Tri-generation
النتائج 1 إلى 7 من 7
    الصورة الرمزية zanitty
    zanitty
    zanitty غير متواجد حالياً
    Received: 1,109
    Given: 1,645
    Tri-generation
    يا ريت لو حد عنده معلومه عن الموضوع ده او كتاب او حتى يدلنى الاقى فين حاجه تفيدنى عن الموضوع ده يا ريت يدلنى و يبقى له جزيل الشكر و الثواب باذن الله
    من مواضيع zanitty :
    سبحانك اللهم و بحمدك... اشهد ان لا اله الا انت... استغفرك و اتوب ا
    ليك
    من طلب رضا الله بسخط الناس
    رضى عنه الله و ارضى عنه الناس
    و من طلب رضا الناس بسخط الله
    سخط عليه الله و اسخط عليه الناس
    استحضار النيه (مهم جدا للجميع)
    aati badri
    aati badri غير متواجد حالياً
    Received: 861
    Given: 384
    رد: Tri-generation
    1 Not allowed!
    aati badri
    Received: 861
    Given: 384
    رد: Tri-generation
    Trigeneration or CCHP (combined cooling, heat and power) refers to the simultaneous generation of electricity and useful heating and cooling from the combustion of a fuel or a solar heat collector. The supply of high-temperature heat first drives a gas or steam turbine powered generator and the resulting low-temperature waste heat is then used for water or space heating as described in cogeneration. Trigeneration differs from cogeneration in that the waste heat is used for both heating and cooling, typically in an absorption chiller. CCHP systems can attain higher overall efficiencies than cogeneration or traditional power plants.
    A modern American acronym is BCHP, Building Cooling, Heating and Power, for trigeneration applications in buildings. Heating and cooling output may operate concurrently or alternately depending on need and system construction.
    1 Not allowed!
    aati badri
    Received: 861
    Given: 384
    aati badri
    Received: 861
    Given: 384
    aati badri
    Received: 861
    Given: 384
    aati badri
    Received: 861
    Given: 384
