تعاريف و مصطلحات مهمة للتعامل خاصة مع الإستشاري - Definitions and Terms
النتائج 1 إلى 10 من 19
    الصورة الرمزية مصطفى الوكيل
    مصطفى الوكيل
    Received: 61
    Definitions & Terms
    General
    A.
    Furnish. Except as otherwise defined in greater detail, the term furnish is used to mean “supply and deliver to the project site, ready for unloading, unpacking, assembly, installation, and similar operations” as applicable to each instance.
    B.
    Install. Except as otherwise defined in greater detail, the term install is used to describe operations at the project site including actual “unloading, unpacking, assembly, erection, placing, anchoring, connecting, applying, working to dimension, finishing, curing, protecting, testing to demonstrate satisfactory operation, cleaning and similar operations” as applicable in each instance.
    C.
    Provide. Except as otherwise defined in greater detail, the term provide means to furnish and install, complete and ready for intended use and successfully tested to demonstrate satisfactory operation as applicable in each instance.
    D.
    Remove. Except as otherwise defined in greater detail, the term remove means to disassemble, dismantle, and/or cut into pieces in order to remove the equipment from the site and to properly dispose of the removed equipment and pay for all associated
    costs incurred.
    E. Replace. Except as otherwise defined in greater detail, the term replace means to remove the existing equipment and to provide new equipment of the same size, capacity, electrical characteristics, function, etc., as the existing equipment.
    F. Relocate. Except as otherwise defined in greater detail, the term relocate means to carefully remove without damaging item and to install where shown on the contract documents and/or as directed by the Engineer and/or Owner.
    G. Shall. Shall indicates action which is mandatory on the part of the Contractor.
    H. Will. Will indicates action which is probable on the part of the Contractor.
    I. Should. Should indicates action which is probable on the part of the Contractor.
    J. May. May indicates action which is permissible on the part of the Contractor.
    K. Indicated. The term indicated is a cross-reference to graphic representations, details, notes, or schedules on the drawings; to other paragraphs or schedules in the specifications; and to similar means of recording requirements in the Contract Documents.
    Where terms such as shown, noted, scheduled, and specified are used in lieu of indicated, it is for the purpose of helping the reader locate the cross-reference, and no limitation is intended except as specifically noted.
    L. Shown. The term shown is a cross-reference to graphic representations, details, notes, or schedules on the Contract Drawings and to similar means of recording requirements in the Contract Documents.
    M. Detailed. The term detailed is a cross-reference to graphic representations, details, notes, or schedules on the Contract Drawings and to similar means of recording requirements in the Contract Documents.
    N. Specified. The term specified is a cross-reference to paragraphs or schedules in the specifications and to similar means of recording requirements in the Contract Documents. The specifications include the General Provisions, Special Provisions,
    and the Technical Specifications for the project.
    O. Including, Such as. The terms including and such as shall always be taken in the most inclusive sense, namely “including, but not limited to” and “such as, but not limited to.”
    P. Supply, Procurement. The terms supply and procurement shall mean to purchase, procure, acquire, and deliver complete with related accessories.
    Q. At no additional cost. The phrase “at no additional cost” shall mean at no additional cost to the Owner and at no additional cost to the Engineer or Construction Manager.
    R. Approved, Accepted. Where used in conjunction with the Engineer’s response to submittals, requests, applications, inquiries, reports, and claims by the Contractor, the meaning of the terms approved and accepted shall be held to the limitations
    of the Engineer’s responsibilities to fulfill requirements of the Contract Documents. The terms approved and accepted shall also mean to permit the use of material, equipment, or methods conditional upon compliance with the Contract Documents.
    S. Approved Equal, Approved Equivalent. The terms approved equal and approved equivalent shall mean possessing the same performance qualities and characteristics and fulfilling the same utilitarian function and approved by the Engineer.
    T. Directed, Requested, Required, etc. Where not otherwise explained, terms such as directed, requested, required, authorized, selected, approved, accepted, designated, prescribed, ordered, and permitted mean “directed by the Engineer,” “requested by the Engineer,” “required by the Engineer,” and similar phrases. However, no such implied meaning will be interpreted to expand the Engineer’s responsibility into the Contractor’s area of construction supervision.
    U. Review. The term review shall mean limited observation or checking to ascertain general conformance with design concept of the Work and with information given in the Contract Documents. Such action does not constitute a waiver or alteration of
    the Contract Document requirements.
    V. Suitable, Reasonable, Proper, Correct, and Necessary. Such terms shall mean as suitable, reasonable, proper, correct, or necessary for the purpose intended as required by the Contract Documents, subject to the judgment of the Engineer or the
    W. Option. The term option shall mean a choice from the specified products, manufacturers, or procedures which shall be made by the Contractor. The choice is not “whether” the Work is to be performed, but “which” product, “which” manufacturer,
    or “which” procedure is to be used. The product or procedure chosen by the Contractor shall be provided at no increase or additional cost to the Owner, Engineer, or Construction Manager and with no lessening of the Contractor’s responsibility for its
    performance.
