pca programs full
النتائج 1 إلى 10 من 43
    الصورة الرمزية أحمد عصام الدين
    أحمد عصام الدين
    أحمد عصام الدين غير متواجد حالياً
    Received: 17
    pca programs full
    كل الشكر للمهندس احمد ابو هاشم رافع البرامج الاصلي
    البرنامج علي اكتر من سيرفر
    ندخل في البرامج
    البرامج التي تم رفعها اصداراتها كالتالي:
    PCA-mats 6.10 of size 14.69 MB
    PCA-slab 2.00 of size 16.43MB
    PCA-beam 2.00 of size 16.54MB
    PCA-Column 3.64 of size 8.818 MB
    PCA-wall 3.50 of size 45.35MB
    وفي النهاية اتمني من الاخوة الاعضاء التفاعل مع الموضوع
    pcaMats analyzes foundation mats, combined footings, or slabs on grade. The slab is modeled as an assemblage of rectangular finite elements. The boundary conditions may be the underlying soil, nodal springs, piles, or translational and rotational nodal restraints. The model is analyzed under static loads that may consist of uniform (surface) and concentrated loads. The resulting deflections, soil pressure (or spring reactions), and bending moments are output. In addition, the program computes the required area of reinforcing steel in the slab
    pcaMats uses the plate-bending theory and the Finite Element Method (FEM) to model the behavior of the mat or slab. The soil supporting the slab is assumed to behave as a set of one-way compression-only springs (Winkler foundation). If, during the analysis, a loading or the mat shape causes any uplift creating a spring in tension, the spring is automatically removed. The mat is re-analyzed without that or any other tension spring. The program automatically iterates until all tension springs are removed and the foundation stabilizes. The program also performs punching shear calculations around columns and piles
    file factory
    z-share
    rapidshare
    pcaSlab is highly efficient in helping engineers analyze, design and investigate reinforced concrete floor systems. Like its predecessor ADOSS, pcaSlab now analyzes beams, one-way slab systems, two-way slab systems, and includes all the functionalities of pcaBeam.
    This program incorporates torsion into shear design and investigation of beam systems. Shear capacity including torsion is represented in terms of required and provided area of transverse and longitudinal reinforcement.
    Additional savings in both material and labor can be achieved using the moment redistribution feature. It allows up to 20% reduction of negative moments over supports reducing reinforcement congestions in these regions.
    pcaSlab supports ACI 318-05, ACI 318-02, ACI 318-99, and CSA.A 23.3-94 codes in both English and metric units.
    Analysis and design tools in pcaSlab are provided for the following systems:
    • Simple and continuous beams
    • One-way slabs
    • Two-way flat plates
    • Two-way flat slabs (with drop panels)
    • One-way pan joist systems (Standard modules)
    • One-way skip joist systems (Wide modules)
    • Two-way joist systems (Waffle slabs)
    pcaSlab enables the user to integrate up to 20 spans and two cantilevers of multiple floor system types in each model. Beyond new slab analysis and design, pcaSlab can perform strength investigation for evaluation and/or modifications to existing building slabs. The program promises to save users time crosschecking designs with applicable provisions of relevant design codes
    file factory
    z-share
    rapidshare
    pcaBeam Version is highly efficient in helping you analyze, design, and investigate beams and one-way slabs in reinforced concrete floor systems . pcaBeam is offered as a limited edition pcaSlab and features ACI 318-05 torsion effects in the shear design and investigation allowing engineers to achieve more economical cross sections where coupled shear and torsion occur. Additional savings in both material and labor can be achieved using the moment redistribution feature. It allows up to 20% reduction of negative moments over supports reducing reinforcement congestions in these regions.
    pcaBeam is a computer program for analysis, design, and investigation of reinforced concrete beams and one-way slab systems. Torsional effects and Moment redistribution can be considered. pcaBeam performs a complete design for flexure and shear and the resulting reinforcement schedules are output (including bar numbers, sizes, lengths, and spacings). pcaBeam offers a great deal of flexibility by allowing the user to modify the reinforcement configuration proposed by the program by switching from the Design to the Investigation option. Under the Investigation option, the longitudinal and transverse reinforcement capacities of the entire system are computed for a given reinforcement configuration. Output is presented in clear and organized tables and may also be viewed graphically. pcaBeam has a graphical interface that uses pull-down menus, dialog boxes, and icons to simplify the data input and clearly present the output.
