موسوعة الألف سؤال فى الهندسة الميكانيكية - إدخل وأجب - 1000
صفحة 6 من 7 الأولىالأولى ... 2 3 4 5 67 الأخيرةالأخيرة
النتائج 51 إلى 60 من 69
  1. [51]
    S_G
    S_G غير متواجد حالياً
    شكرا جزيلا جزاك الله خيرا
  2. [52]
    مصطفى الوكيل
    الصورة الرمزية مصطفى الوكيل
    Received: 61
    الأسئلة من 121 - 130
    121
    Name few MOC of seal faces
    122
    What is seal ring and mating ring
    123
    How many elastomers are used in a mechanical seal assembly
    124
    Name few snap ring in a mechanical seal
    125
    What is snap ring in a mechanical seal
    126
    What are the usual problems faced with mechanical seals
    127
    Does the rotor axial float have something to do with mechanical seal
    128
    What is double mechanical seal
    129
    Why double mechanical seal is used
    130
    Name the two types of double mechanical seal
    مهندس إستشارى / مصطفى الوكيل
    Zuhair Fayez
  3. [53]
    مصطفى الوكيل
    Received: 61
    الأسئلة من 131 - 140
    131
    Where is double mechanical seal used
    132
    What do you mean by barrier fluid
    133
    Name one barrier fluid
    134
    What do you mean by buffer fluid
    135
    Name one buffer fluid
    136
    What is the difference between barrier fluid and buffer fluid
    137
    Where do we use cyclone separator in mechanical seal
    138
    What is pumping ring in a mechanical seal
    139
    What is purpose of pumping ring in a mechanical seal
    140
    What is the difference between inside mounted seal & outside mounted seal
    Zuhair Fayez
  4. [54]
    مصطفى الوكيل
    Received: 61
    الأسئلة من 141 - 150
    141
    What is seal balance ratio
    142
    What is the seal balance ratio for balanced/unbalanced seal
    143
    What are the main differences between centrifugal pump and reciprocating pump
    144
    How do you measure valve lift in reciprocating pump
    145
    What is the necessity of pulsation damper
    146
    Name few types of pulsation damper
    147
    How do you fill up gas in an accumulator
    148
    Explain overhauling sequence for reciprocating pump
    149
    What is web deflection
    150
    How do you measure web deflection
    Zuhair Fayez
  5. [55]
    مصطفى الوكيل
    Received: 61
    الأسئلة من 151 - 160
    151
    How to check big end bearing & small end bush clearance
    152
    What do you mean by stroke length
    153
    What is gudgeon pin
    154
    What is cross head slide/shoe
    155
    Name few ways of locking arrangement of piston/plunger
    156
    How to ensure in-line concentricity of crankshaft to cylinder bore
    157
    What are dosing pump
    158
    Name few types of dosing pump
    159
    What for dosing pumps are used
    160
    What are the probable reasons for cylinder knocking in a reciprocating pump
    Zuhair Fayez
  6. [56]
    مصطفى الوكيل
    Received: 61
    الأسئلة من 161 - 170
    161
    What are the probable reasons for valve knocking in reciprocating pump
    162
    What are the probable reasons for vibration in a reciprocating pump
    163
    Where do we use screw pumps & gear pumps
    164
    What do you mean by flute
    165
    What is idler screw
    166
    How drive is transmitted to idler screw
    167
    How do you measure radial clearance & axial clearance between flutes
    168
    How do you measure gear backlash
    169
    What is the usual gear hardness value
    170
    Name few parts of a centrifugal compressor
    Zuhair Fayez
  7. [57]
    ابا
    ابا غير متواجد حالياً
    هل من الممكن اضافة نسخه عربيه من السؤال والاجابه حتي يستفيد منها الفنين اللذين يعملون في هذا المجال
    واشكرك علي هذا الموضوع والفكره العبقريه
  8. [58]
    مصطفى الوكيل
    Received: 61
    اقتباس المشاركة الأصلية كتبت بواسطة ابا مشاهدة المشاركة
    آسف صعب جدا التعريب فى مثل هذه الأسئلة لكن سنحاول ، مع إنى أفضل أن تترجم الأسئلة أنت وتحاول فهمها ستكون الفائدة مضاعفة
    Zuhair Fayez
  9. [59]
    مصطفى الوكيل
    Received: 61
    الأسئلة من 171 - 180
    171
    What is the applicable standard for centrifugal compressor
    172
    How do you specify a centrifugal/horizontally split compressor
    173
    Explain the over hauling steps for a Barrel type centrifugal compressor
    174
    How do you center a compressor rotor
    175
    How do you check labyrinth clearance for a Barrel type centrifugal compressor
    176
    What is the compound used in the split half of the casing
    177
    How do you leak check a barrel type compressor
    178
    Explain the overhauling steps for a horizontally split type centrifugal compressor
    179
    Name the different types of labyrinth
    180
    How do you measure labyrinth clearance in barrel type compressor
    Zuhair Fayez
  10. [60]
    مصطفى الوكيل
    Received: 61
    الأسئلة من 181 - 190
    181
    How do you measure labyrinth clearance in horizontally split type compressor
    182
    What is diaphragm
    183
    What is diaphragm delta P and what is the maximum value allowed
    184
    What is balance piston
    185
    What is balance piston delta P & what is its normal value
    186
    What is bridge over arrangement
    187
    Draw the lub. Oil circuit
    188
    What is the lub Oil run down tank
    189
    What is the normal filtration size of LO & SO filter
    190
    Draw the seal oil circuit
    Zuhair Fayez
