النـــــــــــاقل العمــــــــــلاق c-130
النتائج 1 إلى 10 من 11
    الصورة الرمزية شفق الصباح
    شفق الصباح
    شفق الصباح غير متواجد حالياً
    C-130 HERCULES
    الناقــــــــــــــلالعمــــــــــــــــــــلاق
    DESCRIPTION:
    Development of the C-130 Hercules began in the early 1950s, and the popular transport continues to be produced in large numbers half a century later. New C-130J and L-100 airframes continue to enter service both for military and civil operators, a trend which shows no signs of slowing for at least the next several years.
    Following the Berlin Airlift and the Korean War, the USAF realized the need for a new transport with a large unobstructed cargo space, turboprop engines for better performance, and rough field operational capability. The winner of the USAF design competition was the Lockheed C-130. With a high-mounted wing to maximize cargo space and a hydraulically-operated ramp at the rear of the fuselage, the C-130 set the standard layout for all future cargo aircraft.
    The initial C-130A was so popular with pilots and capable of such exceptional performance that the basic airframe was soon adapted to numerous other tasks. Many early models were converted to AC-130 aerial gun ships equipped with large-caliber guns and heavy armor. Other applications in which the C-130 has found success include search-and-rescue, airborne refueling, airborne early warning, and special forces transport.
    Over 2,000 C-130 aircraft have been built in numerous variants. Current production is focused on the latest C-130J models.
    Data below for C-130H and AC-130U
    Last modified 17 December 2008
    HISTORY:
    First Flight
    (YC-130A) 13 August 1954
    (C-130A) 7 April 1955
    (C-130E) 25 August 1961
    Service Entry
    (C-130A) December 1956
    (C-130B) May 1959
    (C-130E) August 1962
    (EC-130E) 1986
    (MC-130E) 1966
    (C-130H) June 1974
    (AC-130H) 1972
    (EC-130H) June 1974
    (MC-130H) June 1991
    (WC-130H) 1964
    (C-130J) February 1999
    (HC-130P/N) 1964
    (MC-130P) 1986
    (AC-130U) 1995
    CREW:
    (C-130E/H) five: pilot, co-pilot, navigator, flight engineer, loadmaster
    (EC-130E) 16: pilot, co-pilot, navigator, mission control chief, flight engineer, loadmaster, five electronic communications systems operators, five electronic communications systems operators
    (MC-130E) nine: pilot, co-pilot, two navigators, electronic warfare officer; flight engineer, radio operator, two loadmasters
    (EC-130H) 13: pilot, co-pilot, navigator, flight engineer, electronic warfare officer, mission crew supervisor, four crypto logic linguists, high band operator, acquisition operator, airborne maintenance technician
    (MC-130H) seven: pilot, co-pilot, navigator, electronic warfare officer; flight engineer, two loadmasters
    (WC-130H) six: pilot, co-pilot, navigator, flight engineer, aerial reconnaissance weather officer, dropsonde system operator
    (C-130J) three: pilot, co-pilot, loadmaster
    (EC-130J) 10: pilot, co-pilot, navigator, mission control chief, loadmaster, five electronic communications systems operators
    (HC-130P/N) 10: pilot, co-pilot, navigator, flight engineer, airborne communications specialist, two loadmasters, three pararescuemen
    (MC-130P) eight: pilot, co-pilot, right navigator, left navigator, flight engineer, communications systems operator, two loadmasters
    (AC-130U) 13: pilot, co-pilot, navigator, fire control officer, electronic warfare office, flight engineer, TV operator, infrared detection set operator, loadmaster, four aerial gunners
    C-130 panel
    PASSENGERS:
    92 troops, 64 paratroops, or 74 stretchers
    ESTIMATED COST:
    (C-130E) $11.9 million
    (C-130H) $30.1 million
    (EC-130E) $70 million
