Civil Engineering 101 E-book collection
النتائج 1 إلى 8 من 8
    الصورة الرمزية سيطور
    سيطور
    سيطور غير متواجد حالياً
    ebook |All PDF Format | RS | 13 files
    Aysen - Problem Solving in Soil Mechanics
    Autocad 2006 Manual Users Guide
    AutoCAD2007Bible
    Bridge Design Manual-Texas Department of transportation
    Bridge.Hydraulic.Design.(2000)
    BSP_VL4
    Building Design and Construction Handbook
    Building Design and Construction Handbook(2)
    Chen & Liew Civil Engineering Handbook
    Civil Engineering Handbook(Second Edition)
    Civil engineering hydraulics- Essential theory with worked e
    cmaug2005
    List of books :
    COMPOSITE MATERIALS HANDBOOKvol4
    Composite Structures Of Steel And Concrete- Volume 1 (2Nd Ed
    Concrete Forwork
    Construction of buildings Volume 1
    Construction Of Buildings Volume 2
    Design Loads During Construction
    DESIGN OF HYDRAULIC GATES
    Engineering Structural Welding
    Engineer's Mini-Notebook
    FIDIC
    Finite Element Method - Boundary Element Method
    Finite-element-procedure-Bathe
    Fundamentals Handbook - Engineering Symbology, Prints, and Drawings 1
    Fundamentals of Finite Element Analysis
    Fundamentals of wood design and engineering
    Handbook
    Handbook of Structural Engineering
    Handbook_of_Structural_Engineering
    Harrison___Nettleton_-_Advanced_Engineering_Dynamics__Arnold_1997__4AH
    Hydraulics Manual
    J.F.Doyle - Modern experimental stress analysis
    Lean Manufacturing And The Enviroment (Epa)
    LIQUID STORAGE TANK
    Manual for the design of reinforced concrete building struct
    MARINE STRUCTURAL DESIGN
    Mathematics-The Civil Engineering Handbook
    matlab_quickref
    MatlabNotes
    McGraw Hill - Dictionary of Engineering
    Mcgraw Hill - Project Management
    McGraw-Hill - Piping Handbook
    McGraw-Hill_-_Civil_Engineering_Formulas__2002__Tlf
    Mechanical Engineering Handbook (CRC Press)
    miscellaneous_recipes_001
    Modern Manufacturing
    Multiresolution Green?s Function Methods for Interactive Simulation of Large-Scale Elastostatic Objects
    Non-linear Finite Element Analysis of Solids and Structures Vol.2
    Numerical approximations of time domain boundary integral equation for wave propagation
    Olver P.J., Shakiban C. Applied mathematics (draft, 2004)(11
    Patankar_Numerical_Heat_Transfer_and_Fluid_Flow
    PLANNING AND DESIGN OF HYDROLECTRIC POWER PLANT STRUCTURES
    PORTLAND CEMENT
    Post-Tensioning
    Reinforced concrete analysis and design
    Residential_Structural_Design_Guide
    Sadd - Elasticity theory applications and numerics [butterworth heinemann 2004] 4AH
    SMITH, E. H. (1994). Mechanical Engineer's Reference Book (12t.)
    Soil engineering - testing, design, and remediation
    Soil_Mechanics___Foundations
    SPED_VL3
    standard_handbook_of_engineering_calculations
    Steel designers manual 5th edition
    Stiffener Design for Beam-to-Column Connections
    strength of materials
    stress analysis of why branch
    Structural Mechanics of Buried Pipes
    Structural Steel Designer's Handbook (Brockenbrough & Merritt)
    TAYLOR, D. A. (1996). Introduction to Marine Engineering (2nd .)
    Teexas - Hydraulic Design Manual
    Time-dependent problems with the boundary integral equation
    TONG, L. (2002). 3D Fibre Reinforced Polymer Composites
    Transportation Eng
    Transportation Systems Planning Methods and Applications
    Vibration and Shock Handbook
    Vibration Simulation using MATLAB and ANSYS
    Vibrations Fundamentals and Practice
    WATSON, D. G. M. (1998). Practical Ship Design
    Welded Design - Theory and Practice
    Welding Metallurgy (Second Edition)
    Wind Loading of Structures
    WU, Y.-S. (2001). Practical Design of Ships and Other Floating S
    YUN, L. (2000). Theory and Design of Air Cushion Craft
    ZIENKIEWICZ, O. C. (2000). The Finite Element Method (5th ed.).)
    Zienkiewicz's Finite Element Book
    DOWNLOAD:
    من مواضيع سيطور :
    التعديل الأخير تم بواسطة سيطور ; 2009-03-08 الساعة 05:18 AM
    حنان الالمعي
    حنان الالمعي غير متواجد حالياً
    ممكن solutions manual لكتاب
    construction management ,Daniel Halpin,Wiley,3rd edition
    وشكرا لك
    سبع الليل
    سبع الليل غير متواجد حالياً
    الصورة الرمزية سبع الليل
    Received: 16
    بارك الله فيك أخي سيطور
    اللهم اغفر لي ولوالدي والمسلمين أجمعين
    سيطور
    اقتباس المشاركة الأصلية كتبت بواسطة سبع الليل مشاهدة المشاركة
    أشكرك اخي الفاضل سبع الليل
    الله يحفظك ويسلمك
    أشكر مرورك الكريم
    ksyz_1
    ksyz_1 غير متواجد حالياً
    kaled asaad
    kaled asaad غير متواجد حالياً
    السلام عليكم عندي مجموعة كتب هندسية كيف يمكنني عرضها
    HFabusaif
    HFabusaif غير متواجد حالياً
    احبائى الاعزاء
    هل يمكن الخصول على هذا الكتاب
    (p 17 aci design handbook (05
    ولكم مني جزيل الشكر والتقدير
    جلال ثابت الأغبري
    جلال ثابت الأغبري غير متواجد حالياً
    الصورة الرمزية جلال ثابت الأغبري
    Received: 9
    بارك الله بك أخي الكريم
    مشاركة سخية.
    إلهي أهد قلبي الصراط السوي **** إذا تَّوه العقل في التائهين
    فعقلي يريد ســــــــبيل الغرور **** وقلبي يريد ســـبيل اليقين
    من قصيدة للشاعر د. محمد عبده غانم (رحمه الله).
