Staad pro (advanced
النتائج 1 إلى 2 من 2
    basamkicd
    basamkicd غير متواجد حالياً
    Staad pro (advanced
    Modeling and Design of Structures by
    STAAD PRO (ADVANCED)
    3-14 may 2009- Holiday Inn - Kuwait
    This course is intended for engineers who have experience in using STAAD.Pro and want to learn some of its advanced features. In this course, you learn to use the program for applications involving dynamic analysis, mat foundation analysis, various types of load generation, steel connection design, reinforced concrete design, etc. You also learn to troubleshoot frequently encountered problems like instabilities and modeling errors. Finally, get an introduction to the powerful interface called Open STAAD. All of these topics are discussed through hands-on exercises.
    Topics covered include:
    - Troubleshooting Modeling problems
    - Zero stiffness conditions and instabilities
    - Modeling semi-rigid/shear connections and rigid links
    - Seismic analysis using static equivalent methods - UBC, IBC
    - Structural Dynamics - mode shapes, frequencies, participation factors
    - Time History analysis for seismic loads, machine vibrations, random excitation, blast loading
    - Response spectrum analysis
    - Mat foundation analysis using plate and solid elements, soil springs, contact supports
    - Spring support generation, examining soil pressure intensities and diagrams
    - Physical beam design using the steel designer
    - Connection design using the steel designer
    - Reinforced Concrete Design using the RC Designer
    - Load generation - Panel area loads, wind loads on closed and open structures, moving loads
    - Tension-only members
    - OpenSTAAD
    Benefits include:
    You get an insight into practical applications of advanced topics in structural engineering. The course also helps you learn ways to use the software more productively.
    www.kicd.net
    kustar3*************
    عتاب فلسطين
    عتاب فلسطين غير متواجد حالياً
    عضو فعال جداً (حائزة على المركز الأول في المسابقة المعمارية)
    الصورة الرمزية عتاب فلسطين
    مشكوور جزيلااا على الموضوع.....
    سوف ينقل موضوعك الى قسم هندسة العمارة والتخطيط ليتم الاستفادة منه
