Pic16f84a اي مساعده في هذا المتحكم انا جاهز .....
صفحة 6 من 6 الأولىالأولى ... 2 3 4 5 6
النتائج 51 إلى 52 من 52
  1. [51]
    محمدالقبالي
    محمدالقبالي غير متواجد حالياً
    الصورة الرمزية محمدالقبالي
    Received: 28
    Given: 36
    اقتباس المشاركة الأصلية كتبت بواسطة slmat27 مشاهدة المشاركة
    sorry that i had to write in english, but writing in arabic language is kinda very slow for me and i wont be able to put the right words in time.
    Let's get into my request directly to save your time, i'm doing a project for my 3rd year of engineering in mechatronics. And i need to use pic16f84a as my micro-controller. But i'm facing a problem in adjusting the inputs right as i want so i want a sample code to work on my code. s
    i'm using mplab as my ide, picc_ccs as my compiler, proteus as my simulator.
    I want a sample code in c doing a simple function; for example:s
    - input 5v @ pin_a0 > output is high @ pin_b0 & pin_b1 ~ for 1 sec
    - input 5v @ pin_a1 > output is high @ pin_b2 & pin_b3 ~ for 1 sec
    - input 5v @ pin_a2 > output is high @ pin_b4 & pin_b5 ~ for 1 sec
    - input 5v @ pin_a3 > output is high @ pin_b6 & pin_b7 ~ for 1 sec
    i attached my code for 8 leds sequence, it works fine by lighting up 8 leds in sequence one each sec...
    Hope you can help me as soon as possible - again sorry for writing in english
    اخي الكريم انا ممكن اساعدك ولكن بلغة الاسيمبلي او بالفلوكود
    تحياتي
    سبحان الله وبحمده -- سبحان الله العظيم
  2. [52]
    samoha-991
    samoha-991 غير متواجد حالياً
    رد: Pic16f84a اي مساعده في هذا المتحكم انا جاهز .....
    اخي محمد هل تستطيع مساعدتي في برمجة atmega16ببرنامج الbascom
