The Tailstock of a Lathe
النتائج 1 إلى 3 من 3
    hassono
    hassono غير متواجد حالياً
    That’s a good one, what must i tell you about a Tail stock.
    A: Clamping Lever
    B: Barrel
    C: Center
    D: Hand wheel
    E: Cross Adjustment
    With the clamping lever you can fixate the tailstock on the ways.
    When you turn the Hand wheel , the Barrel will be moved out or in.
    This is a Barrel close up
    This is the nonius of the cross adjustment
    How do we test that the tailstock is in the middle?
    Well that’s easy. We take a piece of round material with a center point on one side and we put it in the machine like this.
    Place a Dial test indicator to it and set it to zero.
    Then turn your material to the maximum and minimum. Turn it to the middle and set it to zero.
    Make a line with a marker at the top of the material.
    Do the same at the center side. So when you moves the Dial test indicator from one side ( with the marker at the top ) to the other side ( with the marker at the top ) , then must the Dial test indicator be at zero. Else you must change the cross adjustment.
    I hope you have understand what i mean. My English is not so good.
    شكرى محمد نورى
    Received: 62
    شكرا جزيلا اخي الكريم وجزاك الله خيرا .
    نترقب المزيد والجديد .
    تقبل اجمل التحايا .
    البغدادي
    eng hamed
    eng hamed غير متواجد حالياً
    الصورة الرمزية eng hamed
    thaaaaaaaaaaaaaaaaaaaaanks for the great effort
