Manufacturing Processes
النتائج 1 إلى 6 من 6
    aboalzooz2002
    aboalzooz2002 غير متواجد حالياً
    طرق التصنيع الغير تقليدي
    ارجو شاكرا مساعدتي في العسور علي المرجع التالي
    لانني في اشد الحوجة لهو؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟ظ
    Nontraditional Manufacturing Processes
    By Gary F. Benedict
    هانى شرف الدين
    هانى شرف الدين غير متواجد حالياً
    Received: 15
    Engineer On a Disk
    Overview: This note set is part of a larger collection of materials available at http://claymore.engineer.
    gvsu.edu. You are welcome to use the material under the license provided at http://claymore.
    engineer.gvsu.edu/eod/global/copyrght.html. As always any feedback you can provide
    will be welcomed.
    Copyright © 1993-2001, Hugh Jack
    email: [email protected]
    phone: (616) 771-6755
    fax: (616) 336-7215
    1. TABLE OF *******S
    TABLE OF *******S.......................................... .................................................. .............. 2
    BASIC MANUFACTURING..................................... .................................................. ............ 7
    INTRODUCTION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 7
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 8
    MANUFACTURING COST ESTIMATING........................................ ................................... 9
    COSTS ESTIMATES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 9
    COGS (COST OF GOODS SOLD) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 14
    VALUE ENGINEERING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 14
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 14
    BASIC CUTTING TOOLS .................................................. .................................................. 15
    CUTTING SPEEDS, FEEDS, TOOLS AND TIMES - - - - - - - - - - - - - - - - - - - - 15
    HIGH SPEED MACHINING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 16
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 17
    CUTTING THEORY............................................ .................................................. ................ 17
    CHIP FORMATION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 17
    THE MECHANISM OF CUTTING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 18
    POWER CONSUMED IN CUTTING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 25
    PRACTICE QUESTIONS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 31
    TEMPERATURES IN CUTTING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 39
    TOOL WEAR - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 39
    CUTTING TOOL MATERIALS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 41
    TOOL LIFE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 43
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 51
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 52
    SAWS .................................................. .................................................. ................................ 55
    SPEEDS AND FEEDS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 56
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 56
    DRILLING.......................................... .................................................. ................................. 57
    TYPES OF DRILL PRESSES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 57
    TYPICAL DRILL PRESS OPERATIONS - - - - - - - - - - - - - - - - - - - - - - - - - - - 57
    TYPICAL DRILL BITS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 59
    DRILLING PROCESS PARAMETERS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 66
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 68
    LATHES .................................................. .................................................. ............................ 71
    INTRODUCTION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 71
    OPERATIONS ON A LATHE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 72
    LATHE TOOLBITS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 75
    FEEDS AND SPEEDS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 83
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 86
    MILLING........................................... .................................................. .................................. 92
    INTRODUCTION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 92
    FEEDS AND SPEEDS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 97
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 103
    GRINDING.......................................... .................................................. .............................. 106
    page 3
    OPERATIONS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 106
    MACHINE TYPES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 106
    GRINDING WHEELS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 108
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 110
    SURFACES .................................................. .................................................. ...................... 111
    MEASURES OF ROUGHNESS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 112
    METHODS OF MEASURING SURFACE ROUGHNESS - - - - - - - - - - - - - - - 115
    OTHER SYSTEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 121
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 124
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 134
    METROLOGY .................................................. .................................................. ................. 143
    INTRODUCTION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 143
    DEFINITIONS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 143
    STANDARDS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 144
    INSTRUMENTS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 147
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 155
    GAUGE BLOCKS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 171
    MEASURING APARATUS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 196
    ASSEMBLY.......................................... .................................................. ............................ 203
    THE BASICS OF FITS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 203
    C.S.A. B97-1 1963 LIMITS AND FITS(REWORK) - - - - - - - - - - - - - - - - - - - - 205
    CSA MODIFIED FITS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 210
    CSA LIMITS AND FITS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 211
    THE I.S.O. SYSTEM - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 214
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 214
    WELDING/SOLDERING/BRAZING........................................... ...................................... 216
    ADHESIVE BONDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 217
    ARC WELDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 217
    GAS WELDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 219
    SOLDERING AND BRAZING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 220
    TITANIUM WELDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 221
    PLASTIC WELDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 223
    EXPLOSIVE WELDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 229
    AESTHETIC FINISHING......................................... .................................................. ......... 233
    CLEANING AND DEGREASING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 233
    PAINTING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 233
    COATINGS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 238
    MARKING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 238
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 240
    METALLURGICAL TREATMENTS........................................ ......................................... 241
    HEAT TREATING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 241
    ION NITRIDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 241
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 241
    CASTING........................................... .................................................. ............................... 243
    SAND CASTING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 244
