PHPMaker.v6.0.1.2.Incl.Keymaker-CORE
PHPMaker v6.0.1.2 *INCL.KEYMAKER*
Cracked by....: LTB Release-Name..: CR-XWN01.ZIP
Supplied......: CORE Release-Date..: 2009/03/09
Packaged......: Bergelmir Release-Type..: Util
Protection....: Serial OS............: Windows
Crack/SN......: Keymaker Language......: English
Rating........: [You decide!] Disks.........: 03
..: DESCRiPTiON :..
PHPMaker is an automation tool (for Windows) that can generate a
full set of PHP scripts quickly from MySQL database. Using the
generated PHP, users can view, edit, search, add and delete
records in the database easily on the Web. With the Quick Generate
Wizard, you can generate your web site instantly with only a few
clicks of the mouse. Clean and straightforward codes which are
easy-to-customize. This useful tool can save you tons of time and
is suitable for both beginners and experienced PHP develpers
alike.
..: iNSTALL/REGiSTER NOTES :..
Use our keymaker to register the application.
..: iMPORTANT NOTE :..
Run CORE10k.EXE to verify this release, if CRC-check fails or
even CORE10k.EXE is missing - you are probably using webshit
Links
http://rapidshare.com/files/20704543...maker-CORE.rar
password if needed : bebnine.com/forum