    X. Similar. The term similar shall mean generally the same but not necessarily identical; details shall be worked out in relation to other parts of the work.
    Y. Submit. The term submit shall mean, unless otherwise defined in greater detail, transmit to the Engineer for approval, information, and record.
    Z. Project Site, Work Site. The term project site shall be defined as the space available to the Contractor for performance of the Work, either exclusively or in conjunction with others performing other Work as part of the project or another project. The extent of the project site is shown on the drawings or specified and may or may not be identical with the land upon which the project is to be built. The project site boundaries may include public streets, highways, roads, interstates, etc., public easements, and property under ownership of someone other than the Client and are not available for performance of Work.
    AA. Testing Laboratories. The term testing laboratories shall be defined as an independent entity engaged to perform specific inspections or tests of the Work, either at the project site or elsewhere, and to report and, if required, interpret the results of
    those inspections or tests.
    BB. Herein. The term herein shall mean the ******* or *******s of a particular section where this term appears.
    CC. Singular Number. In all cases where a device or part of equipment or system is herein referred to in the singular number (such as fan, pump, cooling system, heating system, etc.) it is intended that such reference shall apply to as many such items
    as are required by the Contract Documents and to complete the installation.
    DD. No Exception Taken. The term no exception taken shall mean the same as approved.
    EE. Approved as Noted, Make Corrections Noted, or Revise—No Resubmittal Required. The terms approved as noted, make corrections noted, and revise—no resubmittal required shall mean the submittal essentially complies with the Contract Documents except for a few minor discrepancies that have been annotated
    directly on the submittal that will have to be corrected on the submittal and the Work correctly installed in the field by the Contractor.
    FF. Revise and Resubmit. The term revise and resubmit shall mean the Contractor shall revise the submittal to conform with the Contract Documents by correcting moderate errors, omissions, and/or deviations from the Contract Documents and resubmit it for review prior to approval and before any material and/or equipment
    can be fabricated, purchased, or installed by the Contractor.
    GG. Disapproved/Resubmit. The term disapproved/resubmit shall mean the Contractor shall revise the submittal to conform with the Contract Documents by correcting serious errors, omissions, and/or deviations from the Contract Documents and
    resubmit it for review prior to approval and before any material and/or equipment can be fabricated, purchased, or installed by the Contractor.
    HH. Disapproved or Rejected. The terms disapproved and rejected shall mean the Contractor shall discard and replace the submittal because the submittal did not comply with the Contract Documents in a major way.
    II. Submit Specified Item. The term submit specified item shall mean the Contractor shall discard and replace the submittal with a submittal containing the specified items because the submittal contained improper manufacturer, model number, material, etc.
    JJ. Acceptance. The formal acceptance by the Owner or Engineer of the Work, as evidenced by the issuance of the Acceptance Certificate.
    KK. Contract Item, Pay Item, Contract Fixed Price Item. A specifically described item of Work which is priced in the Contract Documents.
    LL. Contract Time, Time of Completion. The number of Calendar Days (not working days) set forth in the Contract Documents for completion of the Work.
    MM.Failure. Any detected inability of material or equipment, or any portion thereof, to function or perform in accordance with the Contract Documents.
    NN. Substantial Completion. Substantial completion shall be defined as the sufficient completion and accomplishment by the Contractor of all Work or designated portions thereof essential to fulfillment of the purpose of the Contract, so the Owner
    can occupy or utilize the Work or designated portions thereof for the use for which it is intended.
    OO. Final Completion, Final Acceptance. Final completion or final acceptance shall be defined as completion and accomplishment by the Contractor of all Work including contractual administrative demobilization Work, all punch list items, and all other Contract requirements essential to fulfillment of the purpose of the Contract,
    so the Owner can occupy or utilize the Work for the use for which it is intended.
    PP. Pre-Final Inspection or Observation. The term pre-final inspection or observation shall be held to the limitations of the Engineer’s responsibilities to fulfill the requirements of the Contract Documents and shall not relieve the Contractor from
    Contract obligations. The term pre-final inspection shall also mean all inspections conducted prior to the final inspection by the Owner, the Engineer, or both, verifying that all the Work, with the exception of required contractual administrative demobilization
    work, inconsequential punch list items, and guarantees, has been satisfactorily completed in accordance with the Contract Documents.
    QQ. Final Inspection or Observation. The term final inspection or observation shall be held to the limitations of the Engineer’s responsibilities to fulfill the requirements of the Contract Documents and shall not relieve the Contractor from Contract obligations. The term final inspection shall also mean the inspection conducted by the Owner, the Engineer, or both, verifying that all the Work, with the exception of required contractual administrative demobilization work, inconsequential punch list items, and guarantees, has been satisfactorily completed in accordance with the Contract Documents.
