Welding of Duplex Stainless Steel
النتائج 1 إلى 4 من 4
    الصورة الرمزية سيد صلاح الصاوى
    سيد صلاح الصاوى
    سيد صلاح الصاوى غير متواجد حالياً
    Received: 62
    Given: 43
    Duplex stainless steel is among various metals used in corrosion-resistant applications. This article presents an overview of the material's properties, advantages, and disadvantages and compares it to other materials suitable for corrosion-prone environments. It also discusses welding and forming duplex.
    What Is Duplex Stainless
    The word duplex is based on the concept of austenite and ferrite formulated in the same material. The user may require a briefing about the material's composition, but in general, the most important aspect is what it will do in use. Fabricators really are not interested in chemical composition or phase diagrams. They want to know a material's advantages and disadvantages and how difficult or easy it is to fabricate. Metallurgists are interested in the material's composition and the end usage. They may be able to investigate the mechanical, physical, and chemical properties and discover advantages or disadvantages for a particular application.
    gearbox
    gearbox غير متواجد حالياً
    الصورة الرمزية gearbox
    جزاك الله خيرا ز
    mkn
    mkn غير متواجد حالياً
    Duplex
    Find another Link related to the same subject
    http://www.arab-eng.org/vb/showthread.php?t=77738
    Regards
    ahwazy
    ahwazy غير متواجد حالياً
    شکرا وجزاکم الله خیرا
