Finite Element Methods
النتائج 1 إلى 10 من 19
    الصورة الرمزية سيطور
    سيطور
    سيطور غير متواجد حالياً
    Fundamentals of the Finite Element Method for Heat and Fluid Flow
    Heat transfer is the area of engineering science which describes the energy transport between material bodies due to a difference in temperature. The three different modes of heat transport are conduction, convection and radiation. In most problems, these three modes exist simultaneously. However, the significance of these modes depends on the problems studied and often, insignificant modes are neglected.
    Very often books published on Computational Fluid Dynamics using the Finite Element Method give very little or no significance to thermal or heat transfer problems. From the research point of view, it is important to explain the handling of various types of heat transfer problems with different types of complex boundary conditions. Problems with slow fluid motion and heat transfer can be difficult problems to handle. Therefore, the complexity of combined fluid flow and heat transfer problems should not be underestimated and should be dealt with carefully.
    This book:
    Is ideal for teaching senior undergraduates the fundamentals of how to use the Finite Element Method to solve heat transfer and fluid dynamics problems
    Explains how to solve various heat transfer problems with different types of boundary conditions
    Uses recent computational methods and codes to handle complex fluid motion and heat transfer problems
    Includes a large number of examples and exercises on heat transfer problems
    In an era of parallel computing, computational efficiency and easy to handle codes play a major part. Bearing all these points in mind, the topics covered on combined flow and heat transfer in this book will be an asset for practising engineers and postgraduate students. Other topics of interest for the heat transfer community, such as heat exchangers and radiation heat transfer, are also included.
    IFILE
    RAPIDSHARE
    سيطور
    Finite Element Analysis: Theory and Applications with ANSYS, Second Edition
    by Saeed Moaveni
    This book presents the theory of finite element analysis, explores its application as a design/modeling tool, and explains in detail how to use ANSYS intelligently and effectively. This book covers trusses; axial members, beams, and frames; one-dimensional elements; two-dimensional elements; three-dimensional elements; dynamic problems; design and material selection; design optimization; and more. For Design Engineers in CAE-CAD.
    سيطور
    Finite Element Techniques in Structural Mechanics : Solutions Manual
    Albion/Horwood | ISBN: 189856325X | 1 edition (1998) | 207 pages | PDF | 5 Mb
    Bridges the gap between theoretical texts with little software support and the giant finite element software packages. Useful to students and and graduates in civil, mechancal, struictural, aeronautical and elecxtrical engineering.
    Introduction to matrix algebra • The matrix displacement method • Finite element method • Dynamics of structures • Elastic buckling and the non-linear behaviour of structures • Modal method of analysis.
    This book presents the introduction of the finite element method, exclusively to structural mechanics. It contains several listings of subroutines for the use on PCs (in BASIC). The book is directed mainly for undergraduate students of civil, mechanical and aerospace engineering.
    Partial *******s: summary of matrix algebra; basic structural concepts and energy theorems; elementary derivation; static analysis of pin-jointed trusses and rigid-jointed frames; introduction to the finite element method; vibration problems; grillage elements; nonlinear behavior.
    IFILE
    سيطور
    Finite Element Method Using MATLAB (Mechanical Engineering)
    By Young W. Kwon, Hyochoong Bang
    The finite element method (FEM) has become one of the most important and useful tools for scientists and engineers. This new book features the use of MATLAB to present introductory and advanced finite element theories and formulations. MATLAB is especially convenient to write and understand finite element analysis programs because a MATLAB program manipulates matrices and vectors with ease. The book is suitable for introductory and advanced courses in the Finite Element Method, as well as a reference for practicing engineers
    http://rapidshare.com/files/9904210/Kwon.djvu
    سيطور
    Applied Finite Element Analysis
    By Larry J. Segerlind
    An introductory textbook for senior/graduate couses in finite element analysis taught in all engineering departments. Covers the basic concepts of the finite element method and their application to the analysis of plane structures and two-dimensional continuum problems in heat transfer, irrotational fluid flow, and elasticity. This revised edition includes a reorganization of topics and an increase in the number of homework problems. The emphasis on numerical illustrations make topis clear without heavy use of sophisticated mathematics.
    http://rapidshare.com/files/80332989...t_analysis.pdf
    anan6666
    anan6666 غير متواجد حالياً
    finite element program
    if you know how to program with finite element as use 4.2 edtion , i have problem with writing code or how to make model for synchronous generator.
    i wait your response
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    ممتازجدا.................................
    إبن رشد
    إبن رشد غير متواجد حالياً
    موفور الشكر
    عبد النبى زغلول
    عبد النبى زغلول غير متواجد حالياً
    thanks for all
    alilol
    alilol غير متواجد حالياً
    بارك الله فيك