    RR. Reliability. The probability that a system will perform its intended functions without failure and within design parameters under specified operating conditions for which it is designed and for a specified period of time.
    SS. Testing. The term testing may be described as the inspection, investigation, analysis, and diagnosis of all systems and components to assure that the systems are operable, meet the requirements of the Contract Documents, and are ready for
    operation. Included are such items as:-
    1. Verification that the system is filled with water and is not air bound.
    2. Verification that expansion tanks of the proper size are connected at the correct locations and that they are not water logged.
    3. Verification that all system components are in proper working order and properly installed. Check for proper flow directions.
    4. Checking of all voltages for each motor in the system.
    5. Checking that all motors rotate in the correct direction and at the correct speed.
    6. Checking all motors for possible overload (excess amperage draw) on initial start-up.
    7. Checking of each pump for proper alignment.
    8. Checking all systems for leaks, etc.
    9. Checking all systems and components to assure that they meet the Contract Document requirements as far as capacity, system operation, control function, and other items required by the Contract Documents.
    TT. Adjusting. The term adjusting may be described as the final setting of balancing devices such as dampers and valves, in addition to automatic control devices, such as thermostats and pressure/temperature controllers to achieve maximum system
    performance and efficiency during normal operation. Adjusting also includes final adjustments for pumps by regulation of motor speed, partial close-down of pump discharge valve or impeller trim (preferred over the partial close-down of pump discharge valve).
    UU. Balancing. The term balancing is the methodical regulation of system fluid flow-rates (air and water) through the use of workable and industry accepted procedures as specified to achieve the desired or specified flow quantities (CFM or GPM) in each segment (main, branch, or sub-circuit) of the system.
    VV. Commissioning. The term commissioning is the methodical procedures and methods for documenting and verifying the performance of HVAC systems so that the systems operate in conformity with the design intent. Commissioning will include testing; adjusting; balancing; documentation of occupancy requirements and design assumptions; documentation of design intent for use by contractors, owners, and operators; functional performance testing and documentation necessary for evaluating the HVAC systems for acceptance; adjusting the HVAC systems to meet actual occupancy needs within the capability of the systems. Commissioning does not include system energy efficiency testing or testing of other building systems such as envelope, structure, electrical, lighting, plumbing, fire protection, and life safety. The purpose of commissioning of HVAC systems is to achieve the end result of a fully functional, fine-tuned HVAC system.
    WW.Functional Performance Testing. The term functional performance testing shall mean the full range of checks and tests carried out to determine if all components, sub-systems, systems, and interfaces between systems function in accordance with
    the contract documents. In this context, function includes all modes and sequences of control operation, all interlocks and conditional control responses, and all specified responses to abnormal emergency conditions.
    XX. Confined Spaces. Confined spaces (according to OSHA Regulations) are spaces which must have these three characteristics:-
    1. The space must be large enough and configured to permit personnel to enter and work.
    2. The space is not designed for continuous human occupancy.
    3. The space has limited or restricted means of entry and exit.
    There are two categories of confined spaces:-
    1. Non-Permit Required Confined Spaces (NRCS). Spaces which contain no physical hazards that could cause death or series physical harm, and there is no possibility that it contains any atmospheric hazards.
    2. Permit Required Confined Spaces (PRCS). Spaces which contain or may contain a hazardous atmosphere (atmospheric hazards—oxygen deficiency or enrichment 19.5% acceptable minimum and 23.5% acceptable maximum; flammable contaminants; and toxic contaminants—product, process, or reactivity); a liquid or finely divided solid material such as grain, pulverized coal, etc., that could surround or engulf a person; or some other recognized serious safety or health hazard such as temperature extremes or mechanical or electrical hazards (boilers, open transformers, tanks, vaults, sewers, manholes, pits, machinery enclosures, vats, silos, storage bins, rail tank cars, process or reactor vessels).
    YY. Hazardous Location Classifications
    1. Hazardous locations are those areas where a potential for explosion and fire exist because of flammable gases, vapors, or dust in the atmosphere, or because of the presence of easily ignitable fibers or flyings in accordance with the National Electric Code (NEC—NFPA 70).
    2. Class I Locations. Class I locations are those locations in which flammable gases or vapors are or may be present in the air in quantities sufficient to produce explosive or ignitable mixtures.
    a. Class I, Division 1 Locations. These are Class I locations where the hazardous atmosphere is expected to be present during normal operations. It may be present continuously, intermittently, periodically, or during normal repair or maintenance operations. Division 1 locations are also those locations where a breakdown in the operation of processing equipment results in the release of hazardous vapors while providing a source of ignition with the simultaneous failure of electrical equipment.
    b. Class I, Division 2 Locations. These are Class I locations in which volatile flammable liquids or gases are handled, processed, or used, but in which they can escape only in the case of accidental rupture or breakdown of the containers or systems. The hazardous conditions will occur only under abnormal conditions.
