1.zip
    Circuit analysis using nodal anals 1 of 3
    ·pspice2.zip
    Gen of transient & freq respons 2 of 3
    ·pspice3.zip
    Electronic engineering supplement 3 of 3
    ·p_supply.zip
    Linear power supply design made simple
    ·radarhlp.zip
    Radar work station package
    ·rafter.zip
    A must for any home builder
    ·resistor.zip
    Resistor color codes
    ·resomics.zip
    MuRata-Erie microwave dielectric resonator
    ·rfsv202.zip
    AM/FM/TV RF engineering programs (color)
    ·rmez1.zip
    C Translations of REMEZ filter design
    ·roomspkr.zip
    Aid in placing your stereo speakers
    م/زيكو تك
    Received: 101
    Given: 13
    ·sample19.zip
    SIGNIX: DISPRO(tm) Digital Filter Design
    ·satlite.zip
    Win prog. for seting satelite dishes
    ·scope.zip
    Analyze APT signal from 8-bit raw data
    ·slickimd.zip
    Intermod detector for radio engineering
    ·solve310.zip
    Electronic circuit solver v3.10
    ·solve51.zip
    SOLVE v5.1 Circuit solver
    ·sp53.zip
    Statistical Plotting for engineering
    ·spc_stat.zip
    Statistical Process Control Program
    ·speakerh.zip
    Monitor array alignment
    ·splitn.zip
    splitter/combiner network design
    ·stanjan.zip
    Stanford Univ's thermochemical analysis
    ·stru_ana.zip
    Struct. Analysis Pgms. fm Byte Mag
    ·studpl21.zip
    Studio Plus V2.1 Audio Engineers
    ·sunchart.zip
    Satellite Sun Outage Date Chart
    ·sunrise.zip
    Give sun rise/set times
    ·talknbox.zip
    GIF fmt Audio Signal Digitizer/Reproducer
    ·tburn03a.zip
    Combustion and Fired Heater Analysis,
    ·tcxover.zip
    Speaker XOVER design utility
    ·telisol.zip
    Solar energy savings evaluator
    ·therm.zip
    Calculates thermal properties
    ·thrmcalc.zip
    Thermal Effect calculator
    ·toolbox.zip
    Menu-driven RF and eng. formula tools
    ·toxic.zip
    Toxic GAS database & DOSE calculator
    ·tplot753.zip
    T-Plot v7.53 Technical plotting program
    ·tpnet003.zip
    Branch/loop piping Network flow/press calc
    ·tracer.zip
    Fritzz Graphics ray-tracing package
    ·trak250.zip
    Satellite Tracker v2.50 Major upgrade
    ·traxplot.zip
    Elec/schematic/PC board plotter & printer
    ·ttl_name.zip
    TTL Name to Description utility
    ·ttm.zip
    Truth Table Generator
    ·tvcoch1.zip
    TV Channels listed by Channel/state/city
    ·tvinfo2a.zip
    SMATV Design program v2.0 1 of 2
    ·tvinfo2b.zip
    SMATV Design program v2.0 2 of 2
    م/زيكو تك
    Received: 101
    Given: 13
    ·units.zip
    converts anything to anything
    ·valve_w.zip
    Worcester Controls' easy valve sizing
    ·varian.zip
    Varian's Energy savings calculator(TVT/MSDC)
    ·wave.zip
    Utility to view PCM sound file waveforms
    ·waveform.zip
    Waveform analysis (FFT) - very good
    ·wchill.zip
    Wind Chill chart from 40 to -25 F
    ·weld.zip
    Welding tutor..type "BEGIN" to start
    ·westrn1.zip
    Westinghouse Training Pgm access 1of2
    ·westrn2.zip
    Westinghouse Training Pgm Access 2of2
    ·wing.zip
    Model Sailplane design and performance
    ·wirecode.zip
    Crossover list of wire UL/Fire codes
    ·wood.zip
    cut plywood without waste
    ·wxprog.zip
    Convert barometric pressure
    ·xeroxpcb.zip
    make circuit boards with a copier
    ·xovrtols.zip
    General passive crossover design utils
    ·xy.zip
    Curve fitting program
    ·xysee.zip
    Mathematical Function Grapher
    ·1861book.zip
    Book of scientific facts circa 1861
    ·60mmfix.zip
    making dime store telescope better
    ·ac8947_1.zip
    ASTROCLK Astro clock & celestial tracking
    ·ac8947_2.zip
    ASTROCLK v8947 Data files. 2 of 3
    ·ac8947_3.zip
    ASTROCLK v8947 Source code. 3 of 3
    ·afa_orb.zip
    PD: Orbital Simulator from USAF Academy
    ·alchemy1.zip
    a brief history of Alchemy
    ·astrnomy.zip
    test your knowledge of astronomy
    ·astrol94.zip
    A complete astrology package
    ·astrolgy.zip
    A serious astrology chart maker
    ·astrshw2.zip
    astronomy show of stars, galaxies, etc
    ·atoms.zip
    Periodic table w/ spectral & nuclear data
    ·bchild.zip
    BRAINCHILD v1.0 Physics/elements tutorial
    ·bigblow.zip
    hurrican tracking program in basica
    م/زيكو تك
    Received: 101
    Given: 13
    ·biomorf.zip
    Shows Darwin's theories in action
    ·brainrl.zip
    Left/Right Brain Dominance Program
    ·caim01.zip
    C.A.I.M. 1 of 10 Id of Microorganisms
    ·caim02.zip
    C.A.I.M. 2 of 10 Id of Microorganisms File
    ·caim03.zip
    C.A.I.M. Identify anerobic bacteria 3 of 10
    ·caim04.zip
    C.A.I.M Identifies anaerobes 4 of 10
    ·caim05.zip
    C.A.I.M. Identifies yeast. 5 of 10
    ·caim06.zip
    C.A.I.M. Identifies pseudomonads. 6 of 10
    ·caim09.zip
    C.A.I.M. vibrionaceae/neisseriaceae 9 of 10
    ·caim10.zip
    C.A.I.M. Create a own database of 10 of 10
    ·census20.zip
    Census research tool for genealogy
    ·chem20.zip
    Construct/view chemical compounds
    ·chem200.zip
    Molecular model builder
    ·chemic.zip
    3d molecular program
    ·chemist.zip
    Chemistry tutor and Illustrator
    ·chemm.zip
    Molecular model 3D program
    ·chemprog.zip
    chemistry program tutor
    ·chemttr.zip
    Chemical turtor program
    ·chemview.zip
    educational, see 3D molecules with EGA
    ·chpal240.zip
    "Chemistry Pal" v2.40 chemistry tutor
    ·coll_it2.zip
    Collect-It v2.0 Manager
    ·cosmos12.zip
    excellent astronomy program
    ·cosmos6.zip
    a good astronomy program
    ·crimelab.zip
    Lesson in blood typing/fosics
    ·dna.zip
    DNA sequence analysis program for genetics
    ·ethics.zip
    the ethics of gene splicing
    ·flmplsr.zip
    Construction of a chemical Dye Laser
    ·genatics.zip
    biology tutor
    ·humble.zip
    How to build a Humble telescope
    ·hybrid.zip
    Cross-type Biological Species Program
    ·inttest.zip
    test of mental dexterity
    ·ise095.zip
    The Integral Scientist v0.95 Basic
    ·jssc.zip
    Jupiter planet simulator
    ·life050.zip
    LIFE simulation from Scientific American
    ·mbiology.zip
    Latest microbiology programs from Softor
    ·medstat.zip
    Data Analysis in Clinical Medicine
