Matlab R2008a 7.6 (32 bits) بروابط مضموووونة
النتائج 1 إلى 9 من 9
    RuLes BrEAker
    RuLes BrEAker غير متواجد حالياً
    Description
    Matlab R2008a 7.6 (32bits version)
    Windows 2003, XP, Vista, 2008 | ISO | 2 GB
    MATLAB is a high-level technical computing language and interactive environment for algorithm development, data visualization, data analysis, and numeric computation. Using the MATLAB product, you can solve technical computing problems faster than with traditional programming languages, such as C, C , and Fortran.
    You can use MATLAB in a wide range of applications, including signal and image processing, communications, control design, test and measurement, financial modeling and analysis, and computational biology. Add-on toolboxes (collections of special-purpose MATLAB functions, available separately) extend the MATLAB environment to solve particular classes of problems in these application areas.
    MATLAB provides a number of features for documenting and sharing your work. You can integrate your MATLAB code with other languages and applications, and distribute your MATLAB algorithms and applications.
    Key Features
    * High-level language for technical computing
    * Development environment for managing code, files, and data
    * Interactive tools for iterative exploration, design, and problem solving
    * Mathematical functions for linear algebra, statistics, Fourier analysis, filtering, optimization, and numerical integration
    * 2-D and 3-D graphics functions for visualizing data
    * Tools for building custom graphical user interfaces
    * Functions for integrating MATLAB based algorithms with external applications and languages, such as C, C , Fortran, Java, COM, and Microsoft Excel
    Minimum configuration :
    * Pentium IV
    * 1 GB RAM (2 GB for the 64 bits version)
    * 625 MB disk space
    * Windows XP (SP2), 2003 (SP2), Vista, 2008
    Présentation générale
    MATLAB est un langage de calcul scientifique de haut niveau et un environnement interactif pour le développement d'algorithmes, la visualisation et l'analyse de données, ou encore le calcul numérique. En utilisant MATLAB, vous pouvez résoudre des problèmes de calcul scientifique plus rapidement qu'avec les langages de programmation traditionnels, tels que C, C et Fortran.
    Vous pouvez utiliser MATLAB dans une grande variété d'applications, incluant le traitement du signal et d'images, les communications, la conception de systèmes de contrôle, les tests et les mesures, la modélisation et l'analyse financière, ainsi que la biologie informatique. Des boîtes à outils supplémentaires (collections de fonctions MATLAB à vocation spécifique, disponibles séparément) élargissent l'environnement MATLAB pour résoudre des catégories particulières de problèmes dans ces domaines d'applications.
    MATLAB offre un certain nombre de fonctionnalités pour la documentation et le partage de votre travail. Vous pouvez intégrer votre code MATLAB avec d'autres langages et applications, et distribuer vos algorithmes et applications MATLAB.
    Principales fonctionnalités :
    * Langage de haut niveau pour le calcul scientifique
    * Environnement de développement pour la gestion du code, des fichiers et des données
    * Outils interactifs pour l'exploration itérative, la conception et la résolution de problèmes
    * Fonctions mathématiques pour l'algèbre linéaire, les statistiques, l'analyse de Fourier, le filtrage, l'optimisation et l'intégration numérique
    * Fonctions graphiques 2-D et 3-D pour la visualisation des données
    * Outils pour la construction d'interfaces graphiques personnalisées
    * Fonctions pour l'intégration d'algorithmes développés en langage MATLAB, dans des applications et langages externes, tels que C/C , Fortran, Java, COM et Microsoft Excel
    Configuration minimale :
    * Pentium IV
    * 1 Go RAM (2 Go pour la version 64 bits)
    * 625 Mo d'espace disque
    Download links :
    http://anonym-to.com/?http://rapidshare.com/files/109812690/ML2K8A_32.part01.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109814359/ML2K8A_32.part02.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109816263/ML2K8A_32.part03.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109818561/ML2K8A_32.part04.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109820892/ML2K8A_32.part05.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109822631/ML2K8A_32.part06.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109824229/ML2K8A_32.part07.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109826239/ML2K8A_32.part08.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109828089/ML2K8A_32.part09.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109830154/ML2K8A_32.part10.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109832249/ML2K8A_32.part11.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109833586/ML2K8A_32.part12.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836214/ML2K8A_32.part13.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836301/ML2K8A_32.part14.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836328/ML2K8A_32.part16.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836329/ML2K8A_32.part15.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836414/ML2K8A_32.part17.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836418/ML2K8A_32.part18.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836429/ML2K8A_32.part19.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836421/ML2K8A_32.part20.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109836446/ML2K8A_32.part21.rar.html
    http://anonym-to.com/?http://rapidshare.com/files/109814696/ML2K8A_32.part22.rar.html
    password : alisave
    العقاب الهرم
    مشرف داعم للملتقى
    الصورة الرمزية العقاب الهرم
    Received: 41
    Given: 17
    thaaaaaaaaaaaaaaaaaanks
    بشار سيمُـوت ولن تمُت حِمص
    متغيب عن المنتدى
    دعواتكم
    waleedali
    waleedali غير متواجد حالياً
    مشكور اخي الكريم على جهودك
    عمر Zh
    عمر Zh غير متواجد حالياً
    الصورة الرمزية عمر Zh
    يعطيك العافيه هذا اللي كنت ابيه ومشكور
    Sooje
    Sooje غير متواجد حالياً
    hi
    hi plz i need help to solve h.w by matlab, so plz how can help me you will find my h.w on http://fetweb.ju.edu.jo/staff/cpe/ja...t_Summer09.pdf
    عمار باقر سالم
    عمار باقر سالم غير متواجد حالياً
    الصورة الرمزية عمار باقر سالم
    شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا شكرا برنامج رائع جاري التحميل
    عمار باقر سالم
    شكرا يا أخي ولكن عند التحميل ينقطع ولا يمكن إكماله ممكن رفعه على ifile it or Zshear
    وشكرا جزيلا
    نايف عمر العمودي
    نايف عمر العمودي غير متواجد حالياً
    شكرا جزيلا
    نخنوخ
    نخنوخ غير متواجد حالياً
    الروابط مش شغالة! إحتمال تكون عجزت؟