    3. Class II Locations. Class II locations are those locations that are hazardous because of the presence of combustible dust.
    a. Class II, Division 2 Locations. These are Class II locations where combustible dust may be in suspension in the air under normal conditions in sufficient quantities to produce explosive or ignitable mixtures. This may occur continuously, intermittently, or periodically. Division 1 locations also exist where failure or malfunction of machinery or equipment might cause a hazardous location to exist while providing a source of ignition with the simultaneous failure of electrical equipment. Included also are locations in which combustible dust of an electrically conductive nature may be present.
    b. Class II, Division 2 Locations. These are Class II locations in which combustible dust will not normally be in suspension in the air and normal operations will not put the dust in suspension, but where accumulation of the dust may interfere with the safe
    dissipation of heat from electrical equipment or where accumulations near electrical equipment may be ignited by arcs, sparks, or burning material from the equipment.
    4. Class III Locations. Class III locations are those locations that are hazardous because of the presence of easily ignitable fibers or flyings, but in which the fibers or flyings are not likely to be in suspension in the air in quantities sufficient to produce ignitable mixtures.
    a. Class III, Division 1 Locations. These are locations in which easily ignitable fibers or materials producing combustible flyings are handled, manufactured, or used.
    b. Class III, Division 2 Locations. These locations are where easily ignitable fibers are stored or handled.
    تابعونا --------------------------->
    مصطفى الوكيل
    Received: 61
    Systems
    Systems
    A.
    Mechanical Systems. The term mechanical systems shall mean for the purposes of these Contract Documents all heating, ventilating, and air conditioning systems and all piping systems as specified and as shown on the Mechanical Drawings and all services and appurtenances incidental thereto.
    B. Plumbing Systems. The term plumbing systems shall mean for the purposes of these Contract Documents all plumbing fixtures, plumbing systems, piping systems, and all fire protection systems as specified and as shown on the Plumbing and/or Fire Protection Drawings and all services and appurtenances incidental thereto.
    C. Ductwork. The term ductwork shall include ducts, fittings, flanges, dampers, insulation, hangers, supports, access doors, housings, and all other appurtenances comprising a complete and operable system.
    1. Supply Air Ductwork. The term supply air ductwork shall mean for the purposes of these Contract Documents all ductwork carrying air from a fan or air handling unit to the room, space, or area to which it is introduced. The air may be conditioned or unconditioned. Supply air ductwork extends from the fan or air handling unit to all the diffusers, registers, and grilles.
    2. Return Air Ductwork. The term return air ductwork shall mean for the purposes of these Contract Documents all ductwork carrying air from a room, space, or area to a fan or air handling unit. Return air ductwork extends from the registers, grilles, or other
    return openings to the return fan (if used) and the air handling unit.
    3. Exhaust Air Ductwork. The term exhaust air ductwork shall mean for the purposes of these Contract Documents all ductwork carrying air from a room, space, area, or equipment to a fan and then discharged to the outdoors. Exhaust air ductwork extends from the registers, grilles, equipment, or other exhaust openings to the fan and from the fan to the outdoor discharge point.
    4. Relief Air Ductwork. The term relief air ductwork shall mean for the purposes of these Contract Documents all ductwork carrying air from a room, space, or area without the use of a fan or with the use of a return fan to be discharged to the outdoors. Relief air ductwork extends from the registers, grilles, or other relief openings to the outdoor discharge point or from the return fan discharge to the outdoor discharge point.
    5. Outside Air Ductwork. The term outside air ductwork shall mean for the purposes of these Contract Documents all ductwork carrying un-conditioned air from the outside to a fan or air handling unit. Outdoor air ductwork extends from the intake point or louver to the fan, air handling unit, or connection to the return air ductwork.
    6. Mixed Air Ductwork. The term mixed air ductwork shall mean for the purposes of these Contract Documents all ductwork carrying a mixture of return air and outdoor air. Mixed air ductwork extends from the point of connection of the return air and outdoor air ductwork to the fan or air handling unit.
    7. Supply Air Plenum. The term supply air plenum shall mean for the purposes of these Contract Documents all ductwork in which the discharges of multiple fans or air handling units connect forming a common supply header or all ductwork or ceiling construction forming a common supply box where supply air ductwork discharges into the box at limited locations for air distribution to supply diffusers which are directly connected
    to the plenum.
    8. Return Air Plenum. The term return air plenum shall mean for the purposes of these Contract Documents all ductwork in which the suctions of multiple return fans or the discharges of multiple return fans connect forming a common suction or discharge return header or the space above the architectural ceiling and below the floor or roof structure used as return air ductwork.
