معادلات مهمة في هندسة المساحة
صفحة 1 من 15 12 3 4 5 11 ... الأخيرةالأخيرة
النتائج 1 إلى 10 من 143
    الصورة الرمزية دفع الله حمدان هجو
    دفع الله حمدان هجو
    دفع الله حمدان هجو غير متواجد حالياً
    مشرف مميز
    Received: 192
    مرحبا بكم مرة اخري في موضوع اخر وهو معادلات مهمة في هندسة المساحة
    وهي منقولة من الموقع للفائدة
    المعادلة الاولي
    Transformations"
    Introduction
    In our work, it may sometimes be necessary to transform a set of co-ordinates from one cartesian system to another. The following formulae may be used to transform a set of (e, n) co-ordinates into a set of (e', n') co-ordinates.
    Scale
    A simple scale change, for example changing feet to metres or applying a meteorological scale factor, may be applied thus:
    e' = k e
    n' = k n
    where e, n = original (old) co-ordinates: k = scale factor: e', n' = new co-ordinates
    Rotation
    For a rotation of axis about an angle θ, which may be given or derived from known co-ordinates in both systems:
    e' = e cos θ - n sin θ
    n' = e sin θ + n cos θ
    where e',n' = new co-ordinates: e, n = original co-ordinates: θ = angle of rotation
    Translation
    For a change of origin by factors E and N:
    e' = e + E
    n' = n + N
    where e',n' = new co-ordinates: e, n = original co-ordinates: E & N = shift factors
    Scale, Rotation and Translation
    If the transformation parameters are known
    (i) e' = k (e cos θ) - k (n sin θ) + E
    (ii) n' = k (e sin θ) + k (n cos θ) + N
    These formulae work for all cases.
    If no scale factor is required, substitute k = 1.
    If no rotation is needed then substitute θ = 0.
    Similarly, if no Translations are required E & N = 0 as required.
    If the transformation parameters are NOT known
    In this case, two points in each system must be known (preferably as far apart as possible).
    The following parameters may be calculated:
    Scale Factor
    k = (Distance between 2 points in new system) / (Distance between 2 points in old system)
    Rotation Angle
    θ = (Bearing between 2 points in new system) - (Bearing between same 2 points in old system)
    Translation
    If (e, n) = 1 point in old co-ordinate system and (e', n') = same point in new system:
    E = e' - k (e cos θ) + k (n sin θ)
    N = n' - k (e sin θ) - k (n cos θ)
    Further points may now be transformed by applying these parameters into the above formulae (i) and (ii).
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    المعادلة الثانية
    1 Not allowed!
    هدفنا خدمة مهندس المساحة والطرق
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    المعادلة الثالثة
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    المعادلة الرابعة
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    المعادلة الخامسة
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    المعادلة السادسة
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    المعادلة السابعة
    د احمد بكر
    د احمد بكر غير متواجد حالياً
    الصورة الرمزية د احمد بكر
    Received: 36
    Given: 25
    جزاكم الله خير
    موضوع تستحق علية الشكر
    دفع الله حمدان هجو
    مشرف مميز
    Received: 192
    هي معادلات مهمة جدا في اعمال المساحة اليومية
    د احمد بكر
    Received: 36
    Given: 25
    نرجوا منك اخي لو تكرمت ان ترفع الكتاب
    مصدر المشاركة ليستفيد منة المنتدي
    وتذكر لكل شي زكاة وزكاة العلم نشرة
    وجزاكم الله خيرا
