Rapidshare برنامج التحميل من الــ
النتائج 1 إلى 1 من 1
    الصورة الرمزية سيطور
    سيطور
    سيطور غير متواجد حالياً
    FreeRapid Downloader
    *It is tested by myself and it works properly
    FreeRapid-0.81.zip, 5.30MB
    How to run FreeRapid Downloader
    Installation
    Unzip files to any of your directory, but beware special characters (like '+' or '!') on the path.
    If you make an upgrade to higher version, you can delete previous folder. All user settings are preserved. All user settings are saved in home directories:
    MS Windows: c:\Documents and Settings\YOUR_USER_NAME\application data\VitySoft\FRD and in registry HKEY_CURRENT_USER\Software\JavaSoft\Prefs\vitysoft \frd
    Linux: ~/.FRD
    DO NOT copy new version over older one.
    Launching
    Windows Simply launch frd.exe or double click on frd.jar
    Linux Run command ./frd.sh (as first put correct executable rights on this file )