    9. Exhaust Air Plenum. The term exhaust air plenum shall mean for the purposes of these Contract Documents all ductwork in which the suctions of multiple exhaust fans or the discharges of multiple exhaust fans connect forming a common suction or discharge exhaust header or the ductwork formed around single or multiple exhaust air discharge openings or louvers to create a connection point for exhaust air ductwork.
    10. Relief Air Plenum. The term relief air plenum shall mean for the purposes of these Contract Documents all ductwork in which multiple relief air ductwork connections are made forming a common relief air header.
    11. Outdoor Air Plenum. The term outdoor air plenum shall mean for the purposes of these Contract Documents all ductwork in which the suctions of multiple fans or air handling units connect to form a common outside air header or the ductwork formed around single or multiple outside air openings or louvers to create a connection point for outside air ductwork.
    12. Mixed Air Plenum. The term mixed air plenum shall mean for the purposes of these Contract Documents all ductwork in which multiple return air and multiple outdoor air ductwork connections are made forming a common mixed air header.
    13. Vents, Flues, Stacks, and Breeching. The terms vents, flues, stacks, and breeching shall mean for the purposes of these Contract Documents ductwork conveying the products of combustion to atmosphere for safe discharge.
    D. Piping. The term piping shall include pipe, fittings, valves, flanges, unions, traps, drains, strainers, insulation, hangers, supports, and all other appurtenances comprising a complete and operable system.
    E. Wiring. The term wiring shall include wire, conduit, raceways, fittings, junction and outlet boxes, switches, cutouts, receptacles, and all other appurtenances comprising a complete and operable system.
    F. Product. The term product shall include materials, equipment, and systems for a complete and operable system.
    G. Motor Controllers. The term motor controllers shall be manual or magnetic starters (with or without switches), individual push buttons, or hand-off-automatic (HOA) switches controlling the operation of motors.
    H. Control Devices. The term control devices shall be automatic sensing and switching devices such as thermostats, float and electro-pneumatic switches controlling the operations of mechanical and electrical equipment.
    I. Work, Project. The terms work and project shall mean labor, operations, materials, supervision, services, machinery, equipment, tools, supplies, and facilities to be performed or provided including Work normally done at the location of the project to accomplish the requirements of the Contract including all alterations, amendments, or extensions to the Contract made by Change Order.
    J. Extra Work. The term extra work shall be any item of Work not provided for in the awarded Contract as previously modified by change order (change bulletin) or supplemental agreement, but which is either requested by the Owner or found by the Engineer to be necessary to complete the Work within the intended scope of the Contract as previously modified.
    K. Concealed. The term concealed shall mean hidden from normal sight; includes Work in crawl spaces, above ceilings, in chases, and in building shafts.
    L. Exposed. The term exposed shall mean not concealed.
    M. Below Ground. The term below ground shall mean installed under ground, buried in the earth, or buried below the ground floor slab.
    N. Above Ground. The term above ground shall mean not installed under ground, not buried in the earth, and not buried below the ground floor slab.
    O. Conditioned. The term Conditioned shall mean for the purposes of these Contract Documents rooms, spaces, or areas that are provided with mechanical heating and cooling.
    P. Un-Conditioned and Non-Conditioned. The terms un-conditioned and nonconditioned shall mean for the purposes of these Contract Documents rooms, spaces, or areas that are not provided with mechanical heating or cooling.
    Q. Heated. The term heated shall mean for the purposes of these Contract Documents rooms, spaces, or areas that are provided with mechanical heating only.
    R. Air Conditioned. The term air conditioned shall mean for the purposes of these Contract Documents rooms, spaces, or areas that are provided with mechanical cooling
    only.
    S. Unheated. The term unheated shall mean for the purposes of these Contract Documents rooms, spaces, or areas that are not provided with mechanical heating.
    T. Ventilated Spaces. The term ventilated spaces shall mean for the purposes of these Contract Documents rooms, spaces, or areas supplied with outdoor air on a continuous or intermittent basis. The outdoor air may be conditioned or unconditioned.
    U. Indoor. The term indoor shall mean for the purposes of these Contract Documents items or devices contained within the confines of a building, structure, or facility and items or devices which are not exposed to weather. The term indoor shall generally reference ductwork, piping, or equipment location (indoor ductwork, indoor piping, indoor equipment).
    V. Outdoor. The term outdoor shall mean for the purposes of these Contract Documents items or devices not contained within the confines of a building, structure, or facility and items or devices which are exposed to weather. The term outdoor shall generally reference to ductwork, piping, or equipment (outdoor ductwork, outdoor piping, outdoor equipment).
    W. Hot. The term hot shall mean for the purposes of these Contract Documents the temperature of conveyed solids, liquids, or gases which are above the surrounding ambient temperature or above 100°F. (hot supply air ductwork, heating water piping).
