Steps of making new wps
النتائج 21 إلى 30 من 48
  1. [21]
    سيد صلاح الصاوى
    سيد صلاح الصاوى غير متواجد حالياً
    الصورة الرمزية سيد صلاح الصاوى
    Received: 62
    Given: 43
    welding manual
    Procedure Specification
    Procedure Specification for semiautomatic gas
    metal arc (MIG) welding of mild carbon steel per
    AWS structural welding code D1.1 1999 using
    75-25 (75% Argon 25% CO
    2) gas - spray arc
    transfer - solid wire.
    see attached file
  2. [22]
    سامح 2010
    سامح 2010 غير متواجد حالياً
    الصورة الرمزية سامح 2010
    جزاك الله خيرا جميعا
  3. [23]
    سيد صلاح الصاوى
    Received: 62
    Given: 43
    Structural Steel Welding
    Arc welding requires striking a low-voltage, high-current arc between an electrode and the workpiece (base metal). The
    intense heat generated with this arc melts the base metal and allows the joining of two components. The characteristic of
    the metal that is being welded and the joint type (i.e. groove, fillet, etc.) dictates the welding parameters and the procedure
    that needs to be followed to obtain a sound weld joint.
  4. [24]
    سيد صلاح الصاوى
    Received: 62
    Given: 43
    Welding terms
    الملف المرفق هام جدا فيه
    كل ما يهم العاملين بمجال اللحام
  5. [25]
    سيد صلاح الصاوى
    Received: 62
    Given: 43
    Recommended Practice Welding Guidelines for the Chemical, Oil, and Gas Industries
    1.1 This Recommended Practice provides supplementary guidelines and practices for welding and welding related topics for shop and field fabrication, repair and modification of:
    a. Pressure-containing equipment such as pressure vessels, heat exchangers, piping, heater tubes, and pressure boundaries of rotating equipment and attachments welded thereto.
    b. Tanks and attachments welded thereto.
    c. Non-removable internals for process equipment
    d. Structural items attached and related to process equipment
    e. Any other equipment or component item when referenced by an applicable purchase document
  6. [26]
    سيد صلاح الصاوى
    Received: 62
    Given: 43
    Reviewing and Approving Welding Procedure Specfications
    T
    he actual welding procedures
    used for fabrication and erection
    of steel structures directly
    affect the quality and properties of
    the resultant weld. Before production
    begins, proposed welding
    procedures may be submitted to
    the engineer for review.
    Discussed are practical guidelines
    which facilitate this review.
    Particular emphasis is placed on
    joint design geometries, acceptable
    combinations of amperage,
    voltage and travel speed, and
    relationships of deposition rates
    and weld bead sizes. While representing
    general trends and no
    universally accurate for all
    processes or procedures, these
    guideline will help identify Welding
    Procedure Specifications (WPSs)
    that should be scrutinized more
    carefully.
  7. [27]
    سيد صلاح الصاوى
    Received: 62
    Given: 43
    ARAMCO-Welding Test Supplement S01 for SMAW
    This welder performance qualification Test Supplement shall govern the testing of
    welders with the Shielded Metal Arc Welding (SMAW) process, welding progression
    vertical up, for welding carbon and low alloy steel pipe.
  8. [28]
    tifaonline
    tifaonline غير متواجد حالياً
    many many many
    thanks
  9. [29]
    مهندس جعفر معايطة
    مهندس جعفر معايطة غير متواجد حالياً
    هل بإمكان الأخوة الزملاء مساعدتي في كيفية الحصول على الدورات التي تهتم في مجال التعدين والمؤتمرات والمنعقدة مستقبليا خارج الاردن ولكم جزيل الشكر
  10. [30]
    Eng.Saeed
    Eng.Saeed غير متواجد حالياً
    الاخ الصاوي جزاك الله كل خير و نفع الله بعلمك و رزقك من حيث لا تحتسب و الشكر موصولا الى القائمين على هذا الموقع المميز.....
