موسوعة ( أسئلة وهدايا ) - إدخل وأجب ولك هدية - Questions & Gifts
صفحة 30 من 37 الأولىالأولى ... 2026 27 28 29 3031 32 33 34 ... الأخيرةالأخيرة
النتائج 291 إلى 300 من 362
  1. [291]
    اسامة القاسى
    الصورة الرمزية اسامة القاسى
    اقتباس المشاركة الأصلية كتبت بواسطة احمد الغرباوي مشاهدة المشاركة
    casing
    casings are generally of two types: Volute and circular ( diffuser). The impellers are fitted inside the casings.
    volute casings build a higher head
    circular casings ( diffuser) are used for low head and high capacity
    volute is a curved funnel increasing in area to the discharge port as shown in figure. As the area of the cross-section increases, the volute reduces the speed of the liquid and increases the pressure of the liquid
    one of the main purposes of a volute casing is to help balance the hydraulic pressure on the shaft of the pump. However, this occurs best at the manufacturer's recommended capacity. Running volute-style pumps at a lower capacity than the manufacturer recommends can put lateral stress on the shaft of the pump, increasing wear-and-tear on the seals and bearings, and on the shaft itself. Double-volute casings are used when the radial thrusts become significant at reduced capacities.
    2-circular casing have stationary diffusion vanes surrounding the impeller periphery that convert velocity energy to pressure energy. Conventionally, the diffusers are applied to multi-stage pumps
    the casings can be designed either as solid casings or split casings. solid casing implies a design in which the entire casing including the discharge nozzle is all contained in one casting or fabricated piece. A split casing implies two or more parts are fastened together. When the casing parts are divided by horizontal plane, the casing is described as horizontally split or axially split casing. When the split is in a vertical plane perpendicular to the rotation axis, the casing is described as vertically split or radially split casing. Casing wear rings act as the seal between the casing and the impeller.
    وجزيت خيرا يا باش مهندس مصطفي علي هذا الموضوع الشيق والذي افادنا الكثير والكثير
    واقول لك ان المهندس
    اسامه القاسي يعتذر لعدم قدرته علي المشاركه في الاسئله بسبب وجود الامتحانات وسوف نعاود المشاركه انا وهو بعد الامتحانات ان شاء الله واقول لك انا اسامه يسألني كل يوم عن الاسئله التي تضعها في المنتدي ويسألني من فاز بالجائزة فهو مهتما بموضوعك جدا
    واخيرا انتظر تعليق حضرتك ع الاجابه والدعاء لنا في الامتحانات
    اخى الحبيب احمد اية الجمال دة واحشنى بجد والحمد لله الامتحانات خلصت بسلام وربنا يقدم مافية الخير " امين " وشكر واجب وضرورى لك لتوضيح سبب انقطاعى عن منتدانا الحبيب . وايضا شكر واجب على الاجابة المتميزة دى " بجد معلم " والباشمهندس مصطفى واحشنى والله وربنا يوفقة فى شوية المشاغل الى عندة وفى انتظارة باذن الله .
  2. [292]
    احمد محمد نجيب
    احمد محمد نجيب غير متواجد حالياً
    الصورة الرمزية احمد محمد نجيب
    Given: 6
    اية يا جماعة الاسالة فين انا كنت بدخل كل فترة كدة الاقي سوال جديد اتعلم منة حاجة جديدة واستفيد منة الجديد بس دلوقتي كل مادخل ملاقيش حاجة عايزين الاسئلة وها المتحانات خلصت يعني
    nageeb
  3. [293]
    important
    important غير متواجد حالياً
    بارك الله فيكم وجزاكم الله عنا كل خير
    شكر للمهندس مصطفى الذي إستحدث لنا هذه الموسوعه
    والشكر موصول لكل من افادنا عن طريق الموضوع
    المهندس محمد والمهندس اسامه وكل من شارك
    لابد من تجديد الموضوع لكي تعم الفائده سأحاول واتمنى منكم التفاعل معنا على إعادة هذا الموضوع
    للتعبير عن شكرنا العميق للمهندس مصطفى الذي سيكون تجديد الموضوع بمثابة الشكر له
    ونسأل الله العلي القدير ان يوفقه بحياته العمليه ونتمنى تواجده بيننا قريبا
    كل الود والإحترام
  4. [294]
    sosolovefun
    sosolovefun غير متواجد حالياً
    الصورة الرمزية sosolovefun
    مسمي طلمبات التفريغ خاطئ لأن فكرة عمل المضخة عموما هي تخفيض ضغط المائع اسفلها لجعل الضغط الجوي اعلي من الضغط عند فتحة دخول المضخة فيدفع المائع بداخل المضخة
  5. [295]
    sosolovefun
    وأقصي ضغط تفريغ هو الضغط الجوي لأنة إذا زاد عن ذلك فإن المضخة لن تسحب المائع
  6. [296]
    sosolovefun
    السعودية _ تبوك
    مسمي طلمبات التفريغ خاطئ لان فكرة عمل المضخة عموما هي تخفيض ضغط المائع عند فتحة الدخول للمضخة بحيث يصبح أقل من الضغط الجوي مما يدفع المائع لدخول المضخة وأقصي ضغط تفريغ هو الضغط الجوي لانة إذا زاد عن الضغط الجوي لن تسحب المضخة (حدوث ظاهرة الcavitation) وشكرا علي طرح سؤالك
  7. [297]
    ابو محمود
    ابو محمود غير متواجد حالياً
    الصورة الرمزية ابو محمود
    Received: 8
    Given: 15
    الاخ والاستاذ مصطفى
    الموضوع جميل وشيق وانا اول مرة اشوفه ويتميز بالمشاركه الايجابية والتفاعل الواضح والجميل وتبادل الاراء والتنافس
    وهى فكرة لاتخرج الا من عبقرى
    وبسم الله ماشاء الله هناك فعلا اقبال على هذه الصفحة والتى استحقت بجدارة التثبيت
    وان شاء الله سوف اداوم على المتابعه لعلى اكون من النشطيين والمجاوبين لاسلتكم
    وجزاكم الله خير جميعا
  8. [298]
    اسامة القاسى
    بعد غياب طويل الى حد ما : سؤال جديد " اذا كان لدينا طلمبة طاردة مركزية تعمل على ضخ مائع كثافتة ( الماء )1000kg/m3
    واستخدمنا نفس المضخة لضخ مائع اخر كثافتة 750kg/ m3 السؤال هل يتغير pump head؟؟؟؟؟؟؟؟؟ولماذا؟؟؟؟؟؟؟
  9. [299]
    amrhawash
    amrhawash غير متواجد حالياً
    الصورة الرمزية amrhawash
    Received: 9
    Given: 3
    اخوانى ضغط الطلمبة لازم يكون اقل من الضغط الجوى -ve pressure
    يجب الايقل عن ضغط البخار والا سوف يتبخر المائع ويحدث مشاكل للطمبة
  10. [300]
    eng.hosam
    eng.hosam غير متواجد حالياً
    ضغط التفريغ سالب الاشارة فقط للدلاله على التفريغ واقصى ضغط يمكن ان احصل عليه يتوقف على ما يسمى بال net postive suction head الخاص بالطلمبه