    X. Cold. The term cold shall mean for the purposes of these Contract Documents the temperature of conveyed solids, liquids, or gases which are below the surrounding ambient temperature or below 60°F. (cold supply air ductwork, chilled
    water piping).
    Y. Warm. The term warm shall mean for the purposes of these Contract Documents the temperature of conveyed solids, liquids, or gases which are at the surrounding ambient temperature or between 60°F. and 100°F. (condenser water piping).
    Z. Hot / Cold. The term hot/cold shall mean for the purposes of these Contract Documents the temperature of conveyed solids, liquids, or gases that can be either hot or cold depending on the season of the year (heating and air conditioning supply air ductwork, dual temperature piping systems).
    AA. Removable. The term removable shall mean detachable from the structure or system without physical alteration or disassembly of the materials or equipment or disturbance to other construction.
    BB. Temporary Work. Work provided by the Contractor for use during the performance of the Work, but which is to be removed prior to Final Acceptance.
    CC. Normally Closed (NC). The term normally closed shall mean the valve, damper, or other control device shall remain in or go to the closed position when the control air pressure, the control power or the control signal is removed. The position the device will assume when the control signal is removed.
    DD. Normally Open (NO). The term normally open shall mean that the valve, damper, or other control device shall remain in, or go to, the open position when the control air pressure, the control power, or the control signal is removed. The position the device will assume when the control signal is removed.
    EE. Traffic Level or Personnel Level. The term traffic level or personnel level shall mean for the purposes of these Contract Documents all areas, including process areas, equipment rooms, boiler rooms, chiller rooms, fan rooms, air handling unit rooms, and other areas where insulation may be damaged by normal activity and local personnel traffic. The area extends vertically from the walking surface to 8′-0″ above walking surface and extends horizontally 5′-0″ beyond the edge of walking surface. The walking surface shall include floors, walkways, platforms, catwalks, ladders, and stairs.
    تابعونا ------------------------>
    مهندس إستشارى / مصطفى الوكيل
    Zuhair Fayez
    moamen anwar
    moamen anwar غير متواجد حالياً
    tankes about this topic
    مصطفى الوكيل
    Received: 61
    Contract Documents
    Contract Documents
    A. Contract Drawings. The terms contract drawings and drawings shall mean all drawings or reproductions of drawings pertaining to the construction or plans, sections, elevations, profiles, and details of the Work contemplated and its appurtenances.
    B. Contract Specifications. The terms contract specifications and specifications shall mean the description, provisions, and other requirements pertaining to the method and manner of performing the Work and to the quantities and qualities of materials to be furnished under the Contract. The specifications shall include the general provisions, the special provisions, and the technical specifications.
    C. Contract Documents. The term contract documents shall include Contract Drawings, Contract Specifications, Addendums, Change Orders, shop drawings, coordination drawings, General Provisions, Special Provisions, the executed Agreement and other items required or pertaining to the Contract including the executed Contract.
    D. Addendums. Addendums are issued as changes, amendments, or clarifications to the original or previously issued Contract Documents. Addendums are issued in written and/or drawing form prior to acceptance or signing of the Construction Contract.
    E. Change Orders (Change Bulletins). Change orders (change bulletins) are issued changes or amendments to the Contract Documents. Change orders are issued in written and/or drawing form after acceptance or signing of the Contract.
    F. Shop Drawings. The term shop drawings shall include drawings, diagrams, schedules, performance characteristics, charts, brochures, catalog cuts, calculations, certified drawings, and other materials prepared by the Contractor, Sub-Contractor, Manufacturer, or Distributor which illustrates some portion of the Work as per the requirements of the Contract Documents used by the Contractor to order, fabricate and install mechanical and electrical equipment and systems in a building. The corrections or comments annotated on a shop drawing during the Engineer’s review do not relieve the Contractor from full compliance with the Contract Documents regarding the Work. The Engineer’s check is only a review of the shop drawing’s general compliance with the information shown in the Contract Documents. The Contractor remains responsible for continuing the correlation of all material and component quantities and dimensions, coordination of the Contractor’s Work with that of other trades, selection of suitable fabrication and installation techniques, and performance of Work in a safe and satisfactory manner.
    G. Product Data. Illustrations, standard schedules, performance charts, instructions, brochures, diagrams, and other information furnished by the Contractor to illustrate a material, product, or system for some portion of the Work.
    H. Samples. Physical examples which illustrate material, equipment, or workmanship and establish standards to which the Work will be judged.
    I. Coordination Drawings. The terms coordination drawings and composite drawings are drawings created by the respective Contractors showing Work of all Contractors superimposed on the sepia or mylar of the basic shop drawing of one of the Contractors to coordinate and verify that all Work in a congested area will fit in an acceptable manner.
