طلب م طالب في الهندسة
النتائج 1 إلى 4 من 4
    منهل ماجد
    منهل ماجد غير متواجد حالياً
    اريد تقرير عن ال impact test
    من مواضيع منهل ماجد :
    منهل ماجد
    رجاءا ساعدوني
    في دراستي لان مداحك بالدراسة ودزولي التقرير
    منهل ماجد
    واتمنى يكون عندي اصدقاء يساعدوني واساعدهم في بحوثهم ولو اني حاليا ما اكدر اساعد احد لان اني بعدني طالب
    أمير صبحي
    أمير صبحي غير متواجد حالياً
    الصورة الرمزية أمير صبحي
    Thumbs down التقرير المطلوب
    Why Use Impact Testing
    Techniques routinely used to measure the mechanical properties of wear-resistant coatings and surfaces sometimes prove difficult to correlate with actual product performance, particularly for surfaces that are subjected to erosive wear or multiple impacts during service. Now quantitative data can be obtained with the revolutionary new technique of small scale impact testing, available as a modular add-on option to the NanoTest. The impact technique can be used with or without transverse sample movement during testing.
    ...when the film fails catastrophically there is an abrupt and easily recognised shift in the probe position...
    Testing Surface Fracture Resistance with Repetitive Contact at a Single Point
    Sample oscillation causes the probe to impact on the surface. When a change in the contact energy occurs (after fracture of the surface or partial debonding of a coating) a change in probe recoil takes place. Changes in probe depth reveal surface damage (erosive wear).
    Measuring Thin Film Adhesion Failure with Scanning Impact Testing
    Transverse sample movement during scanning at either constant or steadily increasing load causes the test probe to continuously impact along the wear track, simulating many film failure situations, e.g. erosive wear and coating adhesion failure. Tool bit coatings for example, invariably impact the workpiece at slightly different locations due to vibration. The impact energy is determined by the oscillation amplitude and frequency and the underlying applied load. Film failure is detected through changes in probe displacement during scanning.
    Specifications
    • Single and
    Contact Fatigue Delamination of Multi-Layer Polymer Films
    ...when the film fails there is an easily recognised shift in probe position...
    اهلا بك في منتدانا ونحن كلنا اخوانك قبل زملائك|.....................تحياتي..........
    قِف دون رأيك في الحياة مجاهداً --- إن الحياة عقيدة وجهاد
