صور عن كيفية تنفيذ السدود
مشاهدة نتائج الإستطلاع: هل ترون استفادة من هذه الصور ام لا ( بصراحة) وهل من اقتراح
المصوتون
30. أنت لم تصوت في هذا الإستطلاع
  • نعم
    29 96.67%
  • لا
    1 3.33%
إستطلاع متعدد الإختيارات.
صفحة 20 من 34 الأولىالأولى ... 1016 17 18 19 2021 22 23 24 30 ... الأخيرةالأخيرة
النتائج 191 إلى 200 من 337
  1. [191]
    رزق حجاوي غير متواجد حالياً
    الصورة الرمزية رزق حجاوي
    Received: 4,985
    Given: 1,442
    اقتباس المشاركة الأصلية كتبت بواسطة asd salim مشاهدة المشاركة
    pls i need referance for drsign of cofferdams
    Cofferdams تعني المنشأت المؤقته التي تصمم لحفظ الماء او التربة بعيدا عن الحفريات مثل دعامات الكباري= الجسور او السدود او اي منشأت اخرى يرغب في بناؤها .
    امثله على ذلك
    • Cofferdams are temporary enclosures to keep outwater and soil so as to permit dewatering andconstruction of the permanent facility (structure) in the dry.
    • A cofferdam involves the interaction of the structure,soil, and water. The loads imposed include the hydrostatic forces of the water, as well as the dynamic forces due to currents and waves.
    • Because cofferdams are typically constructed under adverse conditions in a marine environment, and because significant deformations of elements may occur at various stages of construction, it is difficult to maintain close tolerances. Ample provisions must be made for deviations in dimensions so that the finished structure may be constructed according to plan.
    • The loads imposed on the cofferdam structure by construction equipment and operations must be considered, both during installation of the cofferdam and during construction of the structure itself.
    • Removal of the cofferdam must be planned and executed with the same degree of care as its
      installation, on a stage-by-stage basis. The effect of the removal on the permanent structure must also be considered. For this reason, sheet piles extending below the permanent structure are often cut off and left in place, since their removal may damage the foundation soils adjacent to the structure.
    • In cofferdam construction, safety is a paramount concern, since workers will be exposed to the hazard of flooding and collapse
    Safety requires:-
    • good design
    • proper construction
    • verification that the structure is being constructed as planned
    • monitoring the behavior of the cofferdam and surrounding area
    • provision of adequate access
    • light and ventilation, and
    • attention to safe practices on the part of all workers and
    • supervisors
    Types of cofferdam:
    • Braced
    • Earth-Type
    • Timber Crib
    • Double-Walled Sheet Pile
    • Cellular
    Braced Cofferdams
    • Formed from a single wall of sheet piling
    • Driven into the ground to form a box around the excavation site
    • The "box" is then braced on the inside
    • Interior is dewatered
    • Primarily used for bridge piers in shallow water (30 - 35 ft depth).
    Cofferdam Design Considerations
    • Scouring or undermining by rapidly flowing water
    • Stability against overturning or tilting
    • Upward forces on outside edge due to tilting
    • Stability against vertical shear
    • Effects of forces resulting from:
    • Ice, Wave, Water, Active Earth and Passive Earth Pressures.
    Advantages of Cofferdam
    • Allow excavation and construction of structures in otherwise poor environment
    • Provides safe environment to work
    • Contractors typically have design responsibility
    • Steel sheet piles are easily installed and removed
    • Materials can typically be reused on other projects
    Items needed for installation
    • Pile driving hammer
    • Vibratory or Impact
    • Crane of sufficient size
    • Steel sheet piles are typically used
    • H-piles and/or wide-flange beams for wales and stringers
    • Barges may be required
    وللمشاركة بقية باذن الله
    www.husseinhijjawiest.com
  2. [192]
    محمودشمس
    محمودشمس غير متواجد حالياً
    عضو متميز جداً
    Received: 14
    الف شكر وربنا يجزيك خير
  3. [193]
    asd salim
    asd salim غير متواجد حالياً
    Received: 19
    اقتباس المشاركة الأصلية كتبت بواسطة كوردستان مشاهدة المشاركة
    i etha momkin tarsel li al moltaqa adad min alswar li hatha al sad
    akh
    pls donot use english words to write arabic words..u r distroying both languages
  4. [194]
    asd salim
    Received: 19
    thx eng. rezic...pls i need design calculation for earth cofferdam,,wsh u can help
  5. [195]
    قاسم الكيميائي
    قاسم الكيميائي غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية قاسم الكيميائي
    Received: 26
    Given: 20
    شكرا جزيلا اخوان
    اذا امكن اهم الفحوصات التي تتم على السدود الترابية وشكرا
  6. [196]
    أبو العز عادل
    أبو العز عادل غير متواجد حالياً
    مشكور يا أخي على هذه الصور المفيده
  7. [197]
    محمودشمس
    عضو متميز جداً
    Received: 14
    شكرا علي هذا العطاء الطيب
  8. [198]
    asd salim
    Received: 19
    i need software for designing earth embanments
  9. [199]
    asd salim
    Received: 19
    i need software for designing earth embankments
  10. [200]
    hivi
    hivi غير متواجد حالياً
    شكرا على الصور الرائعة ونتمنى المزيد