    J. Contract. A set of documents issued by the Owner for the Work, which may include the Contract Documents, the Advertisement, Form of Proposal, Free Competitive Bidding Affidavit, Affidavit as to Taxes, Certification of Bidder, Buy America Requirements, Disadvantaged Business Enterprise Forms, Bid Bond, Agreement, Waiver of Right to File Mechanics Lien, Performance Bond, Labor and Materialman’s Bond, Maintenance Bond(s), Certification Regarding Lobbying, Disclosure Form to Report Lobbying, and other forms that form part of the Contract as required by the Owner and the Contract Documents.
    K. Labor and Materialman’s Bond. The approved form of security furnished by the Contractor and its Surety as a guaranty to pay promptly, or cause to be paid promptly, in full, such items as may be due for all material furnished, labor supplied or performed, rental of equipment used, and services rendered in connection with the Work.
    L. Maintenance Bond. The approved form of security furnished by the Contractor and its Surety as a guaranty on the part of the Contractor to remedy, without cost to the Owner, any defects in the Work which may develop during a period of twelve (12) months from the date of Substantial Completion.
    M. Performance Bond. The approved form of security furnished by the Contractor and its Surety as a guaranty on the part of the Contractor to execute the Work.
    N. Working Drawings. Drawings and calculations which are prepared by the Contractor, Sub-Contractor, Supplier, Distributor, etc., and which illustrate Work required for the construction of, but which will not become an integral part of, the Work. These shall include, but are not limited to, drawings showing Contractor’s plans for Temporary Work such as decking, temporary bulkheads, support of excavation, support of utilities, groundwater control systems, forming and false-work, erection plans, and underpinning.
    O. Construction Drawings. Detailed drawings which are prepared by the Contractor, Sub-Contractor, Supplier, Distributor, etc., and which illustrate in exact and intricate detail, Work required for the construction Contract. These drawings often show hanger locations, vibration isolators, ductwork and pipe fittings, sections, dimensions of ducts and pipes, and other items required to construct the Work.
    P. Project Record Documents. A copy of all Contract Drawings, Shop Drawings, Working Drawings, Addendum, Change Orders, Contract Documents, and other data maintained by the Contractor during the Work. The Contractor’s recording, on a set of prints, of accurate information and sketches regarding exact detail and location of the Work as actually installed, recording such information as exact location of all underground utilities, Contract changes, and Contract deviations. The Contractor’s information is then transferred to the original Contract Documents by the Engineer for the Owner’s permanent record unless otherwise directed or specified.
    Q. Proposal Guaranty. Cashier’s check, certified check, or Bid Bond accompanying the Proposal submitted by the Bidder as a guaranty that the Bidder will enter into a Contract with the Owner for the performance of the Work indicated and file acceptable bonds and insurance if the Contract is awarded to it.
    R. Project Schedule. The schedule for the Work as prepared and maintained by the Contractor in accordance with the Contract Documents.
    S. Certificate of Substantial Completion. Certificate issued by the Owner or Engineer certifying that a substantial portion of the Work has been completed in accordance with the Contract Documents with the exception of contractual administrative demobilization work, inconsequential punch list items, and guarantees. The Certificate of Substantial Completion shall establish the Date of Substantial Completion, shall state the responsibilities of the Owner and the Contractor for security, maintenance, heat, utilities, damage to the Work, and insurance, and shall fix the time within which the Contractor shall complete the items listed therein. Warranties required by the Contract Documents shall commence on the Date of Substantial Completion of the Work or designated portion thereof unless otherwise provided in the Certificate of Substantial Completion or the Contract Documents.
    T. Certificate of Final Completion (Final Acceptance). Certificate issued by the Owner or Engineer certifying that all of the Work has been completed in accordance with the Contract Documents to the best of the Owner’s or Engineer’s knowledge, information, and belief, and on the basis of that person’s observations and inspections including contractual administrative demobilization work and all punch list items. The Certificate of Final Completion shall establish the Date of Owner acceptance. Warranties required by the Contract Documents shall commence on the Date of Final Completion of the Work unless otherwise provided in the Certificate of Substantial Completion or the Contract Documents.
    U. Acceptance Certificate. Certificate to be issued by the Owner or Engineer certifying that all the Work has been completed in accordance with the Contract Documents.
    V. Award. The acceptance by the Owner of the Bid from the responsible Bidder (sometimes the lowest responsible Bidder) as evidenced by the written Notice to Award to the Bidder tendering said bid.
    W. Bid (Proposal). The Proposal of the Bidder for the Work, submitted on the prescribed Bid Form, properly signed, dated, and guaranteed, including Alternates, the Unit Price Schedule, Bonds, and other bidding requirements as applicable.
    X. Certificate of Compliance. Certificate issued by the Supplier certifying that the material or equipment furnished is in compliance with the Contract Documents.
