Automated Oil Spill Detection System for Real-Time Monitoring of Petroleum Hydrocarbo
النتائج 1 إلى 7 من 7
    الصورة الرمزية marine_eng
    marine_eng
    marine_eng غير متواجد حالياً
    The Oil Spill Monitor and Alarm System (OSMAS) consists of an array of underwater sensors deployed just below the water surface near piers, pipelines, transfer points, storage vessels, or other areas of high spill risk. The sensors can detect floating product (surface sheen) from below the surface as well as detect emulsified or dissolved phase petroleum in the water column. Information corresponding to the amount of oil detected by each of the sensors is transmitted over a secure radio-frequency data link to a central base station computer for display, logging, analysis, and alarming. Statistically-based algorithms that "learn" normal background oil contaminant levels are used to determine whether a spill has occurred and serve to minimize the occurrence false alarms.
    Automated Oil Spill Detection System for Real-Time Monitoring of Petroleum Hydrocarbon Contaminants in the Marine Environment
    Conceptual diagram of the Oil Spill Monitor and Alarm System (OSMAS).
    The system is designed to augment, and in some cases replace, human visual observation as the principal means of detecting spills. The primary intended use of the system is to protect marine facilities from accidental petroleum discharges by providing responding authorities with immediate notification of the occurrence of a leak or spill. By enhancing responders' ability to exercise timely countermeasures, early detection is expected to offer an effective means of minimizing the environmental and financial impact of a spill. Automated spill detection is particularly suited for use at night or during foul weather or choppy conditions when visual detection of oil on water is difficult or impossible.
    أمير البحر
    أمير البحر غير متواجد حالياً
    نشاط واضح منك أخي الكريم لك جزيل الشكر
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    الصورة الرمزية Eng-Maher
    Received: 103
    Given: 408
    رائع موضوع رائع وتناوله اروع متشكر اخى
    الحمد لله
    Eng-Maher
    Received: 103
    Given: 408
    يرفع للافاده ***********
    الحمد لله
    sam6255
    sam6255 غير متواجد حالياً
    شششششششكرا على المجهود الرائع
    كيرو عبده
    كيرو عبده غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية كيرو عبده
    Received: 19
    Given: 5
    تسلم يا غالى
    محمد الشناوي20
    محمد الشناوي20 غير متواجد حالياً