    SINGLE USE MOLD TECHNIQUES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 249
    page 4
    MULTIPLE USE MOLD TECHNIQUES - - - - - - - - - - - - - - - - - - - - - - - - - - - 255
    OTHER TOPICS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 261
    Design of Castings - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 262
    REFERENECES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 263
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 263
    MOLDING........................................... .................................................. .............................. 267
    REACTION INJECTION MOLDING (RIM) - - - - - - - - - - - - - - - - - - - - - - - - 268
    INJECTION MOLDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 274
    EXTRUSION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 283
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 285
    ROLLING AND BENDING .................................................. .............................................. 287
    BASIC THEORY - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 287
    SHEET ROLLING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 289
    SHAPE ROLLING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 290
    BENDING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 290
    SHEET METAL FABRICATION .................................................. ..................................... 294
    SHEET METAL PROPERTIES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 294
    SHEARING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 294
    DEEP DRAWING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 296
    SPINNING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 297
    MAGNETIC PULSE FORMING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 297
    HYDROFORMING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 299
    SUPERPLASTIC FORMING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 302
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 306
    FORGING (to be expanded)......................................... .................................................. ...... 310
    PROCESSES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 310
    EXTRUSION AND DRAWING........................................... ............................................... 310
    DIE EXTRUSION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 310
    HYDROSTATIC EXTRUSION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 311
    DRAWING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 311
    EQUIPMENT - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 311
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 311
    ELECTROFORMING.................................... .................................................. .................... 311
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 313
    COMPOSITE MANUFACTURING..................................... ............................................... 314
    FIBER REINFORCED PLASTICS (FRP) - - - - - - - - - - - - - - - - - - - - - - - - - - - 314
    COMPOSITE MANUFACTURING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 325
    POWDERED METALLURGY........................................ .................................................. .. 339
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 341
    ABRASIVE JET MACHINING (AJM)............................................. .................................. 342
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 346
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 346
    HIGH PRESSURE JET CUTTING........................................... ........................................... 346
    ABRASIVE WATERJET CUTTING (AWJ) .................................................. .................... 349
    ULTRA SONIC MACHINING (USM) .................................................. ............................. 354
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 367
    page 5
    ELECTRIC DISCHARGE MACHINING (EDM)............................................. .................. 369
    WIRE EDM - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 372
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 375
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 375
    ELECTROCHEMICAL MACHINING (ECM) .................................................. ................. 375
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 385
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 385
    ELECTRON BEAM MACHINING......................................... ............................................ 387
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 393
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 394
    ION IMPLANTATION .................................................. .................................................. .... 394
    THIN LAYER DEPOSITION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 397
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 397
    ELECTROSTATIC SPRAYING .................................................. ....................................... 398
    ELECTROSTATIC ATOMIZATION METHOD - - - - - - - - - - - - - - - - - - - - - - 398
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 401
    AIR-PLASMA CUTTING .................................................. ................................................. 401
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 404
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 404
    LASER CUTTING .................................................. .................................................. ........... 405
    LASERS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 405
    LASER CUTTING - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 413
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 420
    RAPID PROTOTYPING....................................... .................................................. ............. 421
    STL FILE FORMAT - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 421
    STEREOLITHOGRAPHY - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 424
    BONDED POWDERS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 433
    SELECTIVE LASER SINTERING (SLS) - - - - - - - - - - - - - - - - - - - - - - - - - - - 435
    SOLID GROUND CURING (SGC) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 438
    FUSED DEPOSITION MODELLING (FDM) - - - - - - - - - - - - - - - - - - - - - - - - 440
    LAMINATE OBJECT MODELING (LOM) - - - - - - - - - - - - - - - - - - - - - - - - - 443
    DIRECT SHELL PRODUCTION CASTING (DSPC) - - - - - - - - - - - - - - - - - - 447
    BALLISTIC PARTICLE MANUFACTURING (BPM) - - - - - - - - - - - - - - - - - - 449
    COMPARISONS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 451
    AKNOWLEDGEMENTS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 452
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 452
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 454
    PROCESS PLANNING.......................................... .................................................. ............ 455
    TECHNOLOGY DRIVEN FEATURES - - - - - - - - - - - - - - - - - - - - - - - - - - - - 456
    MOST SIGNIFICANT FEATURE FIRST - - - - - - - - - - - - - - - - - - - - - - - - - - 456
    DATABASE METHODS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 467
    MANUFACTURING VOLUMES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 468
    STANDARD PARTS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 469
    PRACTICE PROBLEMS - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 469
    REFERENCES - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 477
    جواد كاظم حسين
    جواد كاظم حسين غير متواجد حالياً
    الصورة الرمزية جواد كاظم حسين
    مشكور و جزاك الله خيرا و بارك الله فيكم
    aboalzooz2002
    مشكوووووور اخي علي هاالهدية القيمة
    بس
    By Gary F. Benedict
    هانى شرف الدين
    Received: 15
    اقتباس المشاركة الأصلية كتبت بواسطة aboalzooz2002 مشاهدة المشاركة
    بس
    nontraditional manufacturing processes
    by gary f. Benedict
    ارجو ان يكون هذا المرجع هو الذى تبحث عنه
    HASSAN MORSY79
    HASSAN MORSY79 غير متواجد حالياً
    اله يبارك فيكم اريد مرجع surface productionoperations design of oil handling systems and facilities وجزاكم الله خيرا