    Y. Agreement. The instrument executed by the Owner and the Contractor in conformance with the Contract Documents for the performance of the Work.
    Z. Field Order. A notice issued to the Contractor by the Engineer specifying an action required of the Contractor.
    AA. Request for Information (RFI). A notice issued to the Engineer or Owner requesting a clarification of the Contract Documents, sometimes (RFI) means Request For Inspection, and (DCR) means documentary clarification request, while (NCR) means that non conformance form.
    BB. Notice to Proceed. A written notice from the Owner to the Contractor or Engineer directing the Contractor or Engineer to proceed with the work.
    CC. Advertisement, Invitation to Bid. The public or private announcement, as required by law or the Owner, inviting Bids for the Work to be performed, material to be furnished, or both.
    تابعونا ---------------------->
    Zuhair Fayez
    مصطفى الوكيل
    Received: 61
    Contractors / Manufacturers / Authorities
    A. Contractor. The term contractor shall mean the individual, firm, partnership, corporation, joint venture, or any combination thereof or their duly authorized representatives who have executed a Contract with the client for the proposed Work.
    B. Sub-Contractor or Trade Contractor. The terms sub-contractor and trade contractor shall mean all the lower tier contractors, material suppliers, and distributors which have executed a contract with the Contractor for the proposed Work.
    C. Furnisher, Supplier. The terms furnisher and supplier shall be defined as the “entity” (individual, partnership, firm, corporation, joint venture, or any combination thereof) engaged by the Contractor, its Sub-Contractor, or Sub-Sub-Contractor, to furnish a particular unit of material or equipment to the project site. It shall be a requirement that the furnisher or supplier be experienced in the manufacture of the material or equipment they are to furnish.
    D. Installer. The term installer shall be defined as the “entity” (individual, partnership, firm, corporation, joint venture, or any combination thereof) engaged by the Contractor, its Sub-Contractor, or Sub-Sub-Contractor to install a particular unit of Work at the project site, including installation, erection, application, and similar required operations. It shall be a requirement that the installer be experienced in the operations they are engaged to perform.
    E. Provider. The term provider shall be defined as the “entity” (individual, partnership, firm, corporation, joint venture, or any combination thereof) engaged by the Contractor, its Sub-Contractor, or Sub-Sub-Contractor to provide a particular unit of material or equipment at the project site. It shall be a requirement that the provider be experienced in the operations they are engaged to perform.
    F. Bidder. An individual, firm, partnership, corporation, joint venture, or any combination thereof submitting a Bid for the Work as a single business entity and acting directly or through a duly authorized representative.
    G. Authority Having Jurisdiction. The term authority having jurisdiction shall mean federal, state, and/or local authorities or agencies thereof having jurisdiction over Work to which reference is made and authorities responsible for “approving” equipment, installation, and/or procedures.
    H. Surety. The corporate body which is bound with and for the Contractor for the satisfactory performance of the Work by the Contractor, and the prompt payment in full for materials, labor, equipment, rentals, and services, as provided in the bonds.
    I. Acceptable Manufacturers. The term acceptable manufacturers shall mean the specified list of manufacturers considered acceptable to bid the project for a specific piece of equipment. Only the equipment specified has been checked for spatial compatibility. If the Contractor elects to use an optional manufacturer from the acceptable manufacturers list in the specifications, it shall be the Contractor’s responsibility to determine and ensure the spatial compatibility of the manufacturers equipment selected.
    وإلى لقاء فى موضوع آخر
    ودمتم بخير
    Zuhair Fayez
    مصطفى الوكيل
    Received: 61
    (( فَبَدَأَ بِأَوْعِيَتِهِمْ قَبْلَ وِعَاء أَخِيهِ ثُمَّ اسْتَخْرَجَهَا مِن وِعَاء أَخِيهِ كَذَلِكَ كِدْنَا لِيُوسُفَ مَا كَانَ لِيَأْخُذَ أَخَاهُ فِي دِينِ الْمَلِكِ إِلاَّ أَن يَشَاءَ اللّهُ نَرْفَعُ دَرَجَاتٍ مِّن نَّشَاء وَفَوْقَ كُلِّ ذِي عِلْمٍ عَلِيمٌ
    صدق الله العظيم
    Zuhair Fayez
    ابو الباسل الألمعي
    ابو الباسل الألمعي غير متواجد حالياً
    شكرا جزيلا............
    ahmedzizo
    ahmedzizo غير متواجد حالياً
    شكرا جزيلا ياباشمهندس مصطفى
    ahmedzizo
    شكرا جزيلا لان الموضوع ده مهم جدا
    ويا رب تمدنا بكل ماهو مفيد ان شاء الله
    محمد علاوى
    محمد علاوى غير متواجد حالياً
    فى الحقيقة انا استفدت كتير جدا من الكتاب دة وربنا يخلية فى ميزان حسناتك
