ابحث عن بحث عن استخدام الخشب في البناء
النتائج 1 إلى 7 من 7
    حمزة ابو يحيى
    حمزة ابو يحيى غير متواجد حالياً
    anass81
    anass81 غير متواجد حالياً
    الصورة الرمزية anass81
    Received: 672
    Given: 721
    اقتباس المشاركة الأصلية كتبت بواسطة حمزة ابو يحيى مشاهدة المشاركة
    اخي الكريم, هل تبحث عن الابنية الخشبية Timber or wood structures ام عن استخدام مادة الخشب في البناء (مثل الكوفراج او الشدات) ؟.
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    Structural Timber Design to Eurocode 5
    Publisher: Wiley-Blackwell | Pages: 560 | 2008-01-10 | ISBN 1405146389 | PDF | 5 MB
    Structural Timber Design to Eurocode 5 is a comprehensive book which provides practising engineers and specialist contractors with detailed information and in-depth guidance on the design of timber structures based on the common rules and rules for buildings in Eurocode 5 - Part 1-1. It will also be of interest to undergraduate and postgraduate students of civil and structural engineering.
    The book provides a step-by-step approach to the design of all of the most commonly used timber elements and connections using solid timber, glued laminated timber or wood based structural products. It features numerous detailed worked examples, and incorporates the requirements of the UK National Annex.
    It covers the strength and stiffness properties of timber and its reconstituted and engineered products; the key requirements of Eurocode 0, Eurocode 1 and Eurocode 5 - Part 1-1; the design of beams and columns of solid timber, glued laminated, composite and thin-webbed sections; the lateral stability requirements of timber structures; and the design of mechanical connections subjected to lateral and/or axial forces as well as rigid and semi-rigid connections subjected to a moment.
    http://uploading.com/files/AKUKF34W/...ode_5.zip.html
    hassananas
    Received: 224
    Given: 6
    American Forest & Paper Association “Wood Frame Construction Manual (for One and Two-Family Dwellings)"
    American Forest & Paper Association | 2001 | ISBN:B000FBC03O | 12 pages | PDF | 4,8 Mb
    The Wood Frame Construction Manual (WFCM) for One- and Two-Family Dwellings, 2001Edition is an ANSI approved document that provides engineered and prescriptive requirements for wood frame construction based on dead, live, snow, seismic and wind loads derived from the 2000 International Building Code (IBC). Developed over a six-year period by AF&PA's WFCM/ANSI Canvass Committee, the WFCM represents a major milestone for the wood products industry. Designers and code enforcement officials now have one comprehensive design reference to provide solutions for residential wood construction, which is increasingly being regulated, especially in higher load regions. The WFCM includes design and construction provisions for connections, wall systems, floor systems, and roof systems. A range of structural elements are covered, including sawn lumber, structural glued laminated timber, wood structural sheathing, I-joists, and trusses. Also included are provisions approved by the 2000 IBC for perforated shearwalls, wall stud system factors, and increased capacities for shearwalls and diaphragms used in high wind applications.
    http://depositfiles.com/en/files/3450994/
    hassananas
    Received: 224
    Given: 6
    This major reference manual covers both overall and detail design of structural timber, including aspects such as shear deflection, creep, dynamic and lateral stability considerations for flexural members.
    Available for the first time in paperback, the Third Edition was substantially revised to take account of the many changes since the previous edition was published in 1984. It is based on British Standard BS 5268-2: 2002, which brought design concepts closer to European practice and Eurocode 5.
    http://uploadbox.com/files/532bcc101c
    http://uploading.com/files/FGF7QC7A/...46710.rar.html
    anass81
    Received: 672
    Given: 721
    جزاك الله خيرا اخي hassananas على هذه الكتب القيمة في Timber design
    سعيد محمود على
    سعيد محمود على غير متواجد حالياً
    ردود رائعه لايسعنى الا شكركم