    (MC-130E) $75 million
    (AC-130H) $132.4 million
    (EC-130H) $30.1 million
    (MC-130H) $155 million
    (WC-130H) $13 million
    (C-130J) $48.5 million
    (EC-130J) $90 million
    (HC-130P/N) $18.4 million
    (MC-130P) $75 million
    (AC-130U) $190 million
    AIRFOIL SECTIONS:
    Wing Root
    NACA 64A318
    Wing Tip
    NACA 64A412
    DIMENSIONS:
    Length
    97.75 ft (29.79 m)
    Wingspan
    132.58 ft (40.41 m)
    Height
    38.25 ft (11.66 m)
    Wing Area
    1,745 ft2 (162.12 m2)
    WEIGHTS:
    Empty
    75,745 lb (34,430 kg)
    Normal Takeoff
    155,000 lb (70,455 kg)
    Max Takeoff
    175,000 lb (79,380 kg)
    Fuel Capacity
    internal: 44,240 lb (20,108 kg)
    external: 18,160 lb (8,255 kg)
    Max Payload
    42,580 lb (19,355 kg)
    PROPULSION:
    Powerplant
    four Allison T56-A-15 turboprops (plus jet-assisted takeoff capability)
    Thrust
    18,032 shp (13,448 kW)
    PERFORMANCE:
    Max Level Speed
    at altitude: 385 mph (620 km/h)
    at sea level: unknown
    cruise speed: 345 mph (555 km/h)
    Initial Climb Rate
    1,900 ft (579 m) / min
    Service Ceiling
    33,000 ft (10,060 m)
    Range
    typical: 2,160 nm (4,000 km)
    ferry: 4,270 nm (7,900 km)
    ARMAMENT:
    Gun
    (normal) none
    (AC-130U) one 105-mm howitzer, one Bofors 40-mm gun, one GAU-12/U 25-mm six-barrel gun (3,000 rds)
    Stations
    2 hardpoints
    Bomb
    GBU-43 Massive Ordnance Air Blast, BLU-82 Daisy Cutter
    KNOWN COMBAT RECORD:
    Vietnam War (USAF, USN, USMC, 1965-1972)
    Iran - Operation Eagle Claw (USAF [C-130, KC-130], 1980)
    Grenada - Operation Urgent Fury (USAF [C-130, AC-130, EC-130, MC-130], 1983)
    Panama - Operation Just Cause (USAF [C-130, AC-130], 1989)
    Iraq - Operation Desert Storm (USAF, USMC [C-130, AC-130, KC-130], 1991)
    Bosnia - Operation Deliberate Force (USAF [EC-130E/H, AC-130H, MC/HC-130P], Italy [C-130], Spain [KC-130], 1995)
    Kosovo - Operation Allied Force (USAF [AC-130H], 1999)
    Afghanistan - Operation Enduring Freedom (USAF, USMC [C-130, AC-130U, EC-130, KC-130], 2001-present)
    Iraq - Operation Iraqi Freedom (USAF, USMC, Japan [C-130, AC-130U, EC-130, KC-130], 2003-present)
    3-VIEW SCHEMATIC:
    مع خالص دعواتكم
    سلام العراق
    سلام العراق غير متواجد حالياً
    تسلم يا أخي على هذه المعلومات الجميله
    samizzo
    samizzo غير متواجد حالياً
    مشكككككككككككككككككككككور ...
    مهندس أيمن حسن
    الصورة الرمزية مهندس أيمن حسن
    Received: 96
    Given: 12
    الف الف شكر
    انت من انشط اعضاء منتدى الطيران :)
    bryar
    bryar غير متواجد حالياً
    شكرا للمعلومات القيمة عن طائرة س 130
    5A-ALI
    5A-ALI غير متواجد حالياً
    الصورة الرمزية 5A-ALI
    مششششششششششششششششششششششششششششششششششككككككككككككككك كككووووووووووووووووورررررررررررررر
    م/ مصطفي
    م/ مصطفي غير متواجد حالياً
    الصورة الرمزية م/ مصطفي
    بــارك الله لك اخـي الكريـم :)
    عـوده مره أخري الي هذا الملتقي الاكثر من رائع :)
    شفق الصباح
    اقتباس المشاركة الأصلية كتبت بواسطة سلام العراق مشاهدة المشاركة
    اقتباس المشاركة الأصلية كتبت بواسطة samizzo مشاهدة المشاركة
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس أيمن حسن مشاهدة المشاركة
    الف الف شكر
    اقتباس المشاركة الأصلية كتبت بواسطة bryar مشاهدة المشاركة
    اقتباس المشاركة الأصلية كتبت بواسطة 5A-ALI مشاهدة المشاركة
    [quote=م/ مصطفي;1059242]بــارك الله لك اخـي الكريـم :)
    خالص التحايا لكم أخواني الأعزاء
    ومشكورين علي المرور والتعقيب
    كن جميلاً تري الوجود جميلاً
    محمد زرقة
    محمد زرقة غير متواجد حالياً
    الصورة الرمزية محمد زرقة
    wdelrasheed
    wdelrasheed غير متواجد حالياً
    انتظار
    الصورة الرمزية wdelrasheed
    مشكوووووووووووووووووور
    جدا على المعلومات، حسب معلوماتي من مزاياها
    Short Takeoff Area & Short Landing Area
