محطات الطاقة الحرارية (Thermal Power Plants)
صفحة 7 من 15 الأولىالأولى ... 3 4 5 6 78 9 10 11 ... الأخيرةالأخيرة
النتائج 61 إلى 70 من 143
  1. [61]
    مهند عدنان جميل
    مهند عدنان جميل غير متواجد حالياً
    شكرا على الموضوع القيم اخوكم الفيزياوي مهند
  2. [62]
    مهند عدنان جميل
    شكرا على الموضوع القيم اخوكم الفيزيا ئي مهند
  3. [63]
    syrengineer
    syrengineer غير متواجد حالياً
    Combined Cycle Plants
    The combined-cycle unit combines the Rankine (steam turbine) and Brayton (gas turbine) thermodynamic cycles by using heat recovery boilers to capture the energy in the gas turbine exhaust gases for steam production to supply a steam turbine as shown in the figure "Combined-Cycle Cogeneration Unit". Process steam can be also provided for industrial purposes
    [IMG]file:///Z:/important/cc/Combined%20Cycle%20Plants%20-%20ملتقـــــى%20التدريـب%20العربـى_files/gascomb.gif[/IMG]
    Fossil fuel-fired (central) power plants use either steam or combustion turbines to provide the mechanical power to electrical generators. Pressurized high temperature steam or gas expands through various stages of a turbine, transferring energy to the rotating turbine blades. The turbine is mechanically coupled to a generator, which produces electricity.
    Steam Turbine Power Plants
    Steam turbine power plants operate on a Rankine cycle. The steam is created by a boiler, where pure water passes through a series of tubes to capture heat from the firebox and then boils under high pressure to become superheated steam. The heat in the firebox is normally provided by burning fossil fuel (e.g. coal, fuel oil or natural gas). However, the heat can also be provided by biomass, solar energy or nuclear fuel. The superheated steam leaving the boiler then enters the steam turbine throttle, where it powers the turbine and connected generator to make electricity.
    After the steam expands through the turbine, it exits the back end of the turbine, where it is cooled and condensed back to water in the surface condenser. This condensate is then returned to the boiler through high-pressure feedpumps for reuse.
    Heat from the condensing steam is normally rejected from the condenser to a body of water, such as a river or cooling tower.
    Steam turbine plants generally have a history of achieving up to 95% availability and can operate for more than a year between shutdowns for maintenance and inspections. Their unplanned or forced outage rates are typically less than 2% or less than one week per year.
    Modern large steam turbine plants (over 500 MW) have efficiencies approaching 40-45%.
    These plants have installed costs between $800 and$2000/kW,
    depending on environmental permitting requirements.
    Combustion (Gas) Turbines:
    Combustion turbine plants operate on the Brayton cycle. They use a compressor to compress the inlet air upstream of a combustion chamber. Then the fuel is introduced and ignited to produce a high temperature, high-pressure gas that enters and expands through the turbine section. The turbine section powers both the generator and compressor. Combustion turbines are also able to burn a wide range of liquid and gaseous fuels from crude oil to natural gas.
    The combustion turbine’s energy conversion typically ranges between 25% to 35% efficiency as a simple cycle. The simple cycle efficiency can be increased by installing a recuperator or waste heat boiler onto the turbine’s exhaust. A recuperator captures waste heat in the turbine exhaust stream to preheat the compressor discharge air before it enters the combustion chamber.
    A waste heat boiler generates steam by capturing heat form the turbine exhaust. These boilers are known as
    heat recovery steam generators (HRSG). They can provide steam for heating or industrial processes, which is
    called cogeneration. High-pressure steam from these boilers can also generate power with steam turbines, which is called a combined cycle (steam and combustion turbine operation). Recuperators and HRSGs can increase the combustion turbine’s overall energy cycle efficiency up to 80%.
    Combustion (natural gas) turbine development increased in the 1930’s as a means of jet aircraft propulsion. In the early 1980’s, the efficiency and reliability of gas turbines had progressed sufficiently to be widely adopted for stationary power applications. Gas turbines range in size from 30 kW (micro-turbines) to 250 MW (industrial frames). Industrial gas turbines have efficiencies approaching 40% and 60% for simple and combined cycles respectively.
    The gas turbine share of the world power generation market has climbed from 20 % to 40 % of capacity additions over the past 20 years with this technology seeing increased use for base load power generation. Much of this growth can be accredited to large (>500 MW) combined cycle power plants that exhibit low capital cost (less than $550/kW) and high thermal efficiency.
    The capital cost of a gas turbine power plant can vary between $35000-$950/kW with the lower end applying to large industrial frame turbines in combined cycle configurations. Availability of natural gas-fired plants can exceed 95%. In Canada, there are 28 natural gas-fired combined cycle and cogeneration plants with an average efficiency of 48 %. The average power output for each plant was 236 MW with an installed cost of around $ 500/kW.
    Simple Cycle Power Plants (Open Cycle)
    The modern power gas turbine is a high-technology package that is comprised of a compressor, combustor, power turbine, and generator, as shown in the figure "Simple-Cycle Gas Turbine".
    [IMG]file:///Z:/important/cc/Combined%20Cycle%20Plants%20-%20ملتقـــــى%20التدريـب%20العربـى_files/gasturb.gif[/IMG]]
    In a gas turbine, large volumes of air are compressed to high pressure in a multistage compressor for distribution to one or more combustion gases from the combustion chambers power an axial turbine that drives the compressor and the generator before exhausting to atmosphere. In this way, the combustion gases in a gas turbine power the turbine directly, rather than requiring heat transfer to a water/steam cycle to power a steam turbine, as in the steam plant. The latest gas turbine designs use turbine inlet temperatures of 1,500C (2,730F) and compression ratios as high as 30:1 (for aeroderivatives) giving thermal efficiencies of 35 percent or more for a simple-cycle gas turbine.
  4. [64]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة مهند عدنان جميل مشاهدة المشاركة
    شكرا مهندس مهند مرورك
    مع طيب الأماني.
  5. [65]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة syrengineer مشاهدة المشاركة
    مع الشكر الجزيل لهذا الكم من المعلومات
    الموجودة في الروابط
    بارك الله فيك
    وفي إضافتك المتميزة
    دمت ودامت إطلالتك على القسم مهندس syrengineer
  6. [66]
    قاسم محمد محمود
    قاسم محمد محمود غير متواجد حالياً
    بارك الله فيك يا دز محمد شرحبيل
  7. [67]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    بارك الله فيك أخي الفاضل مهند
    وحقيقة الفيزياء هي أساس الهندسة،
    فكل الظواهر الطبيعية تم ترجمتها بمعادلات رياضية وحلها
    وقام المهندس بتطبيق النظريات وتطويعها في الأمور العملية.
    شكرا مرورك.
  8. [68]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة قاسم محمد محمود مشاهدة المشاركة
    شكرا مرورك مهندس قاسم محمد محمود
    وجزاك الله كل خير
  9. [69]
    عماد سعيد كرمة
    عماد سعيد كرمة غير متواجد حالياً
    الصورة الرمزية عماد سعيد كرمة
    عاشت ايدك على هالموضوع بس ممكن سؤال هل يمكن في المحطة الواحدة يوجد هيتريين مغلق ومفتوح
  10. [70]
    nawar_mera
    nawar_mera غير متواجد حالياً
    شكرا الموضوع كلش حلو
