Pipelines Welding Handbook
النتائج 1 إلى 10 من 14
    الصورة الرمزية سيد صلاح الصاوى
    سيد صلاح الصاوى
    سيد صلاح الصاوى غير متواجد حالياً
    Received: 62
    Given: 43
    Every day countless kilometres of steel pipelines are installed
    worldwide for the most varied civil and industrial uses.
    They form real networks comparable to a system of road networks,
    which, although not so obvious, are definitely much more intricate and
    carry fluids that have become essential for us.
    To comply with technical specifications and fulfil the necessary safety
    requisites, special materials and welding processes which have
    evolved with the sector have been developed in recent years.
    The main welding process used to install the pipelines is manual
    welding with coated electrode, which, thanks to its ease and
    versatility, is still the one most used.
    However, to limit costs and increase welding productivity, particularly
    on long routes, various constructors have adopted the semi-automatic
    or completely automatic welding process with solid wire or wire
    flux coated with gaseous protection.
    This handbook describes both methods. Ample space has been
    dedicated, in particular, to manual welding, with particular reference to
    the operative practice and quality assessment, due to its considerable
    use still today, but not neglecting more modern and productive
    methods which will be increasingly used in future.
    The presumption of this work is to be able to satisfy the most
    demanding technician and welder, but, in particular, to supply each
    user with useful information and a solid operative basis, as regards
    the processes and filler materials and the welding equipment.
    سامح 2010
    سامح 2010 غير متواجد حالياً
    الصورة الرمزية سامح 2010
    جزاكم الله خيرا على موضوعاتك القيمه
    وائل البحراوى
    وائل البحراوى غير متواجد حالياً
    الصورة الرمزية وائل البحراوى
    شكر جدا
    احمد محمد1982
    احمد محمد1982 غير متواجد حالياً
    الصورة الرمزية احمد محمد1982
    شكرا جزيلا على هذا المصدر و اتمنى الموفقية و النجاح الدائم لك يا سيد صلاح و شكرا
    اخوكم احمد الانصاري
    mehdi09
    mehdi09 غير متواجد حالياً
    جزاكم الله خيرا
    aakel gedn
    aakel gedn غير متواجد حالياً
    بارك اللة لكم
    غيث هادي عباس علي
    غيث هادي عباس علي غير متواجد حالياً
    الصورة الرمزية غيث هادي عباس علي
    مشكوور وجزاك الله خير جزاء
    aly_zz
    aly_zz غير متواجد حالياً
    بارك الله فيك و جعله الله فى ميزان حسناتك
    ولكن اين الملف
    سبحان الله و بحمده سبحان الله العظيم
    aly_zz
    الملف تم تحميله ممتاز جدا
    buk88
    buk88 غير متواجد حالياً
