الأضواء الخارجية للطائرة مهامها وماذا تعني
النتائج 1 إلى 10 من 12
    الصورة الرمزية شفق الصباح
    شفق الصباح
    شفق الصباح غير متواجد حالياً
    Aircraft Lights & Beacons
    I assume you are referring to the lights located along the exterior of most aircraft, particularly commercial airliners. Planes are equipped with a variety of lights that are used for navigation, safety, and to improve visibility during flight or when taxiing on the ground. Some of the most important exterior lights carried by commercial airliners can be seen in the below photo of a Boeing 737
    Boeing 737 showing common types of lights placed on aircraft
    The external lights on aircraft fall into two general categories. The first is navigation lights or beacons that are always illuminated while the aircraft is in operation. A second type includes takeoff and landing lights that are used to improve visibility when the plane is close to or on the ground. Several of these lights are discussed in greater detail below.
    Navigation lights:
    All aircraft are equipped with a steady light near the leading edge of each wingtip. When facing forward from the perspective of the pilot, the light on the right wingtip is green while that on the left wing is red. The different colors make it possible for an outside observer, such as the pilot of another aircraft, to determine which direction the plane is flying. These navigation lights are most useful at night when it is more difficult to tell the direction the plane is going without them.
    Navigation or Position lights:
    In addition to the red and green lights, most planes are also fitted with other steady white navigation lights in various locations. Large airliners, in particular, will often have such lighting on the trailing edge of each wingtip. These lights are also sometimes placed along the trailing edges of the horizontal tail. Another popular location is at the very aft end of the fuselage or at the top of the vertical tail. One of these latter lights placed along the aircraft centerline is especially common on smaller airliners and commuter planes. Whatever the location, the purpose of these steady white lights is to improve the plane's visibility from behind the aircraft.
    Anti-Collision Beacon lights:
    Two beacon lights are fitted to aircraft near the center of the fuselage. One is located on top of the fuselage and the other on the bottom. These lights are colored reddish orange and rotate to produce a flashing effect. The beacons are turned on just before the engines are started and they remain active until the last engine is shut down. The beacons help to serve as a safety warning to ground personnel that the engines are operational.
    Strobe lights:
    High-intensity strobe lights that flash a white-colored light are located on each wingtip. Most smaller planes are only equipped with one of these strobes near the leading edge just behind the red or green navigation light. Larger airliners may be equipped with an additional strobe at the trailing edge as well. These flashing lights are very bright and intended to attract attention during flight. They are sometimes also used on the runway and during taxi to make the plane more conspicuous.
    Logo lights:
    These lights are not required but are common on most commercial aircraft. The lights are usually located on the surface of or at the tips of the horizontal stabilizer. The steady white lights are used to illuminate the company's logo painted on the vertical tail. While useful for advertising, the primary purpose of these lights is safety since the bright lights help to make the plane more visible.
    Explanation of the lights used on the MD-11
    Wing lights:
    Many airliners feature lights along the root of the wing leading edge that can be used to illuminate the wing and engine pylons in flight. These lights may be used to make the plane more visible during takeoff and landing or to inspect the wings for damage in flight. Pilots can also use the wing lights to inspect the wings and slats for any ice accretion that might build up when flying through clouds.
    Taxi lights:
    A bright white lamp is located on the nose landing gear strut of most planes. This light is typically turned on whenever the aircraft is in motion on the ground for greater visibility during taxi, takeoff, and landing.
    Landing lights:
    Bright white landing lights are usually fitted to most planes for enhanced visibility during the landing approach. These lights can also be used to illuminate the runway at poorly lit airports. They are often required for night landings but also commonly used during the day as well to make the plane more noticeable. While the usage of these lights is common, their location can vary from plane to plane. Landing lights may be located in the wing root, in the outboard wing, or somewhere along the forward fuselage. Some aircraft are equipped with multiple sets of landing lights in more than one of these locations. The 737, for example, has inboard landing lights located in the wing root as well as outboard landing lights in the outboard flap fairings.
    Runway Turnoff lights:
    Usually located in the leading edge of the wing root, these bright white lamps are intended to provide side and forward lighting during taxi and when turning off the runway. These lights are most useful at poorly lit airports but are usually unnecessary. The lights can also be used in flight if greater visibility is required.
    Wheel Well lights:
    Some planes are equipped with additional lights in the nose and main gear wheel wells. These lights are provided primarily to assist ground personnel in making pre-flight inspections of a plane at night.
    Taxi, landing, and turnoff lights visible on the Boeing 777
    The locations of some of these lights can be seen in the above photo of a Boeing 777. To read more about the importance of lighting and aviation safety, you might want to check out two FAA publications called the Pilot's Handbook of Aeronautical Knowledge and the Airplane Flying Handbook.
    المصدر http://www.amazon.com/exec/obidos/AS...rospacewebo-20
    بدري علي
    بدري علي غير متواجد حالياً
    الصورة الرمزية بدري علي
    السللام عليكم
    يعطيك العافية موضوع جميل
    مهندس أيمن حسن
    الصورة الرمزية مهندس أيمن حسن
    Received: 96
    Given: 12
    it's the first time to know that
    i asked my self many times about what do these lights mean
    thanks soo much
    شفق الصباح
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس أيمن حسن مشاهدة المشاركة
    thanks soo much
    [quote=بدري علي;1023771]السللام عليكم
    بارك الله فيكم شباب وشكراً لكم علي المرور
    كن جميلاً تري الوجود جميلاً
    haytham9d
    haytham9d غير متواجد حالياً
    جزاك الله خيرا على هذه المعلومات المفيدة
    محمد زرقة
    محمد زرقة غير متواجد حالياً
    الصورة الرمزية محمد زرقة
    شكرااااااااااااااااااااااااااااااااااااااااااااااا ااااااااااً على المعلومات القيمه
    سوسنة سوداء
    سوسنة سوداء غير متواجد حالياً
    thanks so much
    مهندس قيس
    مهندس قيس غير متواجد حالياً
    موضوع جميل جدا شكرا لك اخي العزيز
    شفق الصباح
    اقتباس المشاركة الأصلية كتبت بواسطة haytham9d مشاهدة المشاركة
    اقتباس المشاركة الأصلية كتبت بواسطة محمد زرقة مشاهدة المشاركة
    اقتباس المشاركة الأصلية كتبت بواسطة سوسنة سوداء مشاهدة المشاركة
    thanks so much
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس قيس مشاهدة المشاركة
    مشكورين شبابب علي المرور والتعقيب
    م_حيدر سامي علم
    م_حيدر سامي علم غير متواجد حالياً
    موضوع مهم
    جزيل الشكر