    file factory
    z-share
    rapidshare
    pcaColumn is a software program for the design and investigation of reinforced concrete sections subject to axial and flexural loads. The section can be rectangular, round or irregular, with any reinforcement layout or pattern. Slenderness effects can be considered. The program offers investigation of irregularly shaped, reinforced concrete column sections that may contain openings or boundary elements. Widely used for design of shear walls, bridge piers as well as typical framing elements in buildings, pcaColumn can investigate sections that are impossible to find on design charts or do by hand calculations. You can obtain the P-M interaction diagrams from both uniaxial and biaxial runs, as well as the Mx-My moment contour plots from biaxial runs for even the most irregular column and shearwall sections. Slenderness effects producing magnified moments may be included in the investigation
    file factory
    z-share
    rapidshare
    pcaWall is a computer program for the design and analysis of reinforced concrete walls, tilt-up walls, and precast architectural and load-bearing panels. Design provisions are in accordance with ACI 318 and CSA A23.3 design standards. The wall may include any number of openings and stiffeners. The program is based on the finite element method and can take into account second-order effects. The amount of steel required for flexure is computed based on the selected design standard, and the user can specify one or two layers of reinforcement. The program also calculates the amount of steel required for shear and torsion in the stiffeners but does not calculate shear reinforcement in the wall elements.
    pcaWall uses an advanced graphical interface that enables the user to easily generate complex wall models. The geometry of the wall (including any number of openings and stiffeners), the material properties, the loads (point, area, and line), and the support conditions are assigned graphically using the mouse. Also, springs (translational and rotational) can be graphically assigned at any node
    pcaColumn program complements pcaWall by generating axial/flexure (P-M) diagrams suitable for shear wall design
    file factory
    z-share
    rapidshare
    الموضوع منقول
    mahmoud.abo80
    mahmoud.abo80 غير متواجد حالياً
    شكرا اخى
    موفق انشاااااء الله ,,,,,,,,,,,,,,,,,,,,,,,
    Aymen
    Aymen غير متواجد حالياً
    الصورة الرمزية Aymen
    مشكوووووورررررررررررر
    م عبد الحكيم مواس
    م عبد الحكيم مواس غير متواجد حالياً
    الصورة الرمزية م عبد الحكيم مواس
    Received: 269
    Given: 472
    الزميل العزيز:
    عند تنزيل pcacol يكون عمله بشكل جيد و بعد عدة أيام تظهر عبارة خطأ و يخر ج البرنامج عن العمل
    أرجو الرد عن هذه الحالة
    إن امكن
    ولكم الشكر
    م.عبد الحكيم
    Eng_M1986
    Eng_M1986 غير متواجد حالياً
    الصورة الرمزية Eng_M1986
    Received: 12
    يا ريت لو حد نزل برنامج Pca wall يعيد رفعه ع موقع تانى
    ibnmolok
    ibnmolok غير متواجد حالياً
    thank you for all things you do
    plz tell me about all you can do
    شرا ياخى و احيا الله ذكرك فى الدنيا و الأخرة
    من أراد عزاً ... فسيكفيه الاسلام
    ibnmolok
    شكرا و احيا الله ذكرك
    صلاح الشافعي
    صلاح الشافعي غير متواجد حالياً
    الصورة الرمزية صلاح الشافعي
    الملفات غير موجود
    نرجو إعادة الرفع على موقع 4shared.com
    صلاح المهندس
    صلاح المهندس غير متواجد حالياً
    Given: 21
    في البدء شكرا جزيلا على المشاركة الرائعة. لم استطع تحميل ال pca wall فأرجوا من الاخ صاحب المشاركة او الاخوة اللذين استطاعوا التنزيل ان يرفعوا لنا البرنامج مشكورين...
    محمد 977
    محمد 977 غير متواجد حالياً
    مشكووووووووووووووووور
    الف الف الف شكر من صميم القلب
    تسلم الأيادي
    جهد مميز و ابداع كبير
    تسلم الأيادي
    أتمنى أن تكون البرامج كاملة و مكركة بشكل كامل و صحيح
    تسلم الأيادي
    تسلم الأيادي
